#1 |
City & State: Providence RI
Hi, monitor has no power at all, no LED at power button.
Attached are pictures of the board, the video and power are on the same board. Probing with a meter, I get 169VDC at the big filter cap, and at the primary connections at T850. I do not measure any other voltages anywhere else on the board, including any direction on the secondary of the transformer. My guess at this point would be the transformer is shot. It's marked "SPW-039 TDK X 0434". I have no idea what the output power or current would be. 2 Questions: 1)Does anyone have any ideas what might be wrong or what else I should measure? 2)Without a datasheet posted online for the transformer, anyone know how to replace it? Thanks |
#2 |
Slow Learner
City & State: Lancashire UK
Check the resistances of the secondary windings on the transformer
#3 |
City & State: California
Try reading the DC voltage of the vcc pin of U850. Sorry , I can't read the part # of U850, so you'll have to look up the spec sheet yourself.
#4 |
Slow Learner
I have been reading other posts
http://www.badcaps.net/forum/showthread.php?t=9297 http://www.badcaps.net/forum/showthr...hlight=E173FPf They have both had problems around R852 q850 and one person came in and said they fixed one by replacing these ,so perhaps you should check yours. Spec sheet may be in one of these threads |
#5 |
City & State: Canada
And the DC voltage across C857. Note if voltages are stable or fluctuating.
--- begin sig file --- If you are new to this forum, we can help a lot more if you please post clear focused pictures (max resolution 2000x2000 and 2MB) of your boards using the manage attachments button so they are hosted here. Information and picture clarity compositions should look like this post. We respectfully ask that you make some time and effort to read some of the guides available for basic troubleshooting. After you have read through them, then ask clarification questions or report your findings. Please do not post inline and offsite as they slow down the loading of pages. --- end sig file --- |
#6 | |
Woa! After seeing this page and billy66's post:
http://www.badcaps.net/forum/showthr...ht=u850&page=2 Quote:
The center pin on Q850 was also -68.7VDC Now I'm no electronics geek, but after rectification why would I be measuring negative voltage? If the whole thing is shorted out I think I'll just call it a day, the monitor only sells for $50 on ebay. Last edited by yotefn; 04-28-2012 at 09:35 PM.. |
#7 |
Negative voltage is a result of you using the wrong ground for your black probe. There is a hot ground and cold ground. Usually the cold ground are the ground screws and chassis. I normally use the negative leg of the large filter capacitor for hot ground.
#8 |
OK, that's good to know.
Here's a list of measurements: Across primary and secondary windings of transformer is non-infinate resistance so I guess thats good for now considering all the other bad measurements. Using filter cap as ground: to cold ground: 67VDC I850 Pins 1 and 2, U801, U802 U851: 67VDC (all pins of these same as cold ground) I850 Pins 3,4: 0V U850 Pin 1,2,4,6: 0VDC Pin 3: 4.4 Pin 5: 0.1 (consistently bumped meter slightly) Pin 7,8: 1.7 Center of Q850: 170VDC Across c857: 1.7VDC U850 part number SG6841S http://pdf1.alldatasheet.com/datashe...C/SG6841S.html Any ideas? Last edited by yotefn; 04-29-2012 at 08:20 AM.. |
#9 | |
Either C857 is bad or the SMPC IC is bad. Start by replacing C857 with something like a Panasonic FC series cap and retest. |
#10 |
Recapped C857, no change.
Analyzing the datasheet and looking at the voltages on U850 at pins 7 and 8, I checked continuity with the IC on the board of those two pins and they were shorted. So I removed the IC and checked again and they're shorted. Ordered a new IC on ebay from Hong Kong (no one reputable carries the chip anymore), will replace and report. Thanks for your help. |
#11 |
Good job finding the short. Yes, if you can't find it at digikey or mouser, ebay is a good alternative.
#12 |
Alright, replaced U850, but now I have fluctuating voltage across C857 (equal to pins 1 and 7 on the SMPS) between 12.1V and 15.8V, with no power to other pins at all, other than pin 3 at 18V but fluctuating slightly. Replaced cap C857 again with no change.
#13 |
Follow along with this thread. There are a number of suggestions that you can try.
http://www.badcaps.net/forum/showthread.php?t=20469 |
| Thread Tools | |
| Display Modes | |
