Go Back   Badcaps Forums > Electronics Theory and Troubleshooting > Test Equipment Usage, Techniques, and Reviews
Old 04-15-2012, 01:53 PM   #1
multimeter
City & State: uk
My Country: uk
Line Voltage: 230v 50hz
I'm a: Hobbyist Tech
Default dmm v analogue
advantages of having an analogue multimeter for component testing?
multimeter is offline   Reply With Quote
Old 04-15-2012, 03:25 PM   #2
retiredcaps
City & State: Canada
Default Re: dmm v analogue
Get a digital multimeter that has an analog bar graph to get the best of both worlds. For example, a Fluke 117 updates the digital display 4 times per second and its bar graph updates at 32 times per second. So if you have wild fluctations in voltage you will see it on the bar graph quite easily.
Other brands also have the same bar graph feature.
Having said that, from what I understand the UK loves the old analog AVO multimeters. There is a forum dedicated to vintage test gear (over 17,000 posts) at
http://www.vintage-radio.net/forum/f...splay.php?f=36
If you can get an AVO for really cheap, then I suggest you get one. In the USA, Simpson is the highly regarded analog multimeter.
--- begin sig file ---
--- end sig file ---
Old 05-14-2012, 08:21 PM   #3
Agent24
Fuhjyyu Killer
Agent24's Avatar
City & State: Behind a soldering iron
My Country: New Zealand
Line Voltage: 230V AC 50Hz
Being able to see the rate of change of what you're measuring is what analog is good for.
Agent24 is offline   Reply With Quote
Old 05-17-2012, 03:59 AM   #4
japlytic
japlytic's Avatar
City & State: Rockhampton, Queensland, Australia
My Country: Australia
Line Voltage: 240VAC 50Hz
I'm a: Hobbyist
For speed, analog is the best, and for accuracy, digital is best.
japlytic is offline   Reply With Quote
Old 05-23-2012, 02:24 PM   #5
Kiriakos GR
Kiriakos GR's Avatar
City & State: Volos, Magnisia
My Country: Greece
Line Voltage: 380V three-phase 50Hz
The analog is good for fast changing voltages or mA.
The dirt cheep digital are slow as turtles.
The 300-400$ modern digital ones does have the speed to measure almost anything.
Even so by having at hand plus one high quality analog, you are 100% ready to measure anything.
Kiriakos GR is offline   Reply With Quote
Old 06-04-2012, 04:13 AM   #6
Radio Fox
Radio Fox's Avatar
City & State: East London
My Country: UK
Line Voltage: 230VAC 50Hz
When you want to measure a voltage or current, and the battery has died in your DMM.
________________________________________________
Invisible airwaves crackle with life
Bright antennae bristle with the energy
Radio Fox is offline   Reply With Quote
