Go Back   Badcaps Forums > Electronics Theory and Troubleshooting > Troubleshooting Computer Displays
Old 04-14-2012, 08:52 AM   #1
smalltownguy
City & State: Osceola, WI
My Country: US
Line Voltage: 120VAC 60Hz
Default Dell E228WFPC goes dim after 10 minutes, not 2 seconds
Working on a Dell 22" monitor I purchased from eBay. The monitor stays on for approximately 10 minutes, then goes dim. When it does go dim, cycling the power causes 2 seconds to black behavior. Leave the monitor powered off for a few hours repeats the ability to have it run for 10 minutes, then the issue reappears.
I've checked all the caps on the inverter board (Elite brand) with my blue ESR meter and all of them spec out fine.
I metered the blue caps near the transformers and got similar ohms between the two (secondaries, right?)
I DO have a few spares at work to check for possible CCFL failure, but I really don't want to pull apart another 22" panel that's in constant use unless I absolutely have to. These things are heavy and awkward.
My symptoms are similar to the ones described in this thread:
http://www.badcaps.net/forum/showthr...light=e228wfpc
And, of course, pics:
smalltownguy is offline   Reply With Quote
Old 04-14-2012, 09:04 AM   #2
Jasgriff
City & State: England
My Country: UK
Default Re: Dell E228WFPC goes dim after 10 minutes, not 2 seconds
Just read your problem and the other thread. That's a strange problem.
Its a shame you don't have some spare ccfls to eliminate that. I can't help but think that heat is causing the issue. You could try to leave the monitor off for sometime then slowly heat up an area of the board to see if that bring the symptoms on earlier. This could help determined where the issue might be for you.
Fixed so far : 1 Home cinema system, 16 LCD Monitors, 4 LCD TV's
How to resize your pictures guide click HERE
Retiredcaps Ideal post example click HERE
Jasgriff is offline   Reply With Quote
Old 04-14-2012, 09:27 AM   #3
jetadm123
City & State: California
Sounds like a heat problem/ bad solder joint. Since you have 10 minutes before the problem occurs, may I suggest you try a hair dryer and heat up various portions of the power and logic boards to see if you can accelerate the problem. Hopefully, you'll be able to narrow down the board/area that's giving you the problem.
jetadm123 is offline   Reply With Quote
Old 04-14-2012, 09:32 AM   #4
vinceroger69
City & State: Nuneaton Warwickshire
My Country: uk
I'm a: Hobbyist Tech
have you also checked the esr on the caps between the 2 heatsinks top right of picture?
vinceroger69 is offline   Reply With Quote
Old 04-14-2012, 09:37 AM   #5
smalltownguy
My Country: US
Yes.
Before I try any hair dryer tactics, it would probably be a better idea to place my panel on the boards of a known working donor monitor. If the problem migrates, then I know it's a CCFL issue.
Old 04-14-2012, 09:42 AM   #6
Jasgriff
My Country: UK
You don't have to heat anything up to the extent that u might damage anything just enough yo replicate the fault which normally takes a few minutes.
Old 04-14-2012, 10:53 AM   #7
selldoor
Slow Learner
selldoor's Avatar
City & State: Lancashire UK
Hi if your boards are the same there is a longish thread here:
http://en.community.dell.com/support...px?PageIndex=1
Initially they thought it was a heat problem on the pwm though replacment did not seem to fix. They then added an extra resistor which appeared to work for some but for others was only partial fix as part of screen remained dim. I dont think they bottomed out why the resistor helped but of you were to extract all the relevant bits and could find a schematic for your your board i am sure budm would figure it out. If you could find a voltage regulator that should keep the voltage down to around 2v that is not working then that might be the answer
Does it stay on longer if you turn the brightness down?
selldoor is offline   Reply With Quote
Old 04-14-2012, 11:31 AM   #8
smalltownguy
My Country: US
Hm....I'll have to try that.
Old 04-14-2012, 04:18 PM   #9
retiredcaps
City & State: Canada
Or try the converse. Pump the brightness and contrast to max.
--- begin sig file ---
--- end sig file ---
Old 04-14-2012, 04:29 PM   #10
selldoor
Slow Learner
selldoor's Avatar
"Before I try any hair dryer tactics, it would probably be a better idea to place my panel on the boards of a known working donor monitor. If the problem migrates, then I know it's a CCFL issue."
Sounds good plan to me likewise if you have the panel off a donor try it on
these boards
Old 04-14-2012, 06:21 PM   #11
retiredcaps
See budm's thread on "Inverter tester using old CFL"
http://www.badcaps.net/forum/showthread.php?t=19987
Old 04-17-2012, 09:25 PM   #12
smalltownguy
My Country: US
Update: I brought a sister monitor home today and swapped in the boards from the known good monitor with my panel. I gave it to my wife to work on all day with her design work.
Result: no problems all day.
OK, that's good, at least that means I've narrowed the issue down to the inverter or logic board(s).
So what now? Start stressing my suspect boards with brightness adjustments, or a hair dryer?
Old 04-17-2012, 09:52 PM   #13
jetadm123
A photo of your inverter board would be helpful.
Old 04-17-2012, 09:59 PM   #14
smalltownguy
My Country: US
Eh?
Old 04-17-2012, 10:03 PM   #15
jetadm123
Oops! Been looking at too many Dell boards today. Some of them had separate inverter boards.
Old 04-17-2012, 10:08 PM   #16
budm
budm's Avatar
City & State: S.F. Bay area
Line Voltage: 120V 60Hz
"I metered the blue caps near the transformers and got similar ohms between the two (secondaries, right?)"
So are you able to read the resistance of these two blue ballast caps?
Old 04-17-2012, 10:10 PM   #17
smalltownguy
My Country: US
How do you do that?
I did test all the caps on both boards with my ESR meter.
Old 04-17-2012, 10:14 PM   #18
budm
budm's Avatar
I am just trying to find out if the two ballast caps have leakage resistance when you check them with the Ohm meter.
Old 04-18-2012, 02:20 AM   #19
POM_MJ
POM_MJ's Avatar
City & State: Thailand
Try to replace C806.
I had the same symptom with the same IPboard.
I used hot-air to locate heat affected component then found C806 conduct when it heat, replaced with 0.1uF/50V 0805 running fine for 2 months.
| AMD Phenom II X2 550BE | GIGABYTE GA-MA790FXT-UD5P | GeIL DDR3 Ultra 2x2GB 1600C7 |
| XFX GTS250 DDR3 512MB | Dell H525EF-00 | Lancool PC-K62 Black | Samsung 2232GW |
| 2xWD7500AYYS | 2xHD322GJ Raid0 |
POM_MJ is offline   Reply With Quote
Old 04-18-2012, 06:26 AM   #20
selldoor
Slow Learner
selldoor's Avatar
Cant see C806 is that a ceramic smd on the back?
What voltages do you get on the two black caps in the inverter side of the PS (one is possibly c805)
