Old 04-14-2012, 06:07 AM   #1
dbtsat
City & State: quebec
My Country: canada
Default Flex connector (LCD to Panel Board)
Hi to everybody,
This is my first post...I'm fixing samsung lcd tv(LN-T44661F) the problem is 3 flex connector from lcd to small top panel are totally out or no connection, is any body try to fix this problem? i know its not easy...but i want to fix it just for fun...i have some some tools to do it (Microscope,heatgun...)the only i need is instruction or advice on how to do it.
Thanks in advance for any suggestion or help.
dbtsat
dbtsat is offline   Reply With Quote
Old 04-14-2012, 06:37 AM   #2
selldoor
Slow Learner
City & State: Lancashire UK
Default Re: Flex connector (LCD to Panel Board)
Close up pictures of the cable ends might help us to suggest a repair.
Check that the connectors are not damaged.
selldoor is offline   Reply With Quote
Old 04-14-2012, 08:03 AM   #3
dbtsat
My Country: canada
Thanks a lot for a quick reply...here is a pictures taken from my scrap unit.
thanks again...
Old 04-14-2012, 08:24 AM   #4
cashkennedy
City & State: Baton Rouge, LA
Line Voltage: 110v 60hz
I'm a: Hobbyist Tech
These are applied in the factory with a special conductive glue that only conducts in 1 direction (Anisotropic conductive adhesive). They put a coating across the contacts then lign up the contacts perfectly using a microsocope then the lcd is heated moderately to set the adhesive.
Generally this is not fixable by a normal person.
cashkennedy is offline   Reply With Quote
Old 04-14-2012, 08:35 AM   #5
Jasgriff
City & State: England
My Country: UK
I didn't know that's how they were fitted that's a good bit of info!
I do hear that sell door has microscopic eyeballs maybe you could post it to him and he can sold a tiny cable from each trace :-)
Fixed so far : 1 Home cinema system, 16 LCD Monitors, 4 LCD TV's
How to resize your pictures guide click HERE
Retiredcaps Ideal post example click HERE
Jasgriff is offline   Reply With Quote
Old 04-14-2012, 08:38 AM   #6
dbtsat
My Country: canada
Thank you very much for the info...i will check at work if we have a conductive glue and i will try to fix it ...i have a 10x microscope to use...i will post if i have luck to fix this....just for fun!
Thanks again...
Old 04-14-2012, 10:46 AM   #7
cashkennedy
I have heard a few people claim to fix the flex cables on simpler devices like cheap monitors and old cell phones, but I think its increasingly hard on 1080p televisions. Theres a video of indian kid on youtube showing how to fix lines on a LG tv i think that might involve reinforcing the glue on the flex cable, i never watched the whole video though cause it was long.
I dont buy / or have any lcd's with those sorts of issues, but if i had one id probably try resetting it with a hot air gun, assuming you didnt clean off the adhesive residue from the tab and surface it bonds to.
