Go Back   Badcaps Forums > General Topics > General Computer Discussion
Old 03-16-2012, 07:57 PM   #21
ratdude747
ratdude747's Avatar
City & State: New Albany, IN
Line Voltage: 120VAC 60Hz
I'm a: Student Tech
Send a message via Yahoo to ratdude747 Send a message via Skype™ to ratdude747
Default Re: Ratdude's Main rig V2
Originally Posted by Uranium-235 View Post
oh hey rat didn't you say you had an old 3dfx card? If you're looking to do a 3dfx upgrade (instead of nvidia or ati) I have a Voodoo 5 5500. works too
it is a new in box (still in shrink wrap) voodoo 3 2000 16mb PCI card.
I was lookign for somethign with more power than a voodoo 5... remember that my board has AGP (pro) 8x...
(Insert signature here)
ratdude747 is offline   Reply With Quote
Old 03-18-2012, 08:12 PM   #22
ratdude747
ratdude747's Avatar
I'm a: Student Tech
UPDATES:
1. I got the coolers home... And I swapped the fans:
One of the old fans:
The new fans:
I am swapping the fans because I needed longer cables and the existing fans are too loud for desktop use. I did do a test with an old fan and a new fan powered up... the airflow was not that much different but the noise was considerably less.
2. I also spun up the case fan for the system and found it to louder than I thought. I decided to undervolt the fan by using resistors... I calculated that the fan itself is about 60 ohms (12V / .2A) and that 3 1/2W 100 ohm resistors in parallel woulf create a 33.3 ohm resitor and would be a good choice. I went ahead and made the mod... the good news is that the fan went from 2500RPM (full blast) to 1800 RPM (about right). The bad news is that the resistors get hotter than I anticipated... after doing the math, I am putting them at just over 1/2W per resistor... Oops!
I guess I will want to look for a quiter fan by design or perhaps a temp controlled fan (like the ones in Dell towers, only with a usable tach output). Anybody have suggestions?
3. I will be getting another ECC DDR 512mb stick soon, which means I can run 2gb of RAM...
4. I also will be getting an ATI Radeon 9800 Pro 256MB for the system...
Old 03-18-2012, 08:21 PM   #23
shovenose
404 Not Found
shovenose's Avatar
City & State: Fairfax, California
I'm a: Forum Junkie
Wouldn't somethign like this work?
http://www.newegg.com/Product/Produc...82E16811995073
Firefox is named after a fox - WRONG! That orange thing is a Red Panda, not a fox!!
http://www.youtube.com/watch?v=y6GaPkkGZGw
PSU Pr0n
http://www.psudatabase.com/
shovenose is offline   Reply With Quote
Old 03-18-2012, 08:31 PM   #24
ratdude747
ratdude747's Avatar
I'm a: Student Tech
Originally Posted by shovenose View Post
Perhaps... I was looking for a more "streamlined" approach... The temp controlled fan idea sounds appealing, if such non-dell fan exists...
Old 03-18-2012, 08:38 PM   #25
c_hegge
Unknown
c_hegge's Avatar
My Country: Australia
Line Voltage: 240V 50Hz
Arctic cooling make them, although it doesn't look like RottenEgg have them. They only have the PWM ones.
I have used the temp controlled ones before, and the noise/airflow ratio seems very good.
Main PC: Core i5 660 3.33GHz, Gigabyte GA-P55-UD3R, 4GB Kingston DDR3 1333, 750GB WD HDD, Sony Optiarc DVD RW, nVidia GTX295 1760MB, Antec 1200 Case, Delta DPS-750CB 750W PSU, Hauppauge TV Tuner, Windows XP Pro.
Main Laptop: Lenovo Thinkpad T60: Core 2 T2500 2GHz, 2GB DDR2, 80GB HDD, DVD RW, Intel Graphics, Windows XP Pro.
2nd Laptop: Toshiba Satellite A200: Core Duo 1.73GHz, 2GB DDR2, 60GB HDD, DVD RW, nVidia GF Go 7300 Graphics, OpenSUSE 12.2, Fan Mod
c_hegge is offline   Reply With Quote
Old 03-18-2012, 08:43 PM   #26
ratdude747
ratdude747's Avatar
I'm a: Student Tech
I wonder if there is a way to use the sensor output of a dell fan as a tach wire... I have a dell fan that I swapped the connector on... but the signal output apparently is not a standard tach output...it reads 0RPM.
Old 03-18-2012, 08:56 PM   #27
c_hegge
Unknown
c_hegge's Avatar
No, because Hell have a different tachometer signal to normal fans. AFIK, there is no way of reading the Tach signal without modding the fan, but I don't usually go there when I can get Arctic cooling Temperature controlled fas for <$10 ( http://www.ebay.com/itm/Arctic-Cooli...item4cebdf92e5 )
Old 03-19-2012, 08:34 PM   #28
ratdude747
ratdude747's Avatar
I'm a: Student Tech
that would have worked if my case used a tradtional fan mount... instead it uses clips (the fan has to be standard dimensions to work):
Old 03-19-2012, 08:52 PM   #29
ratdude747
ratdude747's Avatar
I'm a: Student Tech
What about this?
http://www.newegg.com/Product/Produc...82E16811999617
or, this?
http://www.newegg.com/Product/Produc...82E16811999603
Old 03-20-2012, 12:44 AM   #30
ratdude747
ratdude747's Avatar
I'm a: Student Tech
some cheaper options for a quiet fan that I found:
http://www.ebay.com/itm/282317-003-3...#ht_500wt_1129
the vantec again (I have the 80mm version btw, its a winner)
http://www.ebay.com/itm/Vantec-SF922...#ht_4268wt_907
either of these two look good?
Old 03-20-2012, 01:03 AM   #31
Uranium-235
Radioactive
Uranium-235's Avatar
City & State: tehas
My Country: US
I just realized, I'll probably be using all of the money from the parts i'm selling to buy the same two coolers you bought
Uranium-235 is offline   Reply With Quote
Old 03-20-2012, 01:29 AM   #32
c_hegge
Unknown
c_hegge's Avatar
None of those four fans are all that quiet at all. I've used thos 'stealth' vantecs before ad they are quite noisy. At 29dB at low speed, that thermoflow ain't quiet either. You're looking for 18dB or under. Here in Aus, we have Arctic cooling temperature controlled fans which are standard dimensions.
If you want really good noise/airflow, then you can't beat Noctua, but they are a tad expensive.
try http://www.newegg.com/Product/Produc...82E16835226039
Old 03-20-2012, 01:47 AM   #33
ratdude747
ratdude747's Avatar
I'm a: Student Tech
I see... I may go that route then...
edit- found them cheaper ($10 shipped) http://www.microbarn.com/details.aspx?rid=103024
Old 03-20-2012, 09:15 PM   #34
ratdude747
ratdude747's Avatar
I'm a: Student Tech
updates:
the board came in today... and I found out that the coolers did not fit... the scews are the wrong thread and the brass studs are too long.
I was able to mod the coolers though:
1. I removed the exisisting springs and scews from the coolers. I then used a hammer, pin punch, and a vise to hammer out the brass studs. I slipped and gave myself a blood blister (ouch).
2. I went to the local hardware store and bought some m3 x22 screws (x8) and some #6 washers (x8).
3. I installed the coolers using the screws; the washers keep the scre heads from slippign through the holes in the cooler. I used the amount of unused thread in the bottom of the backplates as a guide to get the cooler flush with the CPU.
Other notes (after system build):
- the 3ware card didn't like my hdd... my guess is that it has to do with raid and it beign a caviar blue... either that, or the card doesn't like single drives. I moved the hdd to port 3 of the onboard SATA.
- for now, I am usign ATI radeon X1300 256mb from my shuttle box untilt he 9800 pro 256mb comes in... question: which card is a better performer, the x1300 or the 9800 pro?
-I got it booted and got F@H running... 4 virtual cores of it (2 CPUs with HT).
-so far, the cpu temps are about 50-52c (internal CPU readout, mobo sensors say 47-47.5). Not bad, right (for 3.2GHZ gallatins)?
Old 03-20-2012, 09:24 PM   #35
Topcat
The Boss Stooge
Topcat's Avatar
City & State: Salem, MO
My Country: United States
Send a message via ICQ to Topcat Send a message via AIM to Topcat
pictures...............jeez!
<--- Badcaps.net Owner & Forum Administrator!!
Badcaps.net Services:
Premade Capacitor Kits
Badcaps.net Capacitor Master List
Motherboard Repair Services
If you've come here in search of replacement capacitors or repair services, please use the links above.
http://folding.stanford.edu/
Team : 49813
Join in!!
Team Stats
Topcat is offline   Reply With Quote
Old 03-20-2012, 09:34 PM   #36
ratdude747
ratdude747's Avatar
I'm a: Student Tech
of what?
(they will come... soon...)
Old 03-20-2012, 10:10 PM   #37
ratdude747
ratdude747's Avatar
I'm a: Student Tech
Here are the few I have:
the board before I installed it into the computer:
close-up of the hacked cooler mounting:
Old 03-20-2012, 10:15 PM   #38
Topcat
The Boss Stooge
Topcat's Avatar
Very nice! I got close to a decade of 100% rock solid service out of that board! In all that time, it was running 24/7. I only shut it down when it became clogged with dust bunnies and needed a blowjob from the air compressor
Old 03-20-2012, 10:47 PM   #39
ratdude747
ratdude747's Avatar
I'm a: Student Tech
I thought you sent me the NOS one?
(I am happy either way)
some notes:
- it is LOUD... the fan swap helped but even with a dell temp controlled fan, it is kinda noisy... trade off I guess
- for some reason the two SATA DVD+RWs have to be set after the hdd in the boot list for the hdd to boot... the SATA controller must not like optical drives (it treats them like hdds, resulting in a no boot.
some pics:
overall:
Yes, it is a bit cramped.
The cooler area:
the cards (note the gap where the 3ware card used to live)
the back:
Look good?
Old 03-20-2012, 10:54 PM   #40
momaka
momaka's Avatar
City & State: VA
My Country: U.S.A.
Line Voltage: 120 VAC, 60 Hz
I'm a: Student Tech
Are there supporting backplates behind the CPUs on the board? Are they thick and sturdy?
- If not, your heatsink bolt mod can seriously warp the board over time. At the place I work, we get Xbox 360s all the time, and when people usually apply a similar heatsink bolt mod, the damage is usually worse than from the original X-clamps.
Then again, the Xbox 360s also run a bit hotter than your CPUs, so that contributes to the damage a lot more.
As for the fans being too loud - maybe you can run them at 7V (red wire to 12V, black wire to 5V) or 8.7V (red to 12V and black to 3.3V
Look good?
Yes.
