Go Back   Badcaps Forums > Electronics Theory and Troubleshooting > Troubleshooting Laptops, Portable, and Mobile Devices
Old 02-27-2012, 10:33 PM   #1
sebuncle
City & State: Isère
My Country: France
Default Sony vaio VPC-EB mbx223/ no start,no power no led
hi ,
motherboard M960 rev1.1 mbx223
doesn't start , no led , no power , no charge.
I check on power button 3v are no present
19v is present on PF1 and PL1.
19v is present on PQ2 but only on pin 1 to 4 , on pins 4 to 8 there's 0v (i change PQ2 it's the same)
i check SN608098:
no voltage on pin 3 and 6
i check BQ24753A:
PVCC have 19v
Can you tell me where i have to check
i don't have schématic
thank you
JOVY RE7500
sebuncle is offline   Reply With Quote
Old 09-16-2012, 02:58 PM   #2
lat123
City & State: Toronto, Ontario
My Country: Canada
Default Re: Sony vaio VPC-EB mbx223/ no start,no power no led
I had the same problem and I was able to fix it by grounding pin 4 (In your picture it is the top left pin) directly. Initially I measured 19.4V at that pin but the IC does not function unless it is grounded and the other three pins are at 19.4V. Hope that helps solve your problem.
lat123 is offline   Reply With Quote
Old 09-17-2012, 04:21 AM   #3
fabiog
Have a similar problem with another Sony ,how do you ground that pin?
fabiog is offline   Reply With Quote
Old 05-19-2013, 07:06 AM   #4
shoesforsale209
City & State: California
My Country: United States
can you describe pin 4 in more detail. Are you talking about the first ground wire (according to the pic) from the power jack. I interested in this repair because I have a MBX223 motherboard no longer showing any signs of life after three months of usage. I change the power jack and the power board, but still nothing. I've attempted to try your grounding method, but i was unsuccessful at it as i'm not sure if i'm grounding the correct pin. What is pin 4?
shoesforsale209 is offline   Reply With Quote
Old 05-19-2013, 07:48 AM   #5
Tuomo
City & State: Sievi
My Country: Finland
Originally Posted by sebuncle View Post
hi ,
thank you
Measure PU3 PIN5 ACDET.
This detect if AC Power is inserted.
Measure PU3 PIN4 ACDRV# should be LOW.
Tuomo is offline   Reply With Quote
Old 05-19-2013, 09:05 AM   #6
shoesforsale209
I found the problem. The PU3 (BQ24753ARHDR) (NS982402) is not functioning at all because i'm not getting a reading. I checked pin 5 (ACDET) and Pin4 (ACDRV) nothing. I have 19.4v from PF1 and PL1. I assuming the PU3 is dead should I replace it?
Old 05-19-2013, 10:17 AM   #7
Tuomo
City & State: Sievi
My Country: Finland
Not yet, first check PR13 and PR14.
Then measure PQ1 voltages.
Old 06-20-2014, 12:01 PM   #8
aimiliano
City & State: athens
My Country: Greece
i have the same motherboard but with slightly different problem.. it starts but it doesn't give the vga voltage
aimiliano is offline   Reply With Quote
Old 03-04-2015, 01:58 PM   #9
OHENABA
City & State: ACCRA
My Country: GHANA
Line Voltage: 220VAC
Hi, i have similar sony mbx223...will like to know if any have the solution or can help...19v is present on PQ2 but only on pin 1 to 4 , on pins 4 to 8 there's 0v. PQ2 was changed but still.
OHENABA is offline   Reply With Quote
Old 04-02-2015, 11:38 AM   #10
Blacktek
Blacktek's Avatar
City & State: Houston
Question Re: Sony vaio VPC-EB mbx223/ no start,no power no led
i have the exact same issue on my mbx-224. On PQ1 im getting approx. 19v on all 8 pins and on PQ2 i get same voltage on pins 1-4. PR13 and PR14 tested ok, i have their right values but PR14 i get 19v on one en and 0.5v on the other end, which is why i get 0.5v on pin 5(ACDET) on PU3. Ping 4(ACDRV#) i get 18.7v.
Any help, clues or ideas would be appreciated.
Blacktek is offline   Reply With Quote
Old 04-02-2015, 12:08 PM   #11
Blacktek
Blacktek's Avatar
When i remove PU3 i get 2.7v on pin 5, still nothing on PQ2 draining pins.
thankx
Old 04-03-2015, 04:46 AM   #12
tata123
City & State: Germany
My Country: Germany
I had the same Problem but with MBX-224 but its the same structure check the PQ1,PQ2, and the most important the are the Capacitators PC168 and PC169.
I have upload a picture witch you can find the parts.
The failure is NO LEDS NO START NOTHING!!
tata123 is offline   Reply With Quote
Old 04-03-2015, 11:29 AM   #13
Blacktek
Blacktek's Avatar
Thanks for the input buddy! but those 2 caps are ok,but i found that something is shorted to ground in the line of PL18(+1_05V_VTT), i removed all PC206,PC208 and PC212 but still same thing, even with PU16 removed i still have the short. Also PQ2 and PQ1 seem to be ok, except that im able to switch them on/off while in circuit...is that normal??
Old 04-03-2015, 02:30 PM   #14
tata123
My Country: Germany
unsolder the PQ CHIPS AO4433 and check it up!!
Dont unsolder the BQ QFN CHIPS if there is higher voltage...
Old 04-05-2015, 11:46 PM   #15
maestro_lpc
City & State: Tbilisi
My Country: Georgia
Try bios reset. Remove rtc battery and short 2 pins. Or there are bad short ceramic capasitor in out tranzistor 19v.
maestro_lpc is offline   Reply With Quote
Old 04-11-2015, 12:59 PM   #16
Blacktek
Blacktek's Avatar
Thanks Maestro_Lpc .. Tried that but no luck. all caps around pq2 are giving the right values when removed from the board. Can you think of anything else i can try?
Old 01-29-2016, 12:08 AM   #17
bicalov
City & State: Eindhoven
My Country: Netherlands
Line Voltage: 220V 50Hz
How this story ended? I have the same issue and I would like to know.
bicalov is offline   Reply With Quote
Old 10-31-2016, 04:05 PM   #18
neky
City & State: Split
My Country: Croatia
Line Voltage: 220VAC 50Hz
aimiliano , flash bios ,should solve your problem
neky is offline   Reply With Quote
Old 04-03-2017, 09:17 AM   #19
ravi_1617
YY Solutions
City & State: JASHEDPUR,JHARKHAND
My Country: India
Line Voltage: 230 a/c
Same board mbx223,board starts and off. Again on by itself. Cycle. On and off., actually it's accident case. Lan coil L70.and Web cam connter pulled off when slipped from hand. Screen part also came of.
ravi_1617 is offline   Reply With Quote
Old 04-03-2017, 11:43 PM   #20
mcplslg123
City & State: siliguri
My Country: india
Just jumper pin1 to pin5 of pq2 and power the mb. if you get 3.3v on battery connectors probably it will work. Wont charge battery though. Very common fault with mbx223/224 mb.
you should make jumper with very thin cable so that it should blow off if there is some short in the mb. If it blows off then look for 19v line. there must be short. usually capacitor goes short near cpu socket where 4-5 mosfets are located.
Hope it helps
mcplslg123 is offline   Reply With Quote
Badcaps.net Technical Forums © 2003 - 2017
