#1 |
City & State: Turku
My Country: Finland
Line Voltage: 230VAC 50Hz
I'm a: Student Tech
Victim/patient in question is a 23" FullHD display sporting a LG-Philips LM230WF1-TLA1 panel, dual HDMI and one VGA input. The previous owner simply said there's no picture, which leads to CCFL-problems first.
Interestingly, the power supply board is the same as used on Hannspree HF237HPB - and has faulty caps (SamXon - bulged, Lelon, Su'scon) - for which I've already purchased replacements (Hitano EXR) and intend to replace as soon as I can get my troubles with Weller sorted out... Here are the questions though:
#2 |
City & State: Canada
Yes.
--- begin sig file --- If you are new to this forum, we can help a lot more if you please post clear focused pictures (max resolution 2000x2000 and 2MB) of your boards using the manage attachments button so they are hosted here. Information and picture clarity compositions should look like this post. We respectfully ask that you make some time and effort to read some of the guides available for basic troubleshooting. After you have read through them, then ask clarification questions or report your findings. Please do not post inline and offsite as they slow down the loading of pages. --- end sig file --- |
#3 |
City & State: Turku
My Country: Finland
I'm a: Student Tech
to continue problem #1: the cable shown attached to the PSU board has no connector on other end, just bare crimped ends - are these connected to the driver board in the same order as they are on the PSU?
#4 | |
City & State: Phoenix, AZ
Line Voltage: 120VAC 60Hz
I'm a: Hobbyist
PlainBill
For a number of reasons, both health and personal, I will no longer be active on this board. Any PMs asking for assistance will be ignored. Never be afraid to try something new. Remember, amateurs built the ark. Professionals built the Titanic. |
#5 |
City & State: Turku
My Country: Finland
I'm a: Student Tech
Thanks for the pointers - need to fire that multimeter up later tonight
#6 |
o.O
City & State: Duisburg
My Country: Germany
Sounds like the previous owner has some explaining to do. He probably ripped the crimped connectors out of the plastic part of the plug and lost the plastic part (i.e. he's been in there before, most likely not telling you about it)
#7 |
City & State: Turku
My Country: Finland
I'm a: Student Tech
He sais he'd opened it, but when I asked about the said connector he had no recollection there being a connector - but then again, I'll be measuring stuff tonight
#8 |
o.O
My Country: Germany
Having the crimped connectors loosely sitting in there would make it ridiculously easy to short out. I highly doubt it came like that from the factory.
If you're lucky, the backside of the controller board might have some indications as to which pin is what (like the PSU board above the connector in the pic in post #1) |
#9 |
City & State: Turku
My Country: Finland
I'm a: Student Tech
Well, took a bit time, but the grounds line up on controller board the same way as on power supply - so do 5V's. Now I just need proper connector housing...
#10 |
City & State: Turku
My Country: Finland
I'm a: Student Tech
Found suitable connector from some oldish 4:3 BenQ-tft - although it's a bit too wide, being 12-pole instead of 10-pole, so I'll need to cut it a bit...
#11 |
City & State: Turku
My Country: Finland
I'm a: Student Tech
Time to bring this up again
#12 |
City & State: England
My Country: UK
I am not massively sure that I am on the right track here but I think it makes a noise when there is not enough power to drive it?
You could try testing the main filter cap and see what voltage you have running across that to see if its right or not. |
#13 |
City & State: Turku
My Country: Finland
I'm a: Student Tech
If you mean by main filter cap that huge one, it had some 300+ volts over it.
#14 |
City & State: University of Leeds (MEng ElecEng undergrad)
My Country: UK
Line Voltage: 230Vac 50Hz
I'm a: Student Tech
Startup cap or bad diode on secondary.
** Begin Signature ** I fix TVs and electronics as a hobby and to save nice things from the dump. 40 LCD TVs, 4 monitors, 13 plasma TVs, and a 6.1 system! Free service manuals database: http://www.tgohome.com/ServiceManuals - Have a manual? Need a manual? Please PM me. I have successfully fixed (from best --> worst build quality): 3 Panasonic Plasmas, 1 Yamaha HTS, 1 NEC Plasma, 2 Sharp LCDs, 2 Toshiba LCDs, 5 Philips Plasma/LCD, 1 Hitachi Plasma, 5 LG LCD/Plasma, 10 Samsung LCD/Plasma, 1 Thomson Plasma, 1 Atec LCD, 1 Hanspree LCD, 1 Xerox LCD, 1 Harwa LCD, 2 Proview LCD, 2 Hyundai LCD, 1 "Onn" LCD, 1 Dell LCD, 1 iiyama LCD, 1 Logik LCD, 5 Bush LCD, 10 Vestel LCDs [Please do not PM me for help: I am a busy student, and we prefer input from all sides on this forum.] |
#15 |
City & State: Turku
My Country: Finland
I'm a: Student Tech
D806 is SRF 10-20 and D807 is SRF 10-10 - how would I measure them? Or rather, what readings they should give without power...
#16 |
My Country: UK
You need to put your meter on the ohm setting and read then both ways around. Make sure its done with the power off.
You should have a low reading then a high one. If you get 2 very low or very high readings then they have gone. Let us know your readings. |
#17 |
City & State: Turku
My Country: Finland
I'm a: Student Tech
Here are some measurements I've already done:
D2: 0,547 V D4: 0,546 V D8: 0,545 V D9: 0,549 V ZD801: 0,645 V D802: 0,474 V D803: 0,442 V These were measured with meter set to diode. D806: ground in the middle, readings 0,337 V left and right (ohms:3,847k right, up to 23k left - stabilizes around 17,5k) D807: ground in the middle, readings 0,248 V left and right (ohms: 1,927k right, up to 23k left - stabilizes around 18,5k) Will measure the DC across the big cap later - my kid is still awake... Last edited by DMCrimson; 04-21-2012 at 11:04 AM.. |
#18 |
To test a diode using the diode test function, you must take 2 readings on the same diode. One reading is with the probes one way and the second reading is with the probes reversed.
A good diode should read between 0.3 to 0.8V and "out of range" the other way. |
#19 |
City & State: Turku
My Country: Finland
I'm a: Student Tech
Have yet to measure them the wrong way round - they do look proper the right way
#20 |
City & State: Turku
My Country: Finland
I'm a: Student Tech
Indeed - there were 4 faulty ones:
D2: 0,766 V D4: 0,767 V D8: 0,767 V D9: 0,766 V Going to replace them tomorrow. I think I have a hundred of those (1N4148) stashed or so Last edited by DMCrimson; 04-21-2012 at 01:59 PM.. |
| Thread Tools | |
| Display Modes | |
