Hello this is my first post on BadCaps but not my first visit. About 2 months ago i would go to power on my tv it would stay on for seconds then turn off, (red led turn to green back to flashing then solid red and was also squealing before this occurred) searched and found this site to help me with the bad caps on power board. The bad caps were 3 capXon 1500uF35v c951, c952, c953 and capXon 2200uF16v c955. I replaced them with the panasonic equals from thread "Philips LCD 42PFL5432D/37 - Bad PSU"
http://search.digikey.com/scripts/Dk...name=P12409-ND
Ordered, soldered and tv started right up. the other day i was watching and whole tv powered down and there was no led red nor green so i opened it up there were no bloated caps on power board or burn marks. So I opened the scaler board case, which i didn't do last time, and found c218, c812, and c807 all capXon 1000uF25v bloated spewing black gunk, c113 capXon 220uF25v, c131 capXon 470 uF25v bloated as well. c830 is same as c113 but not bloated but also replaced.
Here is where i may have messed up instead of coming here i got on digikey and searched here is what i ordered
3 of http://search.digikey.com/scripts/Dk...ords=P11223-ND
1 of http://search.digikey.com/scripts/Dk...ords=P10275-ND
2 of http://search.digikey.com/scripts/Dk...ords=P12383-ND
they are all bigger than the original ones that need replacing. i did order
these all 3000hr at temp instead of 2000. Thinking that it was just the lifetime of the part that made it bigger i installed them connected everything and plugged it in, nothing changed. so i checked the fuse http://search.digikey.com/us/en/prod...2666-ND/777438 and it is bad. My questions are, did i order and install wrong parts causing the fuse to go bad? Are the parts good parts and fuse just went out? If that what caused the fuse to go bad in the first place? i was in the middle of a show when tv went off, no power out, or surge just, off. sorry no camera now but trying. Pictures on https://www.badcaps.net/forum/showth...2PFL5432D%2F37 seem identical. checked inverter boards and they don't have bloated caps. i don't know what else to look for but i went to the local electronic shop took the power board to see if they had any fuses asked him if anything else looked bad to him and he said no that everything looked fine to him but the fuse was definitely bad and he didn't have none. Here now with my order on hold thinking that i might need more parts. Can any body help me? Here is the type of multimeter i have just in case. Velleman Dvm-850Bl 3 1/2 DMM 10A Digital Multimeter
