Go Back   Badcaps Forums > General Topics > Network Design & Troubleshooting
Old 02-23-2012, 08:31 PM   #21
Uranium-235
Radioactive
Uranium-235's Avatar
City & State: tehas
My Country: US
Line Voltage: 120VAC 60Hz
Default Re: Fans in old 1U equipment
my dad gave me a little oil pen with some air condition fan oil he put in there from a 20 year old container. Works great, no mess
Uranium-235 is offline   Reply With Quote
Old 02-27-2012, 06:27 PM   #22
momaka
momaka's Avatar
City & State: VA
My Country: U.S.A.
Line Voltage: 120 VAC, 60 Hz
I'm a: Student Tech
[quotc_hegge]Re-lubed fans don't usually last longer than a couple of weeks before they get noisy again.[/quote]
That's because most people just do it the lazy way - remove plug and add lubricant. This is indeed only a temporary fix. What you really need to do is fully take the fan apart if you actually want it to work right in the long term. And by take apart, I mean take off the retaining/locking washer from the shaft and then remove the the blade assembly (the rotor).
For dual ball bearing fans, just soak the bearings in oil and let them absorb it. That's it.
For fans with a sleeve bearing (and also fans with a single ball-bearing), there's more that needs to be done - the shaft and the bearing must be cleaned thoroughly.
Normally what I do is I wipe the shaft with alcohol using a small piece of paper towel. Then I rip that piece of paper towel into small pieces and insert them into the sleeve bearing after which I use a small screw driver to push them out. After this, I put the fan blade assembly back in the housing and move it in and out while also applying side pressure on it in different directions. The rubbing of the shaft and sleeve bearing is what does all of the cleaning. After this, I take out the blade assembly out again, and clean the shaft and bearing with alcohol one more time. If the fan blades are still hard to turn or make grinding noises, repeat above procedures until they turn freely. Finally, add oil or lithium grease (DO NOT use regular grease for this) and assemble the fan again.
By the way, I just fixed 2 fans like this a few days ago. First one was a 120mm cheap Raidmax fan that was almost completely stuck. The other was a noisy (heavy grinding) 60mm single ball bearing fan (ball bearing on the front, sleeve bearing on the back) from one of those all-in-one kiosk computers (the ones with a touch screen). Both fans run whisper quiet now.
Old 02-27-2012, 06:35 PM   #23
c_hegge
Unknown
c_hegge's Avatar
My Country: Australia
Line Voltage: 240V 50Hz
It can also be that the shaft (or bearings) wears down. If this happens, no amount of oil will put back the worn steel or brass.
Main PC: Core i5 660 3.33GHz, Gigabyte GA-P55-UD3R, 4GB Kingston DDR3 1333, 750GB WD HDD, Sony Optiarc DVD RW, nVidia GTX295 1760MB, Antec 1200 Case, Delta DPS-750CB 750W PSU, Hauppauge TV Tuner, Windows XP Pro.
Main Laptop: Lenovo Thinkpad T60: Core 2 T2500 2GHz, 2GB DDR2, 80GB HDD, DVD RW, Intel Graphics, Windows XP Pro.
2nd Laptop: Toshiba Satellite A200: Core Duo 1.73GHz, 2GB DDR2, 60GB HDD, DVD RW, nVidia GF Go 7300 Graphics, OpenSUSE 12.2, Fan Mod
c_hegge is offline   Reply With Quote
Old 02-28-2012, 02:07 AM   #24
b700029
Banned
Fans usually won't wear their bearings to that extent, because with just a little dryness they'll seize. Different from something like an engine where there's a huge amount of power that can grind away the metal really quickly.
Originally Posted by shovenose
I could have got them for about $1 each, lubed the fans,
and had some REALLY NICE 10/100 switches.
With any luck they might end up here: http://badcaps.net/forum/showthread.php?t=6356
b700029 is offline   Reply With Quote
