Go Back   Badcaps Forums > Electronics Theory and Troubleshooting > Troubleshooting Laptops, Portable, and Mobile Devices
Old 02-11-2012, 12:48 PM   #1
Timelapse
Default Toshiba Satellite c650 no power to battery and no motherboard lights
Hi Guys, I'm new to this forum and have stumbled across it while in search to a possible solution to a problem I have with a Toshiba C650.
One evening it was working... I shut it down and went to bed, next morning a new dvd drive arrived so I removed the screw, removed the drive and replaced it. I thought I have it fully pushed it but hadn't and while attempting to do the screw up the screw has fallen and my screwdriver has gone through the hole and hit the motherboard.
There is some damage to a ceramic capacitor (seen of pic 3) c6210
Since then - nothing. no lights on the laptop at all, either with ac in or out.(same with battery)
I have opened the laptop up and over the past few days been running a multimeter across the board trying to see where about the power stops.
I can follow the 19v's to a point but then nothing. Thing is I'm not sure exactly what should be giving me 19v and what shouldn't. I do know that both fuses are OK and the battery terminals are not giving out any voltage.
I'm new to fiddling with motherboards and have accepted that this laptop is OK to be bin'd but I feel it's such a waste of a laptop if the faulty component can be identified and replaced. May6be not by me but If I can identify the problem then it was save somebody who can do the solder work the troubleshooting.
Anyway, thanks in advance for any help & advice
Paolo
Timelapse is offline   Reply With Quote
Old 02-11-2012, 06:50 PM   #2
b700029
Banned
Default Re: Toshiba Satellite c650 no power to battery and no motherboard lights
Obviously the damaged capacitor is the problem. It's actually C6208 (C6210 is not populated). The part number designations suggest OEM is Inventec. I haven't been able to find the schematic for your model, but from the L500's schematic (also built by Inventec) they use a TI TPS51125 there, which looks like the same chip you have as U6200. If that's the case you can use the reference design on TI's website to figure out what value of cap should go there.
b700029 is offline   Reply With Quote
Old 02-11-2012, 11:57 PM   #3
Timelapse
Hello, thanks for the reply. Exactly what I was looking for so cheers.
With regards to the battery pins showing no reading do you think there could be damage elseshere also?
I can follow the tracks up to q6002 (pic 2) and only have 19v on one side of this. The other side has nothing, as does the next chip in the chain. Does this mean something?
Old 02-12-2012, 06:26 PM   #4
b700029
Banned
Replace the broken cap first, then continue to troubleshoot...
And do get the L500's schematic as a reference (although not exact), since it uses much the same circuitry.
Old 02-13-2012, 12:58 PM   #5
Timelapse
Thanks again. I'll keep you posted
Old 02-15-2012, 03:19 PM   #6
imateski
OK, I dont have experience with the C650, but just a few remarks about your testing. Remember that capacitors don't conduct DC, so many times you'll find a 19V readout on one pin, and 0V on the other pin of the capacitor. That's how it should work. Usually their job is to just filter out any current noise.
The capacitor does seem damaged, but I doubt a single capacitor would kill the laptop, knowing they're mostly current filters. Definitely replace the capacitor is a first step, and if nothing happens, I'd go with a reflow of the small chip next to it. Maybe that screwdriver impact was enough to cause a cold solder on one of the chip pins.
my2 cents, hope it helps
imateski is offline   Reply With Quote
Old 02-15-2012, 06:14 PM   #7
b700029
Banned
If that's a TPS51125 then that is the VIN pin and the damaged capacitor is for decoupling - the IC might not work without it, or work erratically enough to not produce the correct voltage.
You may want to consult the reference design for the TPS51125 (http://www.ti.com/lit/ds/symlink/tps51125.pdf ) and ensure that the 3.3v and 5v outputs are at the correct voltage, as well as the input voltage (5-28V according to the datasheet, probably 19V in your case.)
Old 03-12-2012, 09:05 PM   #8
freak1981
City & State: vic
My Country: australia
Hi Timelapse.
I too have the same issue with my laptop, no lights and does not power on when either the battery or ac is connected.
Did you get anywhere with your problem?
freak1981 is offline   Reply With Quote
Old 03-18-2012, 04:40 AM   #9
siddique
City & State: kerala
My Country: india
my Toshiba l300 in processor connecting time in the near regulator chip overheating
siddique is offline   Reply With Quote
Old 01-14-2013, 09:45 PM   #10
teletwanger
teletwanger's Avatar
City & State: Victoria, BC
My Country: Canada
Hey boys....my situation is classic. I was on the phone to a Toshiba tech to kill the power on password that my brilliant son created after smoking pot with his friends. He couldn't remember it right after doing it. So...it was 2 days past warranty. Toshiba "tech" walked me thru shorting several pads...until...he realized he was looking at the wrong motherboard!!! He then apologized and said he wasn't gonna help any further. I tried to talk him into replacing my board. He quickly ended the call. What a jerk!!!
So I have no power, no leds, no action. Where should I start, other than following the dc in? Any and all help much appreciated.
Last edited by teletwanger; 01-14-2013 at 10:11 PM.. Reason: started my own thread...tried to delete this reply.
teletwanger is offline   Reply With Quote
Old 06-16-2015, 10:12 AM   #11
floriano.bazzanini
City & State: italia
My Country: italia
hello have you solved this problem?
floriano.bazzanini is offline   Reply With Quote
Old 06-16-2015, 10:48 AM   #12
dj_ricoh
dj_ricoh's Avatar
City & State: London
My Country: uk
change U600 max17435 and your good to go.
before post the voltage from that IC
dj_ricoh is offline   Reply With Quote
Old 11-02-2015, 05:36 AM   #13
jitendra kumar sharma
City & State: rajasthan
My Country: india
toshiba leptop c650 no display
jitendra kumar sharma is offline   Reply With Quote
Old 11-02-2015, 06:06 AM   #14
My Country: india
hy
