#1 |
I'm new to this forum, and new to TV repair so bear with me. I've fixed a few with bad caps, but this one is more involved.
It's a Dynex DX-LCD32. It's not the one with the "-09" either. That one looks different inside. I picked this one up cheap because it doesn't power on. The guy did say that it would work every now and then, but I haven't seen it yet. I plug it in, and get the orange stand-by light. Press power and the light turns to a solid green. No picture or any sounds. To get it back to stand by mode, I have to press power twice, and get orange flashes. It's really quick, and I tried to count. I either got 9 flashes, or a few times it does abut 15, then stays a solid orange. I've looked at every capacitor and none are bulging. I have a digital multimeter, and am ready to check whatever that you tell me. Keep in mind that I have very little knowlege of electronics but am willing to learn. I've enclosed some photos of the boards. Thanks for any help that you guys can give me. I'm not looking to get into the business, just trying to get a decent TV for the garage. Michael |
#2 |
City & State: University of Leeds (MEng ElecEng undergrad)
My Country: UK
Line Voltage: 230Vac 50Hz
I'm a: Student Tech
Are there any markings on the cable going from the PSU to the main board?
If so, check the voltages on the pins match these markings. I notice one Rubycon cap and a few Chemicons - did you replace these or did someone else? (Or are they factory originals?? That would be very surprising...)
** Begin Signature ** I fix TVs and electronics as a hobby and to save nice things from the dump. 40 LCD TVs, 4 monitors, 13 plasma TVs, and a 6.1 system! Free service manuals database: http://www.tgohome.com/ServiceManuals - Have a manual? Need a manual? Please PM me. I have successfully fixed (from best --> worst build quality): 3 Panasonic Plasmas, 1 Yamaha HTS, 1 NEC Plasma, 2 Sharp LCDs, 2 Toshiba LCDs, 5 Philips Plasma/LCD, 1 Hitachi Plasma, 5 LG LCD/Plasma, 10 Samsung LCD/Plasma, 1 Thomson Plasma, 1 Atec LCD, 1 Hanspree LCD, 1 Xerox LCD, 1 Harwa LCD, 2 Proview LCD, 2 Hyundai LCD, 1 "Onn" LCD, 1 Dell LCD, 1 iiyama LCD, 1 Logik LCD, 5 Bush LCD, 10 Vestel LCDs [Please do not PM me for help: I am a busy student, and we prefer input from all sides on this forum.] Last edited by tom66; 02-10-2012 at 02:04 PM.. |
#3 |
I did check those voltages on that side of the PSU, and here is what I got:
Red and Orange both have 13.2v, and were marked 12v on the board. Yellow and Green both have 5.1v and are marked as 5v on the board. The only other marking was what looked like 1 15v. Not sure if that was supposed to be 1v and 15 v, or what. But neither wire had anything. These wires are going to that small rectangle board. There were 3 wires with no markings on the board but had current. White 2.7, Black 4.0, and Brown 3.1. These were going to the main board. And all of these readings were with the green power light on. I also checked the other output on the PSU and got nothing except .1 on the wire marked dim on the board. |
#4 |
And I haven't replaced anything, and as far as I know neither did the previous owner. He never mentioned it.
#5 |
My Country: UK
I'm a: Student Tech
The 12V lines measured 13.2V? That's rather high... Something doesn't seem right. Where were you measuring ground?
#6 |
At the chassis ground screw.
#7 |
Even using the wire in that plug that is labeled GND, I still get 13.2 on those wires.
#8 |
City & State: Canada
From the computer lcd monitor world, a lot of the secondary voltages are unregulated and appear high, but then fall into "spec" when everything is working (i.e. there is a proper load).
It may be the same in the TV world especially since the backlights are not on to draw any load.
--- begin sig file --- If you are new to this forum, we can help a lot more if you please post clear focused pictures (max resolution 2000x2000 and 2MB) of your boards using the manage attachments button so they are hosted here. Information and picture clarity compositions should look like this post. We respectfully ask that you make some time and effort to read some of the guides available for basic troubleshooting. After you have read through them, then ask clarification questions or report your findings. Please do not post inline and offsite as they slow down the loading of pages. --- end sig file --- |
#9 |
My Country: UK
I'm a: Student Tech
That may well be true - although it's not typical for a supply with standby power.
Sometimes a higher voltage is indicative of bad caps because the power supply controller is overshooting or is unstable. |
#10 |
I agree with everything you are saying. Just sharing what we have seen in the lcd computer monitor world.
#11 | |
My Country: UK
I'm a: Student Tech
In my experience (and that of others on this forum) the #1 failure mode with bad caps is a decrease in output voltages, not an increase, although a capacitor decreasing in capacitance, or one with an extremely high ESR would probably cause an increase in voltage. Effectively, at high frequencies, the cap is supposed to act as a short circuit, to filter out the higher frequencies, but if it doesn't have a low enough ESR, there is no where for this high frequency noise to go, other than to increase the output voltage. |
#12 | |
Grumpy Old Fart
City & State: Phoenix, AZ
Line Voltage: 120V 60Hz
Mann-Made Global Warming. - We should be more concerned about the Intellectual Climate. - Be who you are and say what you feel, because those who mind don't matter and those who matter don't mind. - Dr Seuss - You can teach a man to fish and feed him for life, but if he can't handle sushi you must also teach him to cook. - |
#13 |
Ok. So what should I check next, or do I need to replace some capacitors?
#14 |
Anyone?
#15 |
Still sitting here with an open TV. Can someone help me out please? I'm ready to get this thing fixed.
Thank you! |
#16 |
City & State: S.F. Bay area
Can you please take good clear pictures of the the whole chassis so we may be we will be able to see how it is wired up? We also need to see the third connector on the power supply board which I think it goes to the Inverter board, back side pictures of the power supply, closed up pictures of the inverter multi-pin connector, LCD panel make, model, revision number so we can look up the spec of the LCD panel which will show the T-CON and inveter board pin out of the connectors, etc.
By the way, do you get sound?, also try turning it on without the inverter board discoonected from the power supply board. Last edited by budm; 03-02-2012 at 03:12 PM.. |
#17 |
Thanks Bud. I'll get working on those pictures and specs tonight when I get home. I appreciate the help.
#18 |
Looking at your picture of the power supply, I think this is what it has on it, see PDF. Right now the standby PS seems to be working (this power supply is running 24/7).
#19 |
All of your assumptions are correct about where the wires are going. And I checked the voltage on the cap, and they fell right in line with where you said that it would.
#20 |
So if I am right, right now you do not have the 24vdc feeding the Inverter board, yes/no? If not, disconnect the cable to the inverter board an see if the 24vdc comes back since if the 24vdc PS circuits sensing over current draw, it will go into shutdown mode.
Another reason you do have 23vdc can be due to 24vdc circuits itself, or it is not getting the command from the main board to turn it on. Any voltage labels on the power supply connector at all? That will be a big help if they are labeled. Last edited by budm; 03-02-2012 at 04:11 PM.. |
| Thread Tools | |
| Display Modes | |
