Go Back   Badcaps Forums > Electronics Theory and Troubleshooting > General Electronics
Old 02-06-2012, 08:06 AM   #1
selldoor
Slow Learner
City & State: Lancashire UK
Default Transformer Tape
Have just received an inverter transformer for a monitor power supply board.
It has yellow transparent tape around it. Do I remove the tape before fitting or leave it on? The one I am taking off does not have any tape on it.
selldoor is offline   Reply With Quote
Old 02-06-2012, 08:29 AM   #2
ratdude747
ratdude747's Avatar
City & State: New Albany, IN
Line Voltage: 120VAC 60Hz
I'm a: Student Tech
Send a message via Yahoo to ratdude747 Send a message via Skype™ to ratdude747
Default Re: Real easy question if you know the answer
Keep the tape.
also renamed the thread to reflect the subject.
(Insert signature here)
ratdude747 is online now   Reply With Quote
Old 02-06-2012, 08:33 AM   #3
selldoor
Slow Learner
Originally Posted by ratdude747 View Post
Keep the tape.
Thanks ratdude747
selldoor
Old 02-08-2012, 02:24 AM   #4
larrymoencurly
larrymoencurly's Avatar
Default Re: Transformer Tape
DealExtreme.com sells Kapton tape cheap. It's not that yellow tape but is high temperature and apparently is used for transformers, even where high voltage safety is needed.
larrymoencurly is offline   Reply With Quote
Old 02-08-2012, 04:07 PM   #5
ben7
City & State: Trenton, NJ
Line Voltage: 240v-120v 60Hz 200A service drop
If the tape is still sticky, and you have a use for it, keep it. Otherwise it will just sit around adding to a larger mess of stuff
-Ben
Hi-pot test: FAIL
ben7 is offline   Reply With Quote
