#101 |
City & State: Central CT
Line Voltage: 120VAC 60Hz
I'm a: Hobbyist
Whoops my post went in after you Checking now.
#102 |
I'm a: Hobbyist
OK just Checked them, I have 119v coming in on the 120v line and both these caps measure 163v. Took me a second to realize I had to set my meter to DC. Thanks!
#103 |
City & State: University of Leeds (MEng ElecEng undergrad)
My Country: UK
Line Voltage: 230Vac 50Hz
I'm a: Student Tech
Your power board is full of high quality "Japcaps" (Japanese capacitors.) These rarely fail. I have never seen a failed Chemicon KY and they are most likely not your problem. I have only ever seen one failed Rubycon, on this forum, but it was most likely due to the failure of some poor quality "Elite" capacitors on the power supply. Generally with bad caps the output voltages become low (too low for operation of the TV) but they are *not* zero.
I can't remember - did you check all the diodes? Check the two diodes I have highlighted (black) with TV unplugged using the diode test mode. Check the pink resistor I have highlighted - should appear close to zero ohms.
** Begin Signature ** I fix TVs and electronics as a hobby and to save nice things from the dump. 40 LCD TVs, 4 monitors, 13 plasma TVs, and a 6.1 system! Free service manuals database: http://www.tgohome.com/ServiceManuals - Have a manual? Need a manual? Please PM me. I have successfully fixed (from best --> worst build quality): 3 Panasonic Plasmas, 1 Yamaha HTS, 1 NEC Plasma, 2 Sharp LCDs, 2 Toshiba LCDs, 5 Philips Plasma/LCD, 1 Hitachi Plasma, 5 LG LCD/Plasma, 10 Samsung LCD/Plasma, 1 Thomson Plasma, 1 Atec LCD, 1 Hanspree LCD, 1 Xerox LCD, 1 Harwa LCD, 2 Proview LCD, 2 Hyundai LCD, 1 "Onn" LCD, 1 Dell LCD, 1 iiyama LCD, 1 Logik LCD, 5 Bush LCD, 10 Vestel LCDs [Please do not PM me for help: I am a busy student, and we prefer input from all sides on this forum.] |
#104 |
I'm a: Hobbyist
I checked the three main diodes on the big heatsink on the secondary side. That was all.
The two diodes measure 482 one way and out of range the other way. The Pink Resistor Measures 2 ohms. Thanks! |
#105 |
My Country: UK
I'm a: Student Tech
Hmm. 2 ohms seems quite high. What do your multimeter probes measure when touched together?
#106 |
I'm a: Hobbyist
Checked again with the Craftsman meter.
And Got 1.4 Ohms. Probes touched together measured 0.6 so I am assuming that its around 0.7-0.8 Ohms |
#107 | |
My Country: UK
I'm a: Student Tech
Do you have a photo taken from an angle looking underneath the primary heatsink? (The one near the big caps.) I suspect your switching controller is bad, but let's see if there are any hidden fuses under there. |
#108 |
I'm a: Hobbyist
Post Number 28 should Cover you I think.
http://www.badcaps.net/forum/showpos...5&postcount=28 Let me know if you need another shot. |
#109 |
I'm a: Hobbyist
I allready tested the main Fuse are there usually others on a SMPS?
#110 |
My Country: UK
I'm a: Student Tech
#111 |
I'm a: Hobbyist
Are these Pictures OK?
Post Number 28 should Cover you I think. http://www.badcaps.net/forum/showpos...5&postcount=28 Let me know if you need another shot. |
#112 | |
My Country: UK
I'm a: Student Tech
#113 |
I'm a: Hobbyist
Are the ones here ok? If not what area do you need a close up of?
http://www.badcaps.net/forum/showpos...52&postcount=1 Last edited by ComputerGeek; 02-23-2012 at 01:44 PM.. |
#114 | |
My Country: UK
I'm a: Student Tech
#115 |
I'm a: Hobbyist
Theres only two caps under there, as far as I see heres a photo, I also grabbed one of another area I thought might be helpful. Thanks!
#116 |
I'm a: Hobbyist
Are those photos ok?
#117 |
My Country: UK
I'm a: Student Tech
They're good. Nothing important unqder the heatsinks. That's disappointing, I was hoping to see a fuse or something like that.
What are the part #'s on the chips on the bottom? |
#118 |
I'm a: Hobbyist
OK i am assuming you want the black Smd chip on the bottom of the board?
Also when looking at the picture Vs101 and VS102 in the first picture of post 115 look discolored is there a way to test those? Thanks! |
#119 |
I'm a: Hobbyist
A picture is worth a thousand words of here you go. THnaks!
#120 |
My Country: UK
I'm a: Student Tech
Okay, check the voltage between these two pins with PSON both high and low using the resistor.
You should get around 9 to 16V if it is working okay, typically when PSON is high. When PSON is low, it might drop below 9V. If the voltage here isn't high enough, it points to a problem in the pre-charge or the standby power part. |
| Thread Tools | |
| Display Modes | |
