#41 | ||
City & State: Canada
I heard Kester makes very good solder, but so far I have found the cheap 60/40 generic stuff works.
--- begin sig file --- If you are new to this forum, we can help a lot more if you please post clear focused pictures (max resolution 2000x2000 and 2MB) of your boards using the manage attachments button so they are hosted here. Information and picture clarity compositions should look like this post. We respectfully ask that you make some time and effort to read some of the guides available for basic troubleshooting. After you have read through them, then ask clarification questions or report your findings. Please do not post inline and offsite as they slow down the loading of pages. --- end sig file --- |
#42 |
1) Can we get a close up shot of all the connectors so we can see the legend?
2) Can we also get another 2000x2000 shot of the power supply? The existing one is too small resolution. 3) Please use manage attachments this time. With the new server, some people are saying pics load really quick now. |
#43 | |
Banned
#44 | |
City & State: Ireland
My Country: Ireland
Line Voltage: 240V AC, 50Hz
Anyway, I was wondering where the green LED should be on the mainboard, I only see 4 red LEDs. I see another LED which is not illuminated. Also, were your 4 caps near the inverter connection all 105dC caps? Mine were rated 130dC. Anyway, in addition to the 10 caps I replaced, there were a number of other points I reflowed and added solder to, particularly on the transformer, and a few other spots that looked like they needed it, more like the components with heavier connections like diodes and power transistors. |
#45 |
My Country: Ireland
#46 |
No I don't. Fortunately, my LG only needed the high frequency caps replaced and it started working like new so I never had to delve into it beyond that.
#47 | |
So way back in post #1 (Dec 28, 2011), DakatoKid reported 6V on the 6V rail. So it looks like this is obviously not normal. So if your soldering is good, then I would start checking around that area. |
#48 |
Banned
Hi all, sorry I haven't had a chance to post. Power went out here for about a week (bad storms) and then I got really busy. Retiredcaps, I ordered the replacement 5 caps and am awaiting delivery from DigiKey. I will install those as soon as I get them and let you know how it goes.
Thanks again for your help! |
#49 | |
City & State: melbourne
My Country: australia
retirecaps, do we need to use low esr caps for those 5 caps in the primary side? low esr caps are very difficult to find in my local (australia) electronics shops..... |
#50 |
updates....
replaced the other 5 smaller caps and problem remains according to my son (the owner of the tv), it did not become bad slowly over time but rather an overnight thing. sounds like this one is not a bad caps problem after all..... some readings when the tv is turned on with the remote: 6v is 6.1v 12v is 11.9v 5v is 5.1v 19v is 18.9v 3.4v is fluctuating between 1.1-1.5v !!! when p202 connector (to av board) is disconnected, 3.4v went up to 1.7v steady. still way below...... i'm at the stage of giving up repairing the psu and would just like to buy a replacement psu, but only if that is most likely going to fix the problem. would appreciate any advices, based on the findings so far. tia. edit: the 3.4v-on rail is 2.1v when on. 24v is 23.95v. Last edited by jh20; 08-04-2012 at 03:42 AM.. Reason: more info |
#51 |
City & State: University of Leeds (MEng ElecEng undergrad)
My Country: UK
Line Voltage: 230Vac 50Hz
I'm a: Student Tech
3.4V is your problem. Three other users on this forum have had problems with it, including me. On mine, it somewhat worked (picture, but no sound, no DVB, no HDMI, no RC or side-buttons) with 3.4V measuring around 2V. 3.4V-ON is good, but that's only a control signal.
** Begin Signature ** I fix TVs and electronics as a hobby and to save nice things from the dump. 40 LCD TVs, 4 monitors, 13 plasma TVs, and a 6.1 system! Free service manuals database: http://www.tgohome.com/ServiceManuals - Have a manual? Need a manual? Please PM me. I have successfully fixed (from best --> worst build quality): 3 Panasonic Plasmas, 1 Yamaha HTS, 1 NEC Plasma, 2 Sharp LCDs, 2 Toshiba LCDs, 5 Philips Plasma/LCD, 1 Hitachi Plasma, 5 LG LCD/Plasma, 10 Samsung LCD/Plasma, 1 Thomson Plasma, 1 Atec LCD, 1 Hanspree LCD, 1 Xerox LCD, 1 Harwa LCD, 2 Proview LCD, 2 Hyundai LCD, 1 "Onn" LCD, 1 Dell LCD, 1 iiyama LCD, 1 Logik LCD, 5 Bush LCD, 10 Vestel LCDs [Please do not PM me for help: I am a busy student, and we prefer input from all sides on this forum.] |
#52 |
thanks tom66. here's the detail outputs from the psu: (those on the right in brackets are b700029's)
p201: pin 1 - 3.4v-on = 2.10v (3.37v) pin 2 - gnd = 0v pin 3 - 6v = 5.98v pin 4 - dim = 3.22v (5.15v) pin 5 - gnd = 0v pin 6 - st/5v = 5.06v pin 7 - bri = 2.96v (0v) pin 8 - err = 3.23v (5.16v) pin 9 - i-c = 4.56v (0v) pin 10 - gnd = 0v pin 11 - st/5v = 5.06v pin 12 - on = 2.89v (4.39v) pin 13 - acd = 3.9v (5.15v) p202: pin 1 - gnd = 0v pin 2 - 12v = 11.73v pin 3 - gnd = 0v pin 4 - 3.4v = fluctuates betw 1.1 to 1.5v pin 5 - gnd = 0v pin 6 - 6v = 5.98v pin 7 - gnd = 0v pin 8 - gnd = 0v pin 9 - 19v = 18.83v pin 10 - 19v = 18.83v p203: pin 1 - gnd = 0v pin 2 - gnd = 0v pin 3 - 12v = 11.73v pin 4 - 12v = 11.73v pin 5 - gnd = 0v pin 6 - gnd = 0v pin 7 - 6v = 5.98v pin 8 - 6v = 5.98v pin 9 - gnd = 0v pin 10 - gnd = 0v pin 11 - 3.4v = betw 1.1 - 1.5v pin 12 - 3.4v = betw 1.1 - 1.5v p204 and p205: pin 1 to pin 5 - 24v = 23.95v etc.... some of the voltages from the main board (p201) seems a bit off when compared to b700029's, like the 3.4v-on signal. i've only got 2.1v but his 3.37v? basically i'm thinking about replacing the whole psu at this stage but really need to be assured it's going to fix the problem and not ended up something else? ta. edit: btw b700029, your problem is probably not the 12v but the 6v. |
#53 |
bought a new psu and the problem is fixed.
btw in my above post, the pin-outs for p201-p203 are in reversed order. eg, pin 1 of p201 should be pin 13 and pin 13 should be pin 1 etc... |
#54 |
City & State: NC
I found these caps to replace on my TV Power Supply
EEU-FM1E102 EEU-FM1A681 EEU-FM1A471BJ EEU-FM1A332 EEU-FM1C102 EEU-FM1V102 Is there anyway someone can confirm these are the right ones. Or make a suggestion of better ones. This forum is very helpful! ! ! ! ! ! |
#55 |
My Country: UK
I'm a: Student Tech
Are those Panasonic FM? Those are very good caps. As long as they are the same capacitance, and the voltage is the same or higher, they are fine - check the dimensions too and see that they fit.
#56 |
City & State: Adelaide/South Australia
My Country: Australia
I picked up a 37lc2d from the side of the road and was dissapointed when it didn't work.
![]() i replaced all the caps and it still didn't work. ![]() Further investigation revealed the 3.4 v rail was around 1.8V. Examining the board reveals this voltage rail is generated with an ir3037 SOIC synchronous buck regulator from the 6V rail (I think): http://www.irf.com/product-info/data...ta/iru3037.pdf The circuit is similar to the data sheet but with 2.2 Ohm resistors in the chip output to the FETs as well as some diodes. These components are surface mounted on the back side of the board. I soldered some short wires from the FET gates to hook CRO leads to and remounted the PSU. On the CRO the drive waveform for the 2 FETs looked OK then I realised the TV was now working. I'm thinking that the problem was a cracked solder joint on one of these components. |
#57 |
My Country: UK
I'm a: Student Tech
Heh, you pick up a curbside TV and you expect it to work? People aren't -that- wasteful.
In my case, I just replaced the PSU, but in future, I would try and replace the IC and MOSFETs. I haven't debugged the circuit enough to know which fails. It may be a die bonding problem ... you flexed one of the chips, the bonds make contact again. Watch it carefully. It will probably go wrong again. |
#58 |
City & State: gastonia, nc
My Country: usa
Hello I had the same issue as the OP and all I replaced was the cap that was bulging and it solved the problem. Thanks for having this on the net, it was a big help.
Barr |
#59 | |
Slow Learner
City & State: Lancashire UK
all caps of a similar make and series. If one has gone others will soon follow. As caps deteriorate they put undue pressure on other components and if they break it may be costlier and more difficult to repair. It is also important to use caps of the same esr and ripple rating or better or else the repair is unlikely to last as long as the oroginal caps did. |
#60 |
City & State: Sydney, NSW
Would someone be able to post the cap values at the board locations? I need to double check I've put mine back in the correct spots. I'm missing the 6 volt rail and want to eliminate a wrong cap b4 I proceed any further. I have a service manual for this model but it must be a different chassis. The caps are not the same for the board locations.
| Thread Tools | |
| Display Modes | |
