Go Back   Badcaps Forums > Motherboards with Bad Capacitors > MSI/Microstar
Old 12-30-2011, 02:12 PM   #21
c_hegge
Unknown
c_hegge's Avatar
My Country: Australia
Line Voltage: 240V 50Hz
Default Re: MSI 848P Neo-V / MS-6788
You could also poly-mod the CPU VRM.
For the four 1500uF 16V caps (which will be on the VRM High side), use http://www.badcaps.net/store/product...products_id=78
For the 3300uF 6.3V (VRM Low side) use http://www.badcaps.net/store/product...roducts_id=134 and fill the 3 blank spaces
For the 1500uF 6.3v caps use, http://www.badcaps.net/store/product...roducts_id=152. The small capacitance increase won't matter. (and the link to the 1500uF cap is broken - I'll PM topcat about that one).
For the 1000uF 6.3V caps, use http://www.badcaps.net/store/product...roducts_id=131
Main PC: Core i5 660 3.33GHz, Gigabyte GA-P55-UD3R, 4GB Kingston DDR3 1333, 750GB WD HDD, Sony Optiarc DVD RW, nVidia GTX295 1760MB, Antec 1200 Case, Delta DPS-750CB 750W PSU, Hauppauge TV Tuner, Windows XP Pro.
Main Laptop: Lenovo Thinkpad T60: Core 2 T2500 2GHz, 2GB DDR2, 80GB HDD, DVD RW, Intel Graphics, Windows XP Pro.
2nd Laptop: Toshiba Satellite A200: Core Duo 1.73GHz, 2GB DDR2, 60GB HDD, DVD RW, nVidia GF Go 7300 Graphics, OpenSUSE 12.2, Fan Mod
c_hegge is offline   Reply With Quote
Old 12-30-2011, 03:49 PM   #22
c_hegge
Unknown
c_hegge's Avatar
Here's the 1500uF 6.3v caps, now that the link is fixed http://www.badcaps.net/store/product...roducts_id=136.
Old 01-01-2012, 06:49 PM   #23
Altairat8te38
You guys are great! Shall be printing them rulers out asap.
Happy new year!
Altairat8te38 is offline   Reply With Quote
Old 01-06-2012, 07:58 AM   #24
Altairat8te38
Hey guys could I poly mod the entire board without any issues?
Old 01-06-2012, 12:44 PM   #25
PCBONEZ
Grumpy Old Fart
PCBONEZ's Avatar
City & State: Phoenix, AZ
Line Voltage: 120V 60Hz
No guarantees.
You have permission to "boldly go where no man has gone before".
Let us know how it works out.
Not all Polys have better ESR specs than lytics so the idea that any ole poly will work is a farce.
You still have to check specs to make sure the ESR is better than original.
VRM mods are well worked out and if you use the right polys it works well.
That mod has been outlined in a number of threads.
The other parts of the board is anyone's guess.
The only one that can tell you would be someone that has done it on THAT specific board.
Additionally, unless you are having heat issues outside of the VRM, there is really no big benefit to using ploys outside the VRM.
A misconception is that you can always lower uF if you use polys.. Nope..
That's -only- true in the VRM if you use the right polys.
In other parts of the board it is anyone's guess and you probably need the original uF if you want a stable board.
Mann-Made Global Warming.
- Dr Seuss
PCBONEZ is offline   Reply With Quote
