Go Back   Badcaps Forums > Electronics Theory and Troubleshooting > Power Supply Design and Troubleshooting
Old 04-29-2006, 04:05 AM   #1
larrymoencurly
larrymoencurly's Avatar
Default How long can cap leads be?
I have a PSU where some of the output filter caps are a tight fit, and it would help the crowding a lot if I could install a couple of the new caps about 1" above the board. Would this make the leads too long? I can solder 16 gauge wire to each lead to reduce the inductance, if it will help. Of course, each lead will be covered with heatshrink to prevent shorts.
larrymoencurly is offline   Reply With Quote
Old 04-29-2006, 04:45 AM   #2
kc8adu
kc8adu's Avatar
City & State: dayton ohio
Default Re: How long can cap leads be?
i have done 1/2 in when 12.5 mm caps wouldnt clear stuff on the board.some psu use 10 or 8 mm caps.no harm done.
kc8adu is offline   Reply With Quote
Old 04-29-2006, 05:03 AM   #3
linuxguru
The switching frequency is only ~100 KHz, and there's already inductance (either stray or part of the circuit) in series at most locations on the secondary side where large caps are usually found. A few pH/nH additional in series won't make a difference.
Exception(s) to this are the small bypass caps next to the switching controller IC or on the output side of 78xx/79xx 3-terminal regulator(s) - these have to have very short leads to avoid instability/oscillations due to high loop-gain linear circuits.
linuxguru is offline   Reply With Quote
