#1 |
City & State: Canada
picked this item up yesterday from a guy who was gonna toss thought id give it a shot.
i press the power button on, blue light come on, it stays on, clicking in the power relay switch area, plasma does not light up. no signs of bad caps, the area looks good. im not a pro tech and i don't have the electrical knowledge but if led i can follow well enough. it has to be something simple im hoping. looks to be a really nice tv. any thoughts or ideas. i will post pics if requested but i just didnt want to load a bunch up at the time. just thought id ask first and show later. thanks. |
#2 |
City & State: Phoenix, AZ
Line Voltage: 120VAC 60Hz
I'm a: Hobbyist
Post one picture of the back of the set (with the cover removed). That will help identify who made the plasma panel, and give us the information to request more detailed pictures.
Attach it using 'Manage Attachments' - below the text entry area.
For a number of reasons, both health and personal, I will no longer be active on this board. Any PMs asking for assistance will be ignored. Never be afraid to try something new. Remember, amateurs built the ark. Professionals built the Titanic. |
#3 |
City & State: Colorado
These are known for failures of two capacitors on the power supply. Most of the time they show no signs of failure. Coppell TV wrote an article about this problem here: http://blog.coppelltvrepair.com/2010...o-picture.html
Now, it is also possible that the Y-main and buffers could have failed as this TV uses the LJ92-01200A, -01202A, -01203A Y-main and buffers. If that is the case then it might not be worth repairing. I would suggest checking voltages coming out of the power supply as your first step. First, check voltages with all boards plugged in. If you do not get correct values then disconnect the Y-main and recheck. Reconnect the Y-main and disconnect the X-main and recheck. Finally disconnect both and recheck if you still do not get correct voltages then the power supply is the problem. At that point I would suggest replacing the two caps mentioned in the above article as they are responsible for the Vs-On signal from thr main board. |
#4 |
AWESOME thank you so much!! i will dig into this and post back!!
#5 |
a couple pics attached little blurry sorry as i wasnt able to lay this monster down for a good top view photo. it is pretty heavy!!
#6 |
I'm a: Hobbyist
#7 |
As i do not have the electronic experience with this type of repair i may be in a lot over my head so please bare with me....to just go ahead and test for shorts i wouldn't know where to start so i just did some cable plugging / unplugging and here is what i found. hopefully this may help.
there is a small green light on the main panel at the bottom just right of the PHILIPS cable output when power cable is plugged in. everything plugged in normal i press the power button and i hear 3 clicks coming from the power relay boxes. when i press the power button off. no clicking sound. with only the x-main unplugged i hear 2 clicks but when powered off i hear one click. with only the y-main unplugged i hear 3 clicks but when powered off no click. i hope this may narrow it down as like i said this may be beyond my capabilities to properly test the unit. thanks. |
#8 | |
I'm a: Hobbyist
http://blog.coppelltvrepair.com/2010_03_01_archive.html http://blog.coppelltvrepair.com/2010_06_01_archive.html http://blog.coppelltvrepair.com/2010_10_01_archive.html PlainBill |
#9 |
City & State: Hudson, MI
I was given a Dell 4201C HD plasma TV from the local computer store that does electronics recycling. I have read through several posts on badcaps.net and also the articles on coppelltvrepair.com. I ordered the two capacitors from digikey.com (p/n 493-1501-ND) and replaced them tonight. The only sign of life is still the blue LED and I get no picture and no sound. I tried powering on with everything plugged in, with the z-sustain unplugged, with the z-sustain and y-sustain unplugged, and with the z-sustain, y-sustain, and control board unplugged with no change in function.
Voltages with everything plugged in: (label - specified on label - actual) Va - 70 Vdc - 70.3 Vdc Vs - 207 Vdc - 209 Vdc Vsc - 190 Vdc - 191 Vdc Ve - 84 Vdc - 84.2 Vdc Vset - 190 Vdc - 191.1 Vdc From my reading, it would appear this TV is destined to head back for recycling. I just wanted to get a second opinion before taking it back. Thanks in advance. |
#10 |
anyone?
#11 |
City & State: University of Leeds (MEng ElecEng undergrad)
My Country: UK
Line Voltage: 230Vac 50Hz
I'm a: Student Tech
Did you check the other voltages, such as 5V, from the power supply?
** Begin Signature ** I fix TVs and electronics as a hobby and to save nice things from the dump. 40 LCD TVs, 4 monitors, 13 plasma TVs, and a 6.1 system! Free service manuals database: http://www.toms-service-manuals.com/ - Have a manual? Need a manual? Please PM me. I have successfully fixed (from best --> worst build quality): 3 Panasonic Plasmas, 1 Yamaha HTS, 1 NEC Plasma, 2 Sharp LCDs, 2 Toshiba LCDs, 5 Philips Plasma/LCD, 1 Hitachi Plasma, 5 LG LCD/Plasma, 10 Samsung LCD/Plasma, 1 Thomson Plasma, 1 Atec LCD, 1 Hanspree LCD, 1 Xerox LCD, 1 Harwa LCD, 2 Proview LCD, 2 Hyundai LCD, 1 "Onn" LCD, 1 Dell LCD, 1 iiyama LCD, 1 Logik LCD, 5 Bush LCD, 10 Vestel LCDs [Please do not PM me for help: I am a busy student, and we prefer input from all sides on this forum.] |
#12 |
12V - 12.03 Vdc
5V - 5.22 Vdc |
#13 |
I am working on a similar plasma TV, a Dell w5001c hd, with similar problems no video or audio but the blue power light comes on and the relay clicks. I read the Coppell article about the bad caps and I noticed the w4201c is almost the same tv with the same design defects. So today googled Dell w4201c to see what comes up and found this website. I also found plasmafix.com and they have troubleshooting tips and a list of repairs for TVs they have fixed by model number. The w4201c is listed that powers on but no picture, and it was a shorted buffer board and Y sus board.
This is the same thing I found after I replaced the bad caps mentioned on the Coppell website and still had no video. I checked the voltages on the PS and they were like yours close to the specs. Then I found an instructables.com repair article http://www.instructables.com/id/Dell...ot-plasma-fix/ where I learned about other known problem areas in Samsung plasma TVs including the buffers. So I followed the instructions from Coppell on how to check the buffers with an Ohm meter. They also mentioned that if one blows it takes the rest with it. Both of mine were blown (LJ92-01277A and LJ92-01276A) so I looked at the Y sus board (LJ92-01275A) and found 4 shorted SMD zener diodes near the upper buffer socket (ZD5024, ZD5023, ZD5017, ZD5016). I googled the part number RLZ33B but I could not find a replacement. This board is hard to repair because there are no service manuals or parts list available. Also plasmafix.com does not mention the location of the bad mosfet. So I decided to replace the Y sus board and both buffers. Shopjimmy.com had the cheapest price for the buffers with a six month warranty but did not have the Y board. The cheapest place I found was tristatemodule.com with a 6 month warranty. In total it will cost about $250 in parts to fix the TV and that is cheaper then any 50 inch out there. Youtube also has a lot of good fix it videos and that is how I located the zeners on the y sus board. |
#14 |
I'm a: Hobbyist
Thanks for the links. Always glad to have more sources for information.
PlainBill |
#15 |
City & State: Hampton
My Country: United States
I found this one by the recycle bin in my neighborhood so I took it home to give it some love. expecting the worst... Well it powered on fine and I connected it to a dvd player the picture was crystal clear sound was ok but the right speaker's sound was fluctuating up and down periodically thorughout the movie. I left home and came back 2 hours later and now It powers on (blue light) but no picture. I knew it was to good to be true. well any way I am curious to know if it is fixable??????? and how would I replace the bad caps if there are any?
#16 |
My Country: UK
I'm a: Student Tech
You can start by taking pictures and we can highlight the failed caps.
#17 |
City & State: Mesa Arizona
4 shorted SMD zener diodes near the upper buffer socket (ZD5024, ZD5023, ZD5017, ZD5016) . those are 5.1v Zener, unsolder them (protection only)
. and I just fix this dell 50" TV. |
| Thread Tools | |
| Display Modes | |
