#41 |
Fuhjyyu Killer
City & State: Behind a soldering iron
My Country: New Zealand
Line Voltage: 230V AC 50Hz
#42 | |
City & State: Springfield, Vermont
Line Voltage: 122-125V 61-62.5 Hz
And a Caviar 1 GB I had, pre-1998, always fails after 238 MB! DOS' FORMAT.COM usually displayed "Format terminated" with any attempt to format past 238 MB and I also got a click-of-death.
Asus Maximus II Gene Core 2 Duo E8400 @ 3.6 Ghz 2 GB A-Data PC2-6400 DDR2 SDRAM @450 Mhz eVGA GeForce 9500GT (rthdribl stable) Fortron FSP500-60GLN(80) 500W PSU Windows XP Pro x64 SP2 "There's nothing more unattractive than a chick smoking a cigarette" -Topcat "Don't eat yellow snow!" -Salem "did I see a chair fly? I think I did! Time for popcorn!" -ratdude747 Last edited by RJARRRPCGP; 01-29-2012 at 03:59 PM.. |
#43 |
404 Not Found
City & State: Fairfax, California
Line Voltage: 120VAC 60Hz
I'm a: Forum Junkie
I just got a "new" Seagate 1TB Barracuda ES.2, "Certified Repaired" (refurb, probably), HDD, and it clicks when you turn it on? Like twice, then it acts normal. is that a problem?
Firefox is named after a fox - WRONG! That orange thing is a Red Panda, not a fox!! http://www.youtube.com/watch?v=y6GaPkkGZGw |
#44 |
I would stay far, far away from Barracuda ES. And you know that Seagate is now only doing 3 years along with WD?
...Their plight, in fact is even worse, they don't realize that they're cantonists, they think they're free men. What a slavery that is - to confuse slavery for light, and bitter darkness for bright light. -Rabbi Menachem Mendel Schneersohn |
#45 |
404 Not Found
I'm a: Forum Junkie
What's wrong with Barracude ES?
#46 | |
City & State: Albany, Western Australia
Line Voltage: 230VAC 50Hz
![]() Did you have it apart??? |
#47 | |
City & State: VA
My Country: U.S.A.
Line Voltage: 120 VAC, 60 Hz
I'm a: Student Tech
The number of bad sectors aside, that hard drive is still working! It gets recognized by the BIOS and even tries to load Windows when I start it on my computer (but it fails since I'm trying it on a completely different motherboard and processor). |
#48 |
Banned
Wow. I will be very surprised if it still works after you remove the heads and platter and put them back.
#49 |
Fuhjyyu Killer
I've done that before. The drive will still work, but for how long, who knows?
It certainly won't get any better, that's for sure! If the drive is multi-platter you run a huge risk of screwing it up, if you get the platters misaligned. Of course if you open it outside of a cleanroom you will screw it anyway. But it might live long enough to do some data recovery... |
#50 | ||
Badcaps User
I also agree that larger drives are more prone to fail, especially with more platters and especially in the case of mechanical HDDs. The only advantage I can think of with a two platter drive (as opposed to one) is lasting longer if one platter fails. I would only trust a 1TB drive at the very most, and a two platter one at that - anything more and I think one is bounded for failure. It kind of expounds upon why older (quality) drives tend to last so long. Also, unless in huge amounts over a short span of time, reallocated sectors don't worry me that much. They'll certainly stress the drive more and will wan performance, but the operating system cannot see them so I can't see them causing much trouble such as the above example. Pending sectors are far more worrying to me, especially with surfeits of them, along with offline uncorrectable sectors. I have a Toshiba MK1637GSX that has 110 pending sectors (not sure why they haven't been reallocated yet with only 9 reallocations, and since there are no offline uncorrectable sectors, but the S.M.A.R.T. log shows 6,409 errors!) and often I hear it scratching and clicking when the HDD is writing or reading slowly enough (it seems to never happen when the drive is rapidly working). It sounds like this... Tick tick... Tick tick... TICK TICK CHTICKEETIE.... Tick tick. Tick. It's not literally ticking. More 'chitting', if you like. But it does tick when you hear it scratch and/or click. I guess Superfetch doesn't help (the drive has Vista Home Premium 32-bit on it) - it seems to work the hard drive more. Disabling it helps a might bit. Turning on Windows Search seems to help even more - it has the drive working quickly, so not nearly as many ticks, scratches, or clicks are heard, though it's not very good for heat and power. But I know those sounds definitely denote the pending sectors. I can't even get it to complete, say, the full benchmark of HD Tach (by Simpli Software) because of it. As for Seagate and the original topic of discussion, I don't care for what became of Seagate once they merged with Maxtor. Before they were fantastic. But after.... I'd call them more Maxtorgate. Or Seamaxtor. But they're not Seagate to me anymore. The quality control and quality itself is just too far gone. Last edited by Wester547; 02-24-2012 at 03:28 AM.. |
#51 | |||
A little like RAID 0 except that it only does it to increase capacity, not transfer rate. Quote:
![]() I had two bad Seagate 1TB drives. The first one was an ST31000333AS from, surprise surprise, a Maxtor-branded USB enclosure. SMART looked fine, but it would act up once in a while and I eventually took it to bits. The second one is an ST31000524AS which developed lots of bad sectors. I don't know about you, but I would act like if I saw 1000 reallocations on one of my own drives.OTOH, I am still using an OLD ST380011A (from an old whitebox from 08/2004; 37,226 hours on the clock) for my, uh, important stuff. If there's any type of abuse that will destroy that thing, I haven't found it. It's heavy too. (At least for a drive with one platter...) I even had an ST320414A (which wasn't MY old drive) fall about 1m to the floor. (The cat knocked it off. ) When I plugged it in, it worked fine. I was careful enough not to drop the ST380011A - good thing, because that was before I had a backup of anything. ![]() If they really are going downhill, it's sad because they made some ridiculously tough drives in the past. The last generation I feel confident in using for anything important is the 7200.8, maybe the 7200.9. I guess I have two options. Western Digital, or enterprise drives. |
#52 | ||||
Badcaps User
My only issue with those drive series (the 7200RPM ones in particular, and other 7200RPM drives of the time from other companies) is how much heat they generate without cooling from a fan, even at idle. Older drives seem to run significantly hotter. Also, the scratching doesn't surprise me - I've never heard good things about Toshiba (who only make portable and mobile drives, to my recollection) and would think them to be the worst of the companies manufacturing HDDs, in spite of HDD quality depending (usually) not so much on the company. Quote:
#53 |
Deputy dood
City & State: Berwick, PA
Line Voltage: 120VAC 60HZ
I'm a: Hardcore Geek
Every time a WD Green drive parks its heads, God kills a kitten.
Please, think of the kittens during your next HD purchase.
Ludicrous gibs! |
#54 | |||||||||
http://www.hddstatus.com/hdrepshowre...ation=A5554B7B Care is nothing to write home about though. Quote:
![]() Quote:
Oh, and what I said earlier: Quote:
But that doesn't mean you'll get away with dropping a drive onto a carpet. Quote:
#55 | ||||
Badcaps User
#56 | |
Fuhjyyu Killer
Motor makes a noise like an old fridge, when you listen to it from afar... but it refuses to die. Yeah but when you've already got 26, more will usually follow... |
#57 |
Badcaps User
I don't argue that - that's why 49 changed to 50 on my old drive. :P But I still think the drive will last a while longer.
And a IC35L040AVVN07 I have has a ball bearing motor but lasted 15,000 hours of use (and 5,000 power cycles) just fine - only 6 reallocated sectors, 7 reallocation events, and 1 pending sector (though the pending sector is my fault - it arose after running chkdsk of my own volition), along with 19 S.M.A.R.T. errors (2 being from that run of chkdsk). Not saying drives with ball bearing motors can't last long, I just think fluid bearings would ultimately be more reliable (and more quiet, though the IC35L040AVVN07 is a quiet drive already). |
#58 |
Fuhjyyu Killer
Running CHKDSK won't cause drive damage, it just ends up reading files (and thus sectors) that otherwise wouldn't often be read and shows up defects.
Those sectors already had issues, you just weren't doing anything with them and therefore didn't know there was an issue with them until you ran CHKDSK and it tried to read\write them. In saying that though, if a drive is borderline, running intensive programs like CHKDSK can push it over the edge. |
#59 |
Badcaps User
That's what I suspected, but I still worry that the drive will have further issue because of it....
#60 |
Fuhjyyu Killer
If you have a backup there's nothing to worry about
| Thread Tools | |
| Display Modes | |
