Old 11-28-2011, 12:39 PM   #1
SEAWOLF
My Country: Barbados West Indies.
Line Voltage: 117VAC
Default Samsung Plasma Tv with black vertical bar.
Someone has a Samsung plasma tv model#Pn50a400c2dxza with a black
vertical bar on the right side of the screen from top to bottom, and this tv is
two years old. Can anyone offer any solution for this problem?
SEAWOLF is offline   Reply With Quote
Old 11-28-2011, 12:43 PM   #2
tom66
Savin' for TSLA
tom66's Avatar
City & State: Leeds & B'Stoke
My Country: UK
Line Voltage: 230Vac 50Hz
I'm a: Student Tech
Default Re: Samsung Plasma Tv with black vertical bar.
Usually a bad panel. Sometimes fixable, often not. Would need a picture of the inside of TV to tell.
Old 11-28-2011, 02:16 PM   #3
mockingbird
mockingbird's Avatar
No, it's not the panel.
See this video:
http://www.youtube.com/watch?v=FXy2jHNpv_0
It is possibly fixable.
...Their plight, in fact is even worse, they don't realize that they're cantonists, they think they're free men. What a slavery that is - to confuse slavery for light, and bitter darkness for bright light.
-Rabbi Menachem Mendel Schneersohn
mockingbird is offline   Reply With Quote
Old 11-28-2011, 02:20 PM   #4
tom66
Savin' for TSLA
tom66's Avatar
My Country: UK
I'm a: Student Tech
See this video:
It depends on the design. Some TVs have the X buffers off-panel which are replaceable - whereas others have the X buffers on the panel and replacing them is not possible.
Old 11-28-2011, 03:02 PM   #5
mockingbird
Yea, but as the guy in the video points out, it's not the actual panel, the X Buffers were on the permanent cable coming out of the panel, so it's still not fixable, but there is nothing technically wrong with the panel itself.
Old 11-28-2011, 03:20 PM   #6
tom66
Savin' for TSLA
tom66's Avatar
My Country: UK
I'm a: Student Tech
Suppose, but I'd still write the TV off either way, as the panel+cables is going to be very expensive.
Old 11-28-2011, 06:30 PM   #7
cadiman
City & State: chesterland Ohio
You don`t know if it is a board or the chip on the ribbon cable. I have repaired over a couple hundred tvs so far. I learn something new on each one. Not always pattern failure.
I have had two plasma tvs with the vertical bar as said above. One was a burned chip on the panel ribbon cable.
The other had a bad board and a failed chip on the ribbon cable.
The chip looked ok but when I replaced the faulty board it still had a vertical bar.
The real problem here is people will make the tv dead (does not power on or blank screen) because everyone knows not to buy or take a tv with a vertical bar unless you need boards.
The one I have is a samsung and I use it for testing boards and learning.
cadiman is offline   Reply With Quote
Old 11-29-2011, 06:36 AM   #8
tom66
Savin' for TSLA
tom66's Avatar
My Country: UK
I'm a: Student Tech
In one case I have fixed the black vertical bar problem on an older LG plasma. It was just a resistor on the FFC that had a cold joint and had separated itself from the board. Tapping the bottom of the TV would sometimes fix it, but never for long. Fixed it with a bit of solder and a soldering iron.
Old 11-30-2011, 07:54 PM   #9
cadiman
Older is the key word here... as in 2005?
I think the older tvs were less of an issue and more repairable. I have a few of the oldie but goodies and I will not part with them.
Old 08-16-2015, 05:23 PM   #10
madphill
City & State: Rockvale TN
My Country: United States
I have the exact same issue on a Samsung P59D6500. It's on the far-left from top to bottom. It's approximately 4" wide. The TV got this issue around the 2-year mark and Samsung wouldn't do anything for me.
I've taken the back panel off and ensured the ribbon cables along the side of the TV are connected before but don't know if there is much else I can do.
Any advice is appreciated.
madphill is offline   Reply With Quote
Old 08-17-2015, 01:24 AM   #11
tom66
Savin' for TSLA
tom66's Avatar
My Country: UK
I'm a: Student Tech
Is the whole bar black, or are there a few pixel lines within the bar?
Old 06-14-2016, 08:55 PM   #12
heyagbay
City & State: Plymouth
Sorry old thread, but what difference would this make? I have a Samsung PN51E7000 which started out with a few thin vertical lines. It eventually turned into an entire vertical black bar about 3" wide with the thin vertical lines visible within.
I tried removing all ribbon cables going to the bottom (x-buffer?) boards and turning on the TV. The image was just dark noise, but the vertical black bar was still visible. This leads me to believe the problem is the chip on the ribbon cable going to the panel :/
In hopes for a cold solder issue, I tried flexing/tapping on the bottom boards, but the black bar remained. Even if it was that bottom board, the ribbon cable from the panel appears soldered or glued and I wouldn't know how to reconnect it.
It's pretty frustrating knowing that a little chip going bad can ruin an entire TV.
heyagbay is offline   Reply With Quote
