#21 |
it has the capability but no. keep in mind that anything socket a is 32 bit.
(Insert signature here) |
#22 |
City & State: Sheboygan, Wisconsin
My Country: United States
socket a wanna water cool i could go through my junk pile and see if i still have my old dangerden setup maze 4 block and a z chipset block lol
I am running out of guesses |
#23 |
#24 |
City & State: Windsor, Colorado
I'm a: Hobbyist Tech
Dual CPUs?
#25 |
#26 |
crap. recapped the psu, still dead.
![]() the manual tot he board says it needs at least a 400W psu, and my only other spare unit is a 300W delta. suggestions? |
#27 |
404 Not Found
City & State: Fairfax, California
Line Voltage: 120VAC 60Hz
I'm a: Forum Junkie
Use the Delta! Since when does a mobo have a wattage rating, lol!
Firefox is named after a fox - WRONG! That orange thing is a Red Panda, not a fox!! http://www.youtube.com/watch?v=y6GaPkkGZGw |
#28 | |
just like graphics cards do. to prove the point, I i will reveal that the mobo is a Gigabyte GA-7DPXDW manual attached. off topic- the manual as a lot of engrish in it... ![]() still looking for advice on the psu issue. ![]() |
#29 |
FYI- the 400w bit isn't in the manual, but in the FAQ on GB's site:
http://www.gigabyte.com/support-down...id=466&pid=995 ![]() |
#30 |
404 Not Found
I'm a: Forum Junkie
It's BS I think... how much amperage you got on the +12V, -12V, +5, and +3.3?
#31 |
well, a datasheet on my psu:
http://www.delta.com.tw/product/ps/s...f/DPS300GB.pdf the psu label says 12v 15A 5v 30A 3.3v 16A -12v 0.8A 5vsb 2A -5v 0.3A |
#32 |
404 Not Found
I'm a: Forum Junkie
Meh just use it until you find a better one. It's a Delta, so it can probably do a little more than 300w anyway...
#33 |
City & State: VA
My Country: U.S.A.
Line Voltage: 120 VAC, 60 Hz
I'm a: Student Tech
Very nice board there!
Like shovenose, I too have to raise the BS flag on the wattage rating that they gave on the FAQ, it's just unrealistic. ![]() I see a AUX 12v connector on the motherboard, so that means the CPU VRM is powered from the 12v rail, which in turn means you need a PSU with a stronger 12v rail. Either way, you I'm sure you won't need a 400W PSU. Just look up the TDP or Maximum Power Dissipation rating of each CPU on cpuworld, then multiply that by 1.3 (assuming an unrealistically low 70% efficiency for the VRM) and then by 2 (since you have 2 CPUs). That will give you a rough estimate of the wattage you need on the 12v rail. **** Okay, I just looked at all of the Athlon MP CPUs, and the highest Maximum Power Dissipitation I saw was 66 Watts. Using the numbers above, that gives you 171.6 Watts peak for the 12v rail just for the CPUs, which comes out to 14.3 Amps peak. And of course, that's only if your CPUs are the ones that use 66 Watts. The Athlon MP 2400+ are rated to dissipate 60W max, so that's 156W on the 12v rail, or 13A. Last edited by momaka; 11-18-2011 at 10:54 PM.. |
#34 |
i ran some calcs and in my initial single cpu setup, the 300W will work. for the final dual setup, I will need some more juice.
that assumes that i keep the graphics card, which is an nvidia geforce 5200fx. |
#35 |
Unknown
My Country: Australia
Line Voltage: 240V 50Hz
It will struggle with a dual CPU. It has too much current on the 5v rail and not enough on the 12V rail. That board may be a socket A, but it does have an ATX12V connector. If you were in Aus, you could have my thermaltake TR2 Bronze 600W.
http://www.ebay.com/itm/XPS-700-710-...item35b6be0c53 looks like it would be goof for the money. It looks like it might be standard ATX but you never know with Dell http://www.ebay.com/itm/Seasonic-550...item1c20d16c01 That one is a bit more expensive, but also looks good. EDIT, your Delta may be OK for a single CPU.
I love putting bad caps and flat batteries in fire and watching them explode!! Main PC: Core i5 660 3.33GHz, Gigabyte GA-P55-UD3R, 4GB Kingston DDR3 1333, 750GB WD HDD, Sony Optiarc DVD RW, nVidia GTX295 1760MB, Antec 1200 Case, Delta DPS-750CB 750W PSU, Hauppauge TV Tuner, Windows XP Pro. Main Laptop: Lenovo Thinkpad T60: Core 2 T2500 2GHz, 2GB DDR2, 80GB HDD, DVD RW, Intel Graphics, Windows XP Pro. 2nd Laptop: Toshiba Satellite A200: Core Duo 1.73GHz, 2GB DDR2, 60GB HDD, DVD RW, nVidia GF Go 7300 Graphics, OpenSUSE 12.2, Fan Mod |
#36 |
so i assume a hipro made 250W unit i have from a p4 based dell is a no either. I'll check the specs on it.
edit- aside form the the 300w, all my spare PSUs are 14A or less. damn. Last edited by ratdude747; 11-18-2011 at 11:04 PM.. |
#37 |
![]() ![]() ![]() fixed the 600W noob over here had some primary side solder bridges (had to remove the primary HS to install a couple caps). fixed that, problem solved. I feel so dumb right now... ![]() ![]() ![]() Last edited by ratdude747; 11-19-2011 at 12:44 AM.. |
#38 |
good news: I got the board and recapped it. haven't had time to test.
bad news: the ****ing board doesn't fit the case at all.. 1cm ish too long and the tall registered memory conflicts with the hdd cage... any suggestions on good but cheap used case brands with front USB headers? I don't need a sound header, as my board has no such header... but it does have a frount usb header and forn usb acess would be nice. on a side note, I have matched coolers... went to a university surplus store and found a bunch of NOS aluminum vantec socket a coolers for $5 a pop... I grabbed 2 and braided the fan cables... now all i need are a couple of athon MPs... and a case that fits ![]() |
#39 |
Grumpy Old Fart
City & State: Phoenix, AZ
Line Voltage: 120V 60Hz
They do. - It's just impossible to find it.
. All the traces on the board have amp limits. That includes the ones going to the PSU connectors. . Also all the MOSFETs and IC's and so forth have TDP ratings - or something equivalent. You -can- add it all up if you care to. .
Mann-Made Global Warming. - We should be more concerned about the Intellectual Climate. - Be who you are and say what you feel, because those who mind don't matter and those who matter don't mind. - Dr Seuss - You can teach a man to fish and feed him for life, but if he can't handle sushi you must also teach him to cook. - Last edited by PCBONEZ; 11-30-2011 at 01:10 AM.. |
#40 |
BTW, the NOS coolers were theese:
http://www.vantecusa.com/gl/product/view_detail/135 they were new in box, never used. good deal for $5/cooler and no shipping? |
| Thread Tools | |
| Display Modes | |
