Just read a story about a fella who mistakenly plugged a USB cord into a USB service port, frying the mainboard.
Two instances to cite:
Scroll to jan 30 jared for actual message
http://www.complaintsboard.com/compl...zio-c6092.html
I purchased a Vizio VS42L FHDTV 10A on 4/9/08. I had been saying nothing but good things about my Vizio experience until now.
This is the situation:
As I was trying to insert a HDMI cable into the HDMI 1 port, I accidentally touched the corner of the male end of the HDMI cable to a port called the "Service Port." The "Service Port" is only 3mm distance from the HDMI port in the back of the TV and when trying to insert the HDMI cable to the HDMI port, from the side of the TV, one could easily see that the "Service Port" is directly in the way of the HDMI port. When trying to plug the HDMI cable in, I accidentally touched the "Service Port" causing my entire TV to shut down. This did not produce a smell or a "pop" noise, but apparently destroyed my TV.
And:
http://www.reddit.com/r/AskReddit/co..._hdtv_someone/
I plugged a USB cord into the 'Service Only' port and the tv instantly cut off. No popping noise, nothing. Just off and won't come back on.
EDIT: It's this TV: [1] http://www.vizio.com/vo420e.html
EDIT 2: Please upvote this to help a guy out. Hopefully it will gain exposure to the point that someone with experience with this will save my life and my wallet. I would be most appreciative!
EDIT 3: The other end was plugged into a DEAD & OFF Palm Treo smartphone (To charge).
I hope this offers any help to people troubleshooting Vizio televisions.
Vizio is apparently aware of this issue and it's not covered under warranty, however I understand their newer TV's have a cover over this port.
And:
