Old 10-30-2011, 08:32 PM   #1
agbayh
Default Random Vertical Lines on Samsung LCD TV
I'm new to these forums. I have a problem with my Samsung LCD TV. There appears vertical lines where ever there is text on the screen. See my picture attachced. I asked a local TV repairman and he said I have to replace the whole pane. Could this be fixed by replacing some kind of printed circuit board that drives the lcd panel? Thanks for all the help in advance.
agbayh is offline   Reply With Quote
Old 10-30-2011, 10:51 PM   #2
PlainBill
PlainBill's Avatar
City & State: Phoenix, AZ
Line Voltage: 120VAC 60Hz
I'm a: Hobbyist
Default Re: Random Vertical Lines on Samsung LCD TV
It could be the tcon, it could be the panel.
PlainBill
Old 10-31-2011, 12:19 PM   #3
agbayh
Thanks PlainBill. I'll try opening this unit up and see. It's already broke, what is the worse that can happen other than electricute myself. I promise not to do that. I was suspecting it to be not the panel since the lines follow the overlayed OSD type display. The adventure begins. Thanks again.
Old 10-31-2011, 01:02 PM   #4
tom66
Wants a Tesla
tom66's Avatar
City & State: Leeds
My Country: UK
Line Voltage: 230Vac 50Hz
I'm a: Student Tech
The panel displays exactly what is sent to it, as does the T-con. Neither differentiate between OSD and video.
Old 10-31-2011, 06:44 PM   #5
agbayh
OK.. Thanks. So if the vertical lines changes location depending on what is being displayed, then the problem is likely upstream and most likely to be one of the logic boards (TCON, Mainboard) and not the Panel/TCP/Driver IC assembly. This is a great forum. So many helpfull people.
Old 10-31-2011, 07:41 PM   #6
tom66
Wants a Tesla
tom66's Avatar
City & State: Leeds
My Country: UK
I'm a: Student Tech
Not quite. Consider the T-con as "part" of the LCD. It controls the addressing of the pixels. It doesn't know what an OSD is, it just tells the LCD panel to display this or that given data from the main board. The panel could still be faulty. The good news is, there is a fix when the panels go bad. It works sometimes, it involves applying a bit of tape and pressure to the connectors, but it's not always a permanent fix.
The main board could still be faulty, but I would say it is less likely.
Old 10-31-2011, 11:02 PM   #7
agbayh
Now, I understand the "shimming" quick fix for some issues with lcd lines. However if the problem is due to an intermittent connection, I would suspect that it would always be the same lines that are affected. Thanks for the susggestion though. I still like the fix suggested on one of the youtube videos. THe guy used a bat and tapped on top of the tv until the lines disappeard. If I had to do that, I would take a bat and take a full swing right in the middle of the panel.
Old 11-01-2011, 02:09 AM   #8
tom66
Wants a Tesla
tom66's Avatar
City & State: Leeds
My Country: UK
I'm a: Student Tech
It depends on the design of the panel, but different lines may be indicative of a T-con fault not a panel fault, as yes you are correct panel faults usually affect certain lines or the whole display.
Before you do decide to smash it, sell it to someone who can repair it.
Old 11-01-2011, 02:41 PM   #9
agbayh
Unless this turns out to be an unrepairable panel, I will repair it and document what I did and share my findings. Recycling is OK but I like reusing/repurposing so much more. Plus this is going to be my guinea pig project on electronic repair. Had been a software guy most of my life. It's time to really work on the fun stuff. I'll Keep you guys posted on my Adventure with this TV. I'm sure I'll have questions along the way as I dig through the anals of circuit analysis. From what I've seen on this forum, there is not a shortage of experts in the field.
Old 03-18-2012, 05:33 PM   #10
Karl D.
City & State: Danville, CA
New to this forum but have a similar problem with my 2 year old Samsung 46" LED/LCD. It has vertical colored lines. Bright ones follow the text on the screen and faint ones are on other screen areas. Other parts of the screen look fine. Please see attached pictures. Is this fixable? Is it the Tcon?
Really like the TV but phone quotes for repair (they haven't seen the TV) are $600-$800. I would buy a new one for that. Hate to throw this one away. Any help for DIY repair would be appreciated
Karl D. is offline   Reply With Quote
Old 03-18-2012, 05:41 PM   #11
retiredcaps
City & State: Canada
What is the exact model number?
Is it the Tcon?
What happens to the display if you bring up the TV setup menu?
--- begin sig file ---
--- end sig file ---
Old 03-18-2012, 06:07 PM   #12
budm
budm's Avatar
City & State: S.F. Bay area
Line Voltage: 120V 60Hz
It happens sometime in the left side, then the right side. I would try reseating the ribbon cables between the T-CON and the LCD panel first. This kind of problem is hard to be 100% sure, I would spend the money on the least expensive board first.
See the examples of what I have found and the fixes are.
File Type: jpg bad connections on the LCD panel and the flexPCB.JPG (605.9 KB, 288 views)
Old 03-19-2012, 01:22 PM   #13
anmol
City & State: Gujarat
My Country: India
@ budm,
Thanks for nice info.
wbr
anmol is offline   Reply With Quote
Old 03-19-2012, 01:24 PM   #14
Karl D.
model is UN46B6000VFXZA, Version SQ01
Still see the vertical lines. Samsung had me reset to factory settings but no change. It is out of warrantee so Samsung could not do any more.
Old 03-19-2012, 03:11 PM   #15
budm
budm's Avatar
@anmol, if you want to see more pictures of failed TV's & Monitors, go here:
http://s807.photobucket.com/profile/budm
Old 03-20-2012, 01:34 PM   #16
Nocta
City & State: Buenos Aires
My Country: Argentina
Line Voltage: 220VAC 50Hz
Make pressure where you have the lines. If it corrects, then the problem are the contacts.
I fixed some monitors by adding styrofoam to make the pressure.
Nocta is offline   Reply With Quote
Old 03-20-2012, 04:47 PM   #17
uberplasma
uberplasma's Avatar
City & State: Haliburton, Ontario
My Country: Canada
Line Voltage: 120 VAC 60 Hz
To: Karl D
OMFG!!! Craig Chaquico from Jefferson Starship - Dig the Hair !!!!
But on a serious note, that fireplace, is it used? may be causing some thermal issues like warping or "drying out" of connectors, or even causing them to shift, even if it is not searing heat, the cumulative effect of the heat over time can cause problems that may not show on the bezel.
uberplasma is offline   Reply With Quote
Old 10-04-2012, 06:40 PM   #18
justlock
City & State: Sioux Falls
My Country: United States
have the exact same problem that @agbayh has in original post photo with a samsung. Already replaced the TCON, same issue. was there a final verdict?
justlock is offline   Reply With Quote
Old 01-05-2013, 08:30 AM   #19
human_fly
City & State: Stockholm
My Country: Sweden
Trying to pick up a dead thread here...
I have the same problem with the vertical lines, not fixed.
I have tried putting pressure to the captators. Tried cleaning and reconnecting the cables between the main and t-con board.
Is the next step to order a new T-con board and if that doesn't work put the TV back where I found it; the dumpster?
Anyone found a solution to this?
human_fly is offline   Reply With Quote
Old 01-05-2013, 11:35 AM   #20
drpj23
City & State: Columbia, SC
Line Voltage: 120vac 60Hz
I'm a: Student Tech
If putting pressure on the tab bonds did not work then if cheap enough, yes try a TCON board.
Though, I would also clean the flex cables from the TCON to the panel.
If all else fails, you could sell the boards either on ebay or here.
drpj23 is offline   Reply With Quote
