#1 |
City & State: Hudson, MI
I have a Dell E177FPv that does nothing when powered and plugged into a working computer. The on/off button does nothing when pressed and shows no lights.
The two fuses (F1 and F151) on the board have been checked and show continuity. The voltage across the main capacitor reads 164.8 - 165.1 VDC. The 8 pins going to the video display board read: pin 1 (labeled +5.1V/1.6A) - 5.19 VDC pin 2 (labeled +5.1V/1.6A) - 5.20 VDC pin 3 (labeled GND) - 0 VDC pin 4 (labeled GND) - 0 VDC pin 5 (labeled NC) - 0 VDC pin 6 (labeled BRIG -A) - 4.98 VDC pin 7 (labeled BRIG -P) - 3.53 VDC pin 8 (labeled ON/OFF) - 0 VDC Q205 and Q208 were tested in circuit and are not shorted. Q1 was tested in circuit and is not shorted. I have replacements for the 8 capacitors on the power board, but have not replaced them as of yet. I was trying to determine the cause of getting nothing from the monitor when the power button was pushed. Any help would be greatly appreciated. |
#2 |
City & State: st.louis mo
Do you feel the power button clicking when you push it?
#3 |
#4 |
There are probably 5 pins that go to the front panel switch,At least 1 should show some voltage around 2 or 3 volts?
Do any of the voltages go low to 0 volts as you press the power button? |
#5 | |
Pin 1 - reads 3.20 VDC constant pushing the power button Pin 2 - reads 3.30 VDC and goes to 0 VDC while the power button is pushed, then goes back to 3.30 VDC when I let go Pin 3 - reads 3.21 VDC constant pushing the power button Pin 4 - reads 3.23 VDC constant pushing the power button Pin 5 - reads 0 VDC Pin 6 - reads 0 VDC Pin 7 - reads 0 VDC |
#6 |
Pin 2 is the on /off pin,looks like it's doing what it's suppose to do.
The power LED is not on any color? |
#7 |
#8 |
I’m getting close to running out of ideas.
It looks like there are a couple of voltage regulators on the logic board. See if there’s numbers on them to identify them, and measure the voltages. |
#9 |
City & State: California
I would consider checking the 2 voltage regulators on the logic board. I believe they are U6 and the similar 3-pin device to the left of it. Please list the voltage readings for each leg and the part number off of each device.
Oops! Alexanna beat me to it! |
#10 | |
Part No. 6J2L 1117L Measurement taken with the power board and video board connected together out of the case (they are upside down and in-accessible installed). Power hooked up but no video. U6: top pin - 5.17 VDC constant middle pin - 3.34 VDC constant bottom pin - 2.09 VDC constant to the left: top pin - 1.19 - 1.24 VDC moving middle pin - 0.38 - 0.45 VDC moving bottom pin - 0.12 - 0.14 VDC moving |
#11 | |
The input voltage on the left regulator really looks low. Can you check to see if a filter cap is in the circuit to pin 1 of the left regulator? If there is a cap involved, you should check to see if it’s shorted. |
#12 |
Update to the status:
As mentioned before, I re-capped the power board before I gave you the voltage measurements on the regulators. After that, I figured I would put the monitor back together enough to see if there was any change after the re-cap. The monitor worked perfectly including the LED. I ran upstairs to put my kids in bed and when I returned, the monitor was off with no sign of life again, no LED either. I will have to open it back up and see if possibly a fuse blew or something along those lines, or I'm back to where I started. Thanks for all the help alexanna and I'll post again probably tomorrow when I get it opened back up. |
#13 |
Update again:
I took the monitor completely apart and checked the 2 fuses, voltage across the main cap, voltage on the 8 pins to the video board, checked for shorts on Q205, Q208, and Q1, voltage on the 7 wires on the ribbon to the control board, and the voltage at the 2 regulators. Everything reads the same as before and there is NO sign of life to this monitor. I'm not sure why it worked for a little while after I reassembled it after I re-capped the power board. alexanna - I cannot follow the circuit to pin 1 of the left voltage regulator, there are no traces on the top or the bottom of the board, I would guess they are between the layers and not on either surface. I'm not sure if I can find a schematic of the board or not. Any ideas would be greatly appreciated. |
#14 |
There are times you can trace a circuit with a voltmeter.If you see the 1.9 volt on pin 1 of the regulator,Carefully probe around the board and see if you can find it at another point.
Check what voltage you have on the positive leads of the capacitors. |
#15 |
I seriously doubt this is your problem, but it won’t hurt to try.
Disconnect the flat ribbon cable from the logic board to the LCD panel; there is voltage on some of the pins so keep it insulated. Dose the behavior of the front PLED change, with the ribbon disconnected? |
#16 |
You say you recapped the board. What brand/series caps did you use? Did you verify correct polarity and are all capacitor joints properly soldered?
#17 |
City & State: US
The left regulator is U7. Is there any more text on the label? In that orientation, the top pin is input, the middle pin is output, the bottom pin ground (or adjusted). Does "moving" mean moving up and down?
Guessing that's a 1.8V regulator, which should be getting 3.3V input from U6. The regulator itself might be bad. Sometimes ceramic caps short; C64 and C65 are worth checking. Testing or just replacing the electrolytics on that board is another option. |
#18 | ||||
Going left to right, top to bottom on the picture of the video board (some of the caps have multiple designations near them): C20 0.41 - 0.44 VDC C63 0.42 - 0.45 VDC C62 1.22 - 1.25 VDC C55 5.17 VDC C54 5.17 VDC C26 0.43 - 0.46 VDC C27 3.34 VDC C13 3.34 VDC C56 3.34 VDC C38 3.34 VDC C68 0.00 VDC Quote:
#19 |
Do you have a way to check C62?
#20 |
| Thread Tools | |
| Display Modes | |
