#21 |
City & State: US
#22 | |
City & State: Phoenix, AZ
Line Voltage: 120VAC 60Hz
I'm a: Hobbyist
The power supply is actually two supplies in one. A standby supply (typically 5 volts) is always on when the TV is plugged in. That powers a standby section of the main processor. When the standby processor senses the power button being pushed, it sends a control line high, which turns on the main supply which supplies 12V, 24V, etc. PlainBill
For a number of reasons, both health and personal, I will no longer be active on this board. Any PMs asking for assistance will be ignored. Never be afraid to try something new. Remember, amateurs built the ark. Professionals built the Titanic. |
#23 |
City & State: northern illinois u.s.a.
thasts what i dont get. Im not seeing any line switching between the set bieng on and the set bieng off.
iirc "pson" is always at like 4.2v and "5vstby" is always at 5v no matter wether the set is working or not working on or off. Perhaps one of those is pulled low for a split second and im just not catching it with my meter. COuld always scope it to me sure(theres a whole other can of worms he he its been a long time since ive used my scope...) to make mattters worse, i have now lost my 24volts for interters. 24v for audio still there 12v still there. here are a ton of ps pics for your viewing pleasure. My whole deal with this has been how to figure out is the mainboard is falsely commanding the 12v and 24v sections on when first plugged in when they should be standing by, or if the ps itself is to blame and coming up on its own, where to go from there. im not going to find this ps on ebay or shopjimmy. Its driving me nuts. Last edited by cadillacman; 08-04-2011 at 11:28 PM.. |
#24 | |
i guess i could always break out the old scope to make sure but i have new issues to chase now |
#25 | ||
Banned
If you provide a larger picture of the area in the blue rectangle, I can help figure out more about this circuit. Last edited by b700029; 08-05-2011 at 03:33 AM.. |
#26 | |
I'm a: Hobbyist
PlainBill |
#27 |
well i have confirmed that the rest of the set is good,. the power supply is definately my problem.
i dug around my junk tvs, didnt find any ps exact but found one in a old proscan(32lb30qd)with a simular pinout.(heres one like it, several of these on feebay) http://cgi.ebay.com/Proscan-Megmeet-...item27bd1c7a3b i carefully marked my terminals, repinned the connectors to match. when the tv is plugged in it goes into standby everytime like it should, powers up and down as commanded fine. Im going to let it run awhile and recheck but yeah im thinking i definately have a bum supply. Now to do some detective work and find out wtf is up with it. or leave this rigged krap mess in there lol.. Last edited by cadillacman; 08-05-2011 at 06:33 PM.. |
#28 | |
Id really like to fix this ps if i can, im not going to learn anything if i just replace it. the "blue wire" you added- there is in face a jumper ont he other side of the board you were correct there. i have been discharging the filter caps every time is pull this ps, it was after the last time of doing that that the 12 doesent work, so mabye i took something else out. Im doing it old school just shorting em and letting em pop a little. Nothing worse than getting bit by a cap or by an anode on a crt monitor... i know that hurts from experience.. Last edited by cadillacman; 08-05-2011 at 07:04 PM.. |
#29 |
City & State: US
Are the light blue caps the new ones? What brand and series are they? (The thinking being that they look like normal ESR, general purpose, 85 degree types, and as you replace more, the problem gets worse. Whether a ripple problem would show on a meter depends on the meter.)
#30 |
yeah they are my cheapie arcade monitor caps, xicon brand. i am out of the good ones at the moment(BEEN BOUNCING AROUND FROM THE LOW ESR XICONS, PANSSONICS, SAMXONS, whatever lol im not really a brand nazi if it works it works.
WIth these i figured theyd be good enough to test with, have gotten away with it in the past mabye this set is where my luck ends. Last edited by cadillacman; 08-05-2011 at 08:47 PM.. |
#31 |
Well i mightve been good if i wasnt such an idiot.
I did go ahead and check the 5v and 12v fets, not shorted checking good. in the 24v primary side, i found arc damage to a polypropelene capacitor (c38). this trace ends up all over the place so who knows what all i fried. For now, shes going to rock this new proscan power supply. These ps issues seem to be beyond my skill level unfortunately. If any of you guys want this to tinker with yourself let me know. heres more pics, having a hard time getting the camera closer. My wife has a canon 50d but i have to steal it sometime shes not around and i know i can get great macro shots with that. |
#32 |
its been 10 days, tv has been used every day for about an hour in the morning. and several hours every evening.
while i would not reccomend this hack to everybody as you do have to pay particular attention when you repin and swap out terminals, and who knows if this ps s rated anywhere near the same watts as the original, but in my case this has worked out great! |
#33 |
Hi guys, i have another problem, i buyed 6 month ago this LCD TV and a over tension on AC line broke my mainboard, now i buy a new main board but is not the same, my original main board have a serial number: 002-fv40-2810-00r and the new, have: 002-fv40-2812-00r, in the service center an engineer told me that fits for my Tv, but isnt true, because on the TCON conector the first have 36 pin, the second have 40 pin, when a put on my tv, all working good, but the image is distorted, only see the dark sides, now my question is, have any body a schematic of this TV?, is quiet hard to my find it on Google. Could any body help me pl?. Thanks.
#34 |
#35 |
you need to get the proper board and you wont fine one.
these are fantastic tvs for cheap but theres just not parts or info available for them. My power supply retrofit is still working great, btw. |
#36 |
Just to followup its been almost a year and this set is still working great with the retrofit. I use the set daily for about two hours a night.
| Thread Tools | |
| Display Modes | |
