#1 |
City & State: Kitchener, ontario
My Country: Canada
Line Voltage: 120VAC 60Hz
Hi all new here, hoping to find some help with a monitor I trying to repair. This Monitor came in with power led not lighting at all on the front panel, when I checked the Power supply I can't find any faulty components. I checked the cap's all are good non leaking or swollen ever DCR & ESR are good. I checked transistors and resistors and all seem good. When check voltages I have 12v & 5v. not exactly sure where to go from here.
Has anyone seen this problem before? Any ideas would be helpful. Thanks |
#2 |
City & State: California
Since you've provided no photos of your boards, then that's equivalent to asking members to guess at what your problem is. Since you're getting no power light, yet getting 5V and 12V outputs, I'm thinking a failed reset controller. Usually labelled U405 or U406 on the logic board. If you remove this controller, it should power up. Again, due to lack of photos, proceed at your own risk.
#3 |
My Country: Canada
Thanks jetadm123 I will post pics shortly.
#4 |
City & State: Harrogate UK
Another 'sharper' picture of the Logic board may be very helpful,as that looks to be where the fault lies.
#5 |
My Country: Canada
These images should be better
#6 |
My Country: Canada
I tried to upload new pics but it fails every time i try. I will try again in a bit. Thanks again.
#7 |
My Country: Canada
Hi jetadm123, I apologize for my lack of photos again. However I have followed your suggestion and removed U406 and as you said the monitor did pwr on, thanks you for that. Now that I have determined that U406 is the issue do I just replace the IC? or does it need to be re programmed? I was looking at the Datasheet and because of the type of chip that it is I am not sure of the replacement method. Again I really appreciate your help with this unit. Thanks
#8 |
The part in question is a MAX810STRG reset controller. It is not programmed, but a generic part and can be easily purchased through many sources. Others that have removed this controller have not had any further problems. However, if you feel you must/should replace it, then it's rated at a threshold of 2.93V and can be purchased through digikey.com:
http://search.digikey.com/scripts/Dk...0SEUR%2BTCT-ND |
#9 | |
My Country: Canada
Again I know I should provide a pic but every time I try to upoad pics I get file upload failed message. Not sure what I am doing wrong. Any thought on this? Is there another way for me to send you the pic? Thank you very much! |
#10 |
Unfortunately, what you removed is an eeprom. The reset controller is a 3-legged device. The link I provided has a datasheet for it. What was U405?
#11 |
My Country: Canada
Can't find a U405, I got pics this time.
#12 |
I can barely make it out. It looks like U405 was printed on the circuit board, but was not used. Not sure why removing U406 allowed the monitor to work. This possibly could be a eeprom that stores user settings made using the on screen display (OSD) menu. You can verify by changing a setting on the menu, turning the monitor off for a minute and back on to see if the menu setting was saved.
#13 |
My Country: Canada
Thanks for all your help. I reinstalled the U406 and everything works now. Not sure if there was a bad solder joint, but it works now. Thanks again
| Thread Tools | |
| Display Modes | |
