Go Back   Badcaps Forums > Electronics Theory and Troubleshooting > Troubleshooting Laptops & Notebooks
Old 07-16-2011, 08:34 PM   #1
unlockdev
Default Pavilion dv5 White Screen problem
Pavilion dv5 White Screen and caps lock flashing
unlockdev is offline   Reply With Quote
Old 07-19-2011, 08:45 AM   #2
mattbrad2
Default Re: Pavilion dv5 White Screen problem
Caps lock flashing is a video problem. I had one a while back and ended up replacing the motherboard. Spent way too much time trying to fix that one. You can always try and reflow the GPU and / or built on video ram.
mattbrad2 is offline   Reply With Quote
Old 07-19-2011, 05:58 PM   #3
unlockdev
Red face Re: Pavilion dv5 White Screen problem
the white screen is lcd problem and still flashing i hav other dv5 back screen and caps lock flashing i try to reflow the bga chip but no lock
problem i think the video gpu is dead
Old 07-19-2011, 10:17 PM   #4
gretti
It most likely is the GPU. I have had the same issue with a white screen on a DV5 with the AMD GPU and a reflow worked. I have also had no video with the caps lock flashing caused by a bad AMD processor. Be sure to test with a compatible CPU. Also make sure that you test the system on an external monitor with the LCD cable disconnected from the mainboard, to rule out a shorted cable.
gretti is offline   Reply With Quote
Old 07-21-2011, 09:41 PM   #5
mattbrad2
DVx series shouldn't have GPU / South Bridge problems. Most common problems in these are Texas Instruments power management IC's. Believe me, I've tried GPU reflows that normally work on the older DVxxxx series all the time but have had zero luck on these new ones. That being said, the caps lock flashing is definitely an HP code for video malfunction. Like I said earlier - best not waste your time on this one.
Old 07-24-2011, 10:08 AM   #6
infringer
Badcaps Member
My Country: United Frickin States
Line Voltage: 120VAC 60Hz
I'm a: Hobbyist Tech
If you figure the problem out is it really a waste of time from this thread I have gotten 2 things to look for or at on my Acer 5100 see if there are any similar Texas Instruments power management IC's that are bad and check to see if the video ram on board needs reflow dunno exact specifics...
I read somewhere that a bad connection on the back of your screen the cabling that actually connects to the to of the monitor on the back is plugged in crooked or not all the way can cause issues...
Keep at it let us know how your progress is coming this seems like a very common symptom amongst laptops not brand specific so if we iron this one out it would be a major feat!
infringer is offline   Reply With Quote
