#1 |
I have two broken VA912 with same symptom of black screen.
I replaced the caps on the inverter board for the first one and it then worked right away. However, when I did the same on the second one, symptoms remains. I swapped the parts with the first monitor. I can conclude that it is due to the main logic board. I can see the image when I shine light on the LCD panel. It has to be the backlight not coming on. I examined the board and could not find amy bulged caps. Any pointer where I should look or caps that I should change? |
#2 | |
City & State: Canada
We want picture as close to 2000x2000 and like this. http://www.badcaps.net/forum/showpos...94&postcount=1 2) Do you have a multimeter? If yes, there might be a blown fuse in the inverter section of the board. Or a shorted mosfet or transistor. Also, you can measure the backlight off/on pin to see if the voltage changes when you press the on/off button.
--- begin sig file --- If you are new to this forum, we can help a lot more if you please post clear focused pictures (max resolution 2000x2000 and 2MB) of your boards using the manage attachments button so they are hosted here. Information and picture clarity compositions should look like this post. We respectfully ask that you make some time and effort to read some of the guides available for basic troubleshooting. After you have read through them, then ask clarification questions or report your findings. Please do not post inline and offsite as they slow down the loading of pages. --- end sig file --- Last edited by retiredcaps; 05-07-2011 at 11:51 AM.. |
#3 |
The inverter board and the logic board are in the picture.
The inverter board has no problem as it works when coupled with a good logic board. I found the schematics around the connector between the two boards (attached). Pins 1,2 are 12Vcc, Pins 3,4 are GND and Pins 5,6 are 5DVCC and all appear normal. I therefore tried to measure pin 7 and pin 8 in the connector. I doesn't seem to get a proper reading for both pins no matter I tried a good or bad logic board (zero readings). But I am pretty sure the good logic board works as I can hear the soft high pitch noise from the inverter while the bad logic board doesn't. What should I expect with those pins? |
#4 |
City & State: Harrogate UK
[QUOTE=sylvester328;164181]I have two broken VA912 with same symptom of black screen.
However, when I did the same on the second one, symptoms remains. I swapped the parts with the first monitor. I can conclude that it is due to the main logic board. I can see the image when I shine light on the LCD panel. It has to be the backlight not coming on. QUOTE] You may be getting confused between Logic and combined PSU/Inverter !!! If you can see an Image then the LOGIC board( the one on the right in your picture) is NOT faulty.The problem is with the PSU/Inverter. |
#5 |
Measure the resistance of the secondary windings on the Inverter Transformer,the ones at each end.
#6 | |
I am now suspecting the 5DVCC to 3DVCC regulator circuit on the logic board. Will test it tomorrow. EDIT: Hmm.. No. It can't be 5DVCC to 3DVCC either. The RTD2523 takes 3.3VDC and 2.5VDC as well. That parts seems working (as I can see the image). ![]() Last edited by sylvester328; 05-27-2011 at 04:47 AM.. |
#7 | |
City & State: Phoenix, AZ
Line Voltage: 120VAC 60Hz
I'm a: Hobbyist
The area you are interested in is pins 7 and 8 of CN1, and the signal lines VRMT and VBRI. Those control respectively the On/Off and Brightness signals to the inverter. And what is more, there is often a third line from the processor chip which switches power to the LCD panel, and often a fourth which controls the power LED. Since you can see a dim display on the 'B' card it is likely all of those outputs are correct, it's the support components that must be checked. PlainBill
For a number of reasons, both health and personal, I will no longer be active on this board. Any PMs asking for assistance will be ignored. Never be afraid to try something new. Remember, amateurs built the ark. Professionals built the Titanic. |
| Thread Tools | |
| Display Modes | |
