Old 05-06-2011, 12:35 PM   #1
Houston1381
Default sony kdl-46S4100 dark, no sound, inverter?
I have a sony kdl-46S4100 that one day went dark,
no sound,
powers on by the remote,
has a click at power on,
power light glows steady,
no backlight that I can see
no heat detected anywhere
remote fails to do anything after power on
no sound, no smell
Ive been swapping parts from ebay trying one different board at a time
power supply board - no change
main board - no change
I have a salvaged tcon board and inverter board that i have not tried yet.
Anyone have a beginners troubleshoot algorithm that I can do with a multimeter? Sorry in advance, I'm trying to learn this as I go.
Houston1381 is offline   Reply With Quote
Old 05-06-2011, 02:16 PM   #2
Village Electronics
OldPro
Village Electronics's Avatar
Default Re: sony kdl-46S4100 dark, no sound, inverter?
no sound,
no sound, no smell
Blink Code?
Village Electronics is offline   Reply With Quote
Old 05-06-2011, 02:51 PM   #3
Houston1381
No blinks - this model does not do that
Old 05-06-2011, 06:29 PM   #4
Village Electronics
OldPro
You are correct. It does not do that.
Old 05-06-2011, 09:08 PM   #5
cadiman
City & State: chesterland Ohio
Faulty panel or t-con.
Could be either with this panel.
check for 12vdc or so at t-con board fuse (very small near plug).
Grey panel (some backlight trying to get through) could mean no power to t-con.
Run through inputs with dvd plyer hooked up and listen for audio.
Just a few ideas for you.
cadiman is offline   Reply With Quote
Old 05-08-2011, 08:21 AM   #6
Houston1381
Solved!
Thanks to cadiman for the tip - I swapped out the salvaged t-con board and it started working. I am still looking for the fuse in case this one fails too.
My process was:
take the back off and look for any bad caps anywhere on the PS or main board - dead end
research web for known issues -couldnt find any exactly like mine - most had sound or some other first symptom
swap out power supply with a ps from ebay - dead end
found another guy on ebay selling the guts of a tv like mine with cracked screen
swap out main board - dead end
put all oriiginal parts back in between attempts
buy a correct screwdriver that loosens really small phillips screws without stripping
remove tcon board
jerked out the ribbon cable from the board and tv - then found there was a little tab that popped up that pinched down the cable - luckily I didnt destroy the ribbon
test
shout up the stairs that I fixed my tv
Thanks for the tip and the forum
Old 05-08-2011, 08:14 PM   #7
cadiman
You would have better luck using a microscope than any type of eyeglasses to find the fuse on the t-con. should be next to the input plug. The board will be marked F with a number after it like (F101). F for fuse. R for resister , D for diode etc.
If the fuse is blown on the t-con do not jump it with solder.
Glad we could help you!
Old 11-10-2011, 05:48 PM   #8
chums12
I also have a sony kdl 46s4100 and have the same exact problems that Houston1381 had. So i tried swapping the t-con board with a salvaged one but nothing happen. I was wondering if someone can please help me.
chums12 is offline   Reply With Quote
