Old 04-15-2011, 05:42 PM   #1
orin
Default Vizio V042L, No picture, Has sound
I am new to the forum, I mostly read the posts and have repaired a Samsung 32Ē LCD with the information from this forum. (Bad Power supply)
My 42Ē Visio picture went out, but I still have sound. I tested the power supply and have all the correct voltageís 5V, 12V, 24V,
When I turn the TV on the Visio light turns to white and I have sound. The master inverter led lights up for a few seconds then goes out. I started checking the mosfets on the inverters and the master inverter checked out fine. But when I started checking the mosfets on the slave inverter the TV came on with a flickering screen. Would it be safe to say the slave inverter is my problem?
If needed I will post pictures of the inverters
Would appreciate any help you can provide
Orin
orin is offline   Reply With Quote
Old 04-15-2011, 06:46 PM   #2
PlainBill
PlainBill's Avatar
City & State: Phoenix, AZ
Line Voltage: 120VAC 60Hz
I'm a: Hobbyist
Default Re: Vizio V042L, No picture, Has sound
Orin
It's hard to tell without pictures, but that could be one of the inverter sets by LG that are causing problems.
PlainBill
Old 04-15-2011, 07:47 PM   #3
orin
PlainBill
Thank you for your reply
I have posted two pictures of the inverters
The TV is still coming on but itís very faded on the left side of the screen (Slave inverter side)
And the right side (Master inverter) is flickering but has good picture.
I am leaving the TV on to see if it loses the picture when itís good and warm.
Orin
Old 04-15-2011, 09:30 PM   #4
PlainBill
PlainBill's Avatar
I'm a: Hobbyist
PlainBill
Orin
Bingo!!! That's the culprit. If you look at the 32 pin IC on the slave, something doesn't look too healthy in the area of pin 26.
PlainBill
Old 04-22-2011, 07:36 PM   #5
orin
PlainBill,
I ordered the Master and Slave inverters and I am back up and running
Thank you
I very much appreciate all the help you have gave me
Orin
Old 01-01-2012, 09:39 PM   #6
djsmith
Solder Fumes
City & State: Salt Lake City, UT
Orin, could you post a link to the replacement parts (you replaced both boards right)?
I think I have the same problem.
Thanks!
djsmith is offline   Reply With Quote
Old 11-01-2012, 12:39 PM   #7
hammerdog
City & State: ventura
Well, one of my campus buildings had there lobby Visio FO42 TV go bad. So, quick search and I found thuis thread. Quick look at my boards I had the exact same IC blow but on my Master inverter board. I also had a blown cap. The campus was ready trash the TV and to drop $1500 for a new one. I found a set of new Inverters for $100. I let you know if it works out but all indications point to the obvious. Thanks for this forum!!
hammerdog is offline   Reply With Quote
Old 11-01-2012, 01:34 PM   #8
Dgtech
E. Technician
Dgtech's Avatar
City & State: Pittsburgh
My Country: Steeler
Line Voltage: 120 VAC 60Hz
Nice job!!!
An even cheaper fix is to replace the caps and that blown IC Chip for about $10... that is if you can do the repair or you know someone who can do the repair. Either way, you're saving a lot on a 42 inch TV!!!
Dgtech is offline   Reply With Quote
Badcaps.net Technical Forums © 2003 - 2017
