Old 03-04-2011, 06:23 AM   #1
Welchs101
City & State: Cary, NC
Line Voltage: 120V 60Hz
Default Emerson LD195EMX shows colors on screen when plugged in
I have an Emerson TV Model LD195EMX. When you plug the unit it it shows some text on the screen (shows the text "Digital Television) and then it begins a loop showing a red screen, blue screen, green screen, white screen...........and it just keeps doing this.
I am not a TV repair person......but i have worked on a few LCD monitors but i am not an expert.
Note: Dont know if this is helpful or not but the "on/off" button does not seem to work. WHen i plug unit in it is "already" on and when i try to turn it off with the on/off switch it has no effect.
Note: I found a troubleshooting manual for this unit online but i am not sure how to proceed.......since i cant find my symptoms in the manual.
http://www.tvrepairtips.org/files/ti..._pdf_12349.pdf
any help will be appreciated.
Welchs101 is offline   Reply With Quote
Old 03-04-2011, 07:14 AM   #2
ecking767
City & State: Fort lauderdale Florida
Line Voltage: 120vac 60Hz
Default Re: Emerson LD195EMX shows colors on screen when plugged in
the first thing i will try is to unplug the off/on panel, there maybe a short on one or more of the buttons.
if that doesn't fix the problem I will look into the firmware
ecking767 is offline   Reply With Quote
Old 03-04-2011, 07:15 AM   #3
Scenic
o.O
Scenic's Avatar
City & State: Duisburg
My Country: Germany
Line Voltage: 230VAC 50Hz
it seems to do some sort of self test?!
the changing colors is what my ooold HP L1820 (Acer OEM) LCD Monitor does if there's no signal..
The USA have Barack Obama, Bob Hope, Stevie Wonder and Jonny Cash.
We have Angela Merkel, no hope, no wonder, no cash.
Scenic is offline   Reply With Quote
Old 03-04-2011, 07:34 AM   #4
Welchs101
i disconected the on/off switch panel from the tv...........so the on/off, reset, and other functions that are on that control panel are totally removed from the tv..............i then plugged power to the tv and the same thing happens. No change.
Any other thoughts?
Old 03-04-2011, 07:46 AM   #5
Th3_uN1Qu3
Believe in
City & State: Bucharest
My Country: Romania
You're stuck in some kind of service mode. Most likely you have a bad EEPROM, you're going to need to reflash it. Equipment to do that isn't exactly cheap - for a one-off better look if anyone is selling preprogrammed chips.
Originally Posted by PeteS in CA View Post
A working TV? How boring!
Th3_uN1Qu3 is offline   Reply With Quote
Old 03-04-2011, 10:39 AM   #6
alexanna
alexanna's Avatar
City & State: st.louis mo
I very quickly read through the service manual link you provided, it doesnít describe your problem exactly but it does describe a service mode that is accessed with the remote control. There is something in there about removing or cutting a plastic cover on the remote to get to a service button. To exit the service mode they say to power the set off with the remote control.
If you donít have the original remote you could try to program a universal remote to turn the set off.
I have no idea if thatís the problem your having, or if it will work but it canít hurt to try it.
alexanna is offline   Reply With Quote
Old 03-04-2011, 09:28 PM   #7
mbates14
My issue has never been the equipment.
its finding a good hex or bin file.
mbates14 is offline   Reply With Quote
Old 03-05-2011, 03:57 AM   #8
Scenic
o.O
Scenic's Avatar
My Country: Germany
no luck here either :|
http://dump.elektroda.pl/main.php?d_start=2150
main page
Old 04-25-2012, 10:13 PM   #9
vampyyri1123
City & State: CA
My Country: LA
this is how you fix it for anybody having trouble with it... if you have the original remote what you do is you keep the tv on and with the remote u press up and down on the remote controller... not the channel or vol buttons but the ones that control dvds... unplug and replug the tv in and BAM there you go.. i tried it and it worked great... give feedback if it doesnt work and ill try to help you
vampyyri1123 is offline   Reply With Quote
Old 05-24-2012, 11:59 PM   #10
Keri M. Parrot
City & State: Tustoned,AZ
My Country: !Amerika!
vampyyri1123-You are great,
I almost went out to buy a boat and a lake because I had an expensive art device and got an estimate from a local place that advertises Resonable Prices! and asked $175 to replace the main circuit board. They did get my $15 to get an estimate.
THANK YOU
Keri M. Parrot is offline   Reply With Quote
Old 03-08-2013, 04:14 AM   #11
Mitchell00
City & State: Carolinas
Lightbulb Re: Emerson LD195EMX shows colors on screen when plugged in
I had the exact same thing to happen to my tv, exact same model, and i read vampy's message about pressing the up and down buttons on the dvd button section of the remote and it had no effect, but it got me to start pressing other combs. of buttons and found that pressing the left and right buttons in the dvd section of the remote fixed it and got it back to a picture screen, so i got on here and went through making a user name and password just so i could put up a post, so hopefully this helps anyone else who needs it, so if up/down doesnt work try left/right..
Mitchell00 is offline   Reply With Quote
Old 02-23-2014, 03:10 PM   #12
marshabrady
City & State: Sanford Maine
I'm having this same issue with the screen changing colors. Does anyone know how to fix this problem if I no longer have the original remote?
marshabrady is offline   Reply With Quote
Old 02-25-2014, 09:40 PM   #13
hoangmai
City & State: seattle, washington
My Country: usa
I would suggest try to use a universal remote .
hoangmai is offline   Reply With Quote
Old 03-08-2015, 11:32 AM   #14
troya770
City & State: Virginia
I got mine straight with a Direct TV remote.I just pushed the side to side buttons next to the Select button and it popped back on.
troya770 is offline   Reply With Quote
Old 12-23-2016, 03:42 PM   #15
nera
City & State: Berkeley
My Country: United States
I have the same problem. I didn't have the original remote, but ordered a replacement remote. However when trying the solution, it didn't work. Do you have any other suggestions? Thanks.
nera is offline   Reply With Quote
Badcaps.net Technical Forums © 2003 - 2017
