Go Back   Badcaps Forums > Electronics Theory and Troubleshooting > General Electronics
Old 03-03-2011, 09:45 PM   #1
mockingbird
mockingbird's Avatar
Send a message via AIM to mockingbird
Default How many 1U servers can I run with 20 amps?
I'm thinking of setting up an older 1U server in someone's rack, but he pays for a maximum of 20 amps and I am concerned that it will overloaded.
OTOH, with two 1U servers already running, the meter is only showing 2A.
Let's assume there will be five servers with 4 harddrives on each, let's say each server is drawing no more than 300W. All the information I've read so far leads me to believe it should not be a problem, but what concerns me is that with video cards, people suggest there should be two rails that supply at least 15A each. If one high end video card can draw 30 amps, how can these servers be drawing such a minute amount?
...Their plight, in fact is even worse, they don't realize that they're cantonists, they think they're free men. What a slavery that is - to confuse slavery for light, and bitter darkness for bright light.
-Rabbi Menachem Mendel Schneersohn
mockingbird is offline   Reply With Quote
Old 03-03-2011, 09:51 PM   #2
Th3_uN1Qu3
On my level
Th3_uN1Qu3's Avatar
City & State: Bucharest
My Country: Romania
Line Voltage: 230VAC 50Hz
I'm a: Student Tech
Send a message via Yahoo to Th3_uN1Qu3
Default Re: How many 1U servers can I run with 20 amps?
A server does not have a high-end video card. Actually, some have no video card at all. Also there isn't a whole lot of dissipation capability in a 1U case, so if it's 1U you can bet it's power efficient. Or has some darn noisy fans.
Originally Posted by PeteS in CA View Post
A working TV? How boring!
Th3_uN1Qu3 is offline   Reply With Quote
Old 03-03-2011, 10:12 PM   #3
mockingbird
So you're telling me that these videocards really draw 30 amps when I'm playing Movie Battles II maxxed out at 1280x1024 and chugging away at 30fps? I have a Radeon 2900XT, the thing is a power hog I hear, though I do have a 750W PSU in that PC.
Old 03-03-2011, 11:23 PM   #4
Th3_uN1Qu3
On my level
Th3_uN1Qu3's Avatar
My Country: Romania
I'm a: Student Tech
12x30=480w. Not too hard to believe. Tho i believe it applies to today's high end, the 2900 is quite old.
A quick google reveals a consumption of about 350w for the 2900.
Old 03-04-2011, 09:46 AM   #5
severach
City & State: Michigan
Line Voltage: 120VAC 60Hz
I'm a: Hobbyist Tech
A Kill A Watt is a cheap way to get an instant answer.
severach is offline   Reply With Quote
Old 03-04-2011, 04:25 PM   #6
smason
City & State: Alberta
My Country: Canada
Line Voltage: 120VAC 61Hz
WTF? A video card drawing 30A? Holy excrement!
I'm not a gamer so I normally ignore high end video cards, but 30A?
A 100W 20 metre HF transmitter barely gets to 20A.
smason is offline   Reply With Quote
Old 03-04-2011, 05:15 PM   #7
Krankshaft
Krankshaft's Avatar
City & State: New Jersey, USA
A thing to mention the Kilawatt meters aren't true RMS.
They claim to be on the package but when I hooked one up to my modified sine wave (square wave) UPS inverter and pulled the plug it registered 0 volts. I commend it for giving up and not registering some fictional voltage that is too low but I wish they wouldn't have lied on the package.
Back on topic I believe you're referring to video card current draw from the PSU?
Yes at full load they can draw up to their max current it depends on how graphics intensive the game is. A graphics card is just a GPU like a CPU the more it's loaded the more current it will draw.
But servers don't have high end graphics cards they're not designed for that.
Krankshaft is offline   Reply With Quote
Old 03-16-2011, 04:28 AM   #8
santel
No possible way a video card draw 30 Amps, that would be like 500Watts + cpu etc etc = 800Watts. will require a 1000Watts supply or more.
santel is offline   Reply With Quote
Old 03-16-2011, 05:11 AM   #9
PlainBill
PlainBill's Avatar
City & State: Phoenix, AZ
I'm a: Hobbyist
You're getting confused between current drawn from the AC line (at 120 VAC) and current drawn by a video card (at 12VDC). If your video card is drawing 30 Amps, that's 360 Watts. Assuming the power supply is 80% efficient, that's less than 4 Amp from the AC line.
PlainBill
Old 03-16-2011, 08:00 AM   #10
PCBONEZ
Grumpy Old Fart
PCBONEZ's Avatar
Line Voltage: 120V 60Hz
TDP of CPU(s) [in watts] x 1.25 [The 1.25 is for VRM efficiency/losses]
+plus+
5 to 15 watts/stick of RAM depending on what kind it is. [Google it]
+plus+
20 watts/HDD [typical watts on spin-up from dead stop]
+plus+
35 watts for basic mobo power [approximation used in most PSU calculators]
+plus+
10 watts/add-in card [general slot power is +5v, slots limited to 2 amp on +5v]
+plus+
5 watts/LAN chip [wild guess]
-divided by-
PSU effieciency
=Equals=
Pretty Darned Close [in watts]
Skipped Opticals because when in use the HDDs are already spun-up from a dead stop and using much less than the 20 watts.
Mann-Made Global Warming.
- Dr Seuss
PCBONEZ is offline   Reply With Quote
Old 03-16-2011, 08:08 AM   #11
PCBONEZ
Grumpy Old Fart
PCBONEZ's Avatar
The steady state condition is not what you should look at.
Look at what they pull when starting up.....
