Go Back   Badcaps Forums > Battling the Bad Capacitors > Identifying Bad Capacitors and Related Symptoms
Old 03-02-2011, 06:00 PM   #1
Hornpipe2
Default PCChips M810D V7.5C - salvageable?
I scored this gray-box PC off Freecycle. It's got a Dynex 350W power supply and the mobo is a PCChips M810D V7.5C. The member warned me that the computer wouldn't turn on any more but I thought I'd scoop it up anyway in case it had any usable parts.
Opening the case and I'm greeted by this...
Overall I see five bulging caps on the board. with another 3 suspect because they're the same as two of the bad ones. And then there's the burnt little chips on here.
What do you think the odds are of the CPU or motherboard surviving this and functioning properly if I replaced everything?
Hornpipe2 is offline   Reply With Quote
Old 03-02-2011, 06:46 PM   #2
370forlife
Large Marge
370forlife's Avatar
City & State: Kalamazoo, MI
My Country: United States
Line Voltage: 0-120VAC 60Hz
I'm a: Hobbyist Tech
Send a message via AIM to 370forlife
Default Re: PCChips M810D V7.5C - salvageable?
Pretty good. There are quite a few threads on here depicting replacing fried VRM components with success.
Originally Posted by JFK
The American, by nature, is optimistic. He is experimental, an inventor and a builder who builds best when called upon to build greatly
370forlife is offline   Reply With Quote
Old 03-02-2011, 07:06 PM   #3
c_hegge
Unknown
c_hegge's Avatar
My Country: Australia
Line Voltage: 240V 50Hz
Agreed. If you replace both the Caps and the MOSFETS, the board will probably be OK. I've done it myself once. http://www.badcaps.net/forum/showthread.php?t=12789
Main PC: Core i5 660 3.33GHz, Gigabyte GA-P55-UD3R, 4GB Kingston DDR3 1333, 750GB WD HDD, Sony Optiarc DVD RW, nVidia GTX295 1760MB, Antec 1200 Case, Delta DPS-750CB 750W PSU, Hauppauge TV Tuner, Windows XP Pro.
Main Laptop: Lenovo Thinkpad T60: Core 2 T2500 2GHz, 2GB DDR2, 80GB HDD, DVD RW, Intel Graphics, Windows XP Pro.
2nd Laptop: Toshiba Satellite A200: Core Duo 1.73GHz, 2GB DDR2, 60GB HDD, DVD RW, nVidia GF Go 7300 Graphics, OpenSUSE 12.2, Fan Mod
c_hegge is offline   Reply With Quote
Old 03-11-2011, 04:54 PM   #4
TheLaw
City & State: New Jersey
Whoa. Thru-hole resistors on a motherboard!?
As long as you know the model of the power mosfet, I'd say sure. I think some of the black on the board is more residue than burn.
TheLaw is offline   Reply With Quote
Old 03-11-2011, 06:11 PM   #5
Scenic
o.O
Scenic's Avatar
City & State: Duisburg
My Country: Germany
Line Voltage: 230VAC 50Hz
^ those are 0 ohm resistors. the usual ECS deal.. notice how the spots for them are labeled "F" for fuse..
The USA have Barack Obama, Bob Hope, Stevie Wonder and Jonny Cash.
We have Angela Merkel, no hope, no wonder, no cash.
Scenic is offline   Reply With Quote
Old 03-12-2011, 09:12 AM   #6
TheLaw
Yeah I know they are 0ohm....just interesting because you never see too much thru-hole stuff on motherboards (besides some caps).
Oh and how could I have forgotten, fuses..pssshh...they're so overrated
Old 03-23-2011, 04:55 AM   #7
Agent24
Fuhjyyu Killer
Agent24's Avatar
City & State: Behind a soldering iron
My Country: New Zealand
Line Voltage: 230V AC 50Hz
I think you will find most if not all non-SMD parts on motherboards to use plated through holes...
Agent24 is offline   Reply With Quote
