Go Back   Badcaps Forums > Electronics Theory and Troubleshooting > General Electronics
Old 01-15-2011, 12:06 PM   #1
billy66
City & State: Dracut, MA USA
Default Zener diode test question
I have a surface mount zener diode and I want to make sure it is good/bad. I believe it may be shorted, but not sure. Here is the data sheet:
http://http://www.taitroncomponents.com/catalog/Datasheet/TZT2.0W.pdf
The diode is part number: TZT7.5YW
When testing resistance across pins 1-3... I get 21 ohms... Max Zener Impedence is listed as 23... does this mean I'm ok? Or am I grossly misunderstanding this?
Thanks for any and all help
billy66 is offline   Reply With Quote
Old 01-15-2011, 01:41 PM   #2
Th3_uN1Qu3
On my level
Th3_uN1Qu3's Avatar
City & State: Bucharest
My Country: Romania
Line Voltage: 230VAC 50Hz
I'm a: Student Tech
Send a message via Yahoo to Th3_uN1Qu3
Default Re: Zener diode test question
So it's a 7.5 volt. Remove it from the board and hook it up to a 12v power supply with a 1k resistor in series. Resistor goes from cathode (pin 3 in this case) to +12v, anode goes to ground. If you don't get 7.5 volts across the diode in this arrangement then it is bad.
Originally Posted by PeteS in CA View Post
A working TV? How boring!
Th3_uN1Qu3 is offline   Reply With Quote
Old 01-16-2011, 04:41 AM   #3
billy66
Thanks, I'll give that a try... if I can dig up a power supply.
Old 01-16-2011, 07:38 AM   #4
billy66
.2V, it's bad... thanks for the help.
Old 01-16-2011, 09:18 AM   #5
Th3_uN1Qu3
On my level
Th3_uN1Qu3's Avatar
My Country: Romania
I'm a: Student Tech
.2v is consistent with your 21 ohm resistance reading (apply voltage divider rule). It's bad alright.
Old 01-16-2011, 12:27 PM   #6
billy66
Will this work in its place:
http://www.mouser.com/Search/Product...1-BZX84C7V5W-F
Old 01-16-2011, 01:11 PM   #7
Th3_uN1Qu3
On my level
Th3_uN1Qu3's Avatar
My Country: Romania
I'm a: Student Tech
Yup, will do.
Old 01-16-2011, 01:17 PM   #8
billy66
Thanks... I thought so, just ordered.
Old 01-26-2011, 03:29 PM   #9
billy66
Worked perfect, thanks!
