#1 |
City & State: Latvia
Another LCD display with bad caps.
Symptoms: Dead, doesn't power on Board: 715L1142-3-AUE year~2005 PC170027.jpg Fix: Replace bad Elite caps C814,C185 (16V 1000uF). Seems they fail sooner because are too close to heatsinks. It would be better to solder them not so close. Didn't replace the shield maybe it will help to stay cooler, is it safe? . PC170028.jpg PC170030.jpg ![]() |
#2 |
You did not include a picture of the shield in question, so it's hard to be definitive. However, since a monitor is typically enclosed in plastic there is no danger of physical harm. However, shielding is used to prevent interference with other electrical devices, especially radios, cordless phones, cell phones and the like. You know, the FCC notice that we do not read in the manual!
#3 | |
City & State: Owensboro, KY.
Line Voltage: 120VAC 60Hz
Caps are effected by heat yes, always replace caps in high heat areas with caps less prone to failure due to heat. Provided shielding is just that and rarely can be replaced with better shielding as far as heat goes, though adding some type of fan can help a alot. |
#4 |
Fuhjyyu Killer
City & State: Behind a soldering iron
My Country: New Zealand
Line Voltage: 230V AC 50Hz
Mmm It's stupid how they put them above the heatsinks, so more heat can rise into them.
Maybe they do it to make sure the capacitors die off quickly? There's probably some black art to it to ensure it fails 1 week after the warranty expires... |
#5 | |
City & State: East London
My Country: UK
Line Voltage: 230VAC 50Hz
What do you mean by heat shielding?
________________________________________________ Invisible airwaves crackle with life Bright antennae bristle with the energy ________________________________________________
#6 |
Fuhjyyu Killer
I have never seen a heat shield on a monitor, I also think otoluk means RF shield.
#7 |
City & State: Rockhampton, Queensland, Australia
My Country: Australia
Line Voltage: 240VAC 50Hz
I'm a: Hobbyist
Good repair job, but I recommend replacing all of the electrolytic capacitors on the power supply board. You can replace the 400/450V unit if you want; it depends on the manufacturer and series.
With the electrolytics near the heatsink, you can place them lying against the board so that they are away from the heatsink, just like the 400/450V unit.
My first choice in quality Japanese electrolytics is Nippon Chemi-Con, which has been in business since 1931... the quality of electronics is dependent on the quality of the electrolytics. |
#8 | |
I replaced all Elite caps, except the 400V one (but keep it in spare) , should update the first post accordingly. Monitor still works 24/7 at my workplace. Last edited by otoluk; 03-06-2011 at 12:36 PM.. |
| Thread Tools | |
| Display Modes | |
