Go Back   Badcaps Forums > Motherboards with Bad Capacitors > Other Devices with Bad Capacitors
Old 12-03-2010, 12:34 PM   #1
george-spellman@ca.rr.com
Default Power supply made by DPS-210EP-2C
Failue in this Power Supply for Westinghouse LCD . No apparent Bulging Caps, but that does not say one could cause LCD not to turn on.
george-spellman@ca.rr.com is offline   Reply With Quote
Old 12-03-2010, 03:24 PM   #2
ratdude747
ratdude747's Avatar
City & State: New Albany, IN
Line Voltage: 120VAC 60Hz
I'm a: Student Tech
Send a message via Yahoo to ratdude747 Send a message via Skype™ to ratdude747
Default Re: Power supply made by DPS-210EP-2C
dps= delta made. delta makes very good power supplies, they are one of the best.
check the logic board of the tv... westinghouse is known for bad caps on the logic board.
(Insert signature here)
ratdude747 is offline   Reply With Quote
Old 12-03-2010, 03:28 PM   #3
c_hegge
Unknown
c_hegge's Avatar
My Country: Australia
Line Voltage: 240V 50Hz
Delta do use LTEC caps on their PSUs sometimes. They aren't as bad as Fuhjyyu but they do fail, especially in monitors where there is no fan to cool them.
Main PC: Core i5 660 3.33GHz, Gigabyte GA-P55-UD3R, 4GB Kingston DDR3 1333, 750GB WD HDD, Sony Optiarc DVD RW, nVidia GTX295 1760MB, Antec 1200 Case, Delta DPS-750CB 750W PSU, Hauppauge TV Tuner, Windows XP Pro.
Main Laptop: Lenovo Thinkpad T60: Core 2 T2500 2GHz, 2GB DDR2, 80GB HDD, DVD RW, Intel Graphics, Windows XP Pro.
2nd Laptop: Toshiba Satellite A200: Core Duo 1.73GHz, 2GB DDR2, 60GB HDD, DVD RW, nVidia GF Go 7300 Graphics, OpenSUSE 12.2, Fan Mod
c_hegge is offline   Reply With Quote
Old 12-03-2010, 05:43 PM   #4
Thankyou for this Heads up. I found a new Power supply, but I have not tried to find a Bad Cap on old Board. I will check Logic Board. Set does not belong to me, and I have not been able to find a Service Manual.
Old 12-03-2010, 05:45 PM   #5
seanc
City & State: Cambridge, UK
Delta also use Capxon in their desktop PSUs from time to time.
seanc is offline   Reply With Quote
Old 12-15-2011, 03:14 PM   #6
dblur
Can I use this power supply in my VX2835WM? Mine is a PSM217-404-H-R.
I found this one is available, the DPS that is.
Thanks.
dblur is offline   Reply With Quote
Old 12-15-2011, 09:03 PM   #7
dblur
I used this supply and it worked fine for all those looking. 12volt connector is slightly different and it has a fuse on it, but otherwise it functions and I am using the monitor to see this page.
Old 08-07-2012, 12:53 PM   #8
damystery
City & State: BC
My Country: CANADA
I am considering replacing the VX2835wm's PSM217-404-H-R power supply with the DPS-210EP.
-Is the 12V connector the 2-pin connector that connects the power cable plug to the power supply?
-Does the 12V connector from the vx2835wm still fit even though it is slightly different or does the plug need to be replaced as well as the power suplly?
damystery is offline   Reply With Quote
