Go Back   Badcaps Forums > Electronics Theory and Troubleshooting > Troubleshooting Computer Displays
Old 09-30-2011, 02:05 PM   #41
alexanna
alexanna's Avatar
City & State: st.louis mo
Default Re: Samsung Syncmaster 932B
The only thing I see mentioned is 14V.
Do any of the pins on CN201 say analog?
alexanna is offline   Reply With Quote
Old 10-01-2011, 10:40 PM   #42
waitery
City & State: Oregon
Retired, thanks you helped me out big time. I changed out the IC and it came back to life! Thank you for your help and insight!!!
waitery is offline   Reply With Quote
Old 10-01-2011, 10:49 PM   #43
retiredcaps
City & State: Canada
Wow, that was quick!! Did you get the IC from a local store?
PS. I gave 3 possibilities to hedge my bets!
edit: I would love to see a pic of the newly installed IC. Soldering in ICs isn't in my skill set (due to a cheap sort by lowest ebay price soldering iron).
--- begin sig file ---
--- end sig file ---
Old 10-22-2011, 03:20 AM   #44
psspala
I have a problem in this model, the display is bright like white washed and no images when VGA cable is connected from CPU, on disconnecting the VGA cable from CPU or monitor the screen displays and menu and all and adjustments can done, menu function is ok on screen, when no VGA cable is connected no signal cable indicator is visible on on screen, I have replaced ic 101 (DMO465r) and capacitor c107 47uf 50v, still no same problem , visually capacitors looks ok. pls help .
psspala is offline   Reply With Quote
