Old 11-05-2010, 07:54 PM   #1
hoadle
City & State: Nebraska
Default Samsung LN52A530
I had 52 inch Samsung LCD tv Model LN52A530
One day Picture shows only on half screen sometimes shows on the whole screen
maybe FHD60C4LV0.3, SAMSUNG T-CON go bad?
any one know what wrong my TV
hoadle is offline   Reply With Quote
Old 11-06-2010, 05:52 PM   #2
mbates14
Default Re: Samsung LN52A530
ive seen this as a trend lately. it went from a huge capacitor common failure point to t-cons being a common failure point.
mbates14 is offline   Reply With Quote
Old 11-07-2010, 07:35 PM   #3
hoadle
what you mean huge capacitor common & location of huge capacitor common?
Old 11-09-2010, 09:34 PM   #4
mbates14
huge capacitor common failure point is just a phrase i used. Basically it means the capacitor plague.
Old 11-18-2010, 04:26 AM   #5
Dgtech
Junior Advisor
Dgtech's Avatar
City & State: Pittsburgh, PA
Line Voltage: 120 VAC 60Hz
Has anyone fixed this problem yet by replacing the T-con board? I will be helping someone fix a LN52A580 with similar issues. See pic below.
I have to travel to get to this person so I want a clear understanding of the direct cause before I get there. Although I hate to be a board swapper, in this case, it works best for me.
Dgtech is offline   Reply With Quote
Old 11-18-2010, 04:27 AM   #6
Dgtech
Junior Advisor
Dgtech's Avatar
Oh and yes, it does do this same thing with a signal applied.
Old 02-04-2011, 05:44 PM   #7
utdt06
Cool Re: Samsung LN52A530
Bạn thay tụ hóa 5volt là ok.
utdt06 is offline   Reply With Quote
Old 02-04-2011, 06:49 PM   #8
Wizard
Hoadle, Replace T-CON.
Dgtech, iffy, try a T-CON, reason is Hoadle's is more clear-cut is it is split exact down the middle.
Cheers, Wizard
Wizard is offline   Reply With Quote
Old 01-24-2012, 11:43 AM   #9
arkywolf99
so did you replace the tcon and did it work?
arkywolf99 is offline   Reply With Quote
Old 01-25-2012, 04:52 AM   #10
Dgtech
Junior Advisor
Dgtech's Avatar
For me, the person never got back to me to fix the TV before I moved from Baltimore. I have fixed others with the same symptoms by changing TConn.
Old 02-01-2012, 02:49 PM   #11
arkywolf99
oh, well I had the exact some problem as the guy with the first post. the same side of the screen and everything. I replaced the tcon card and it was still having the same issue.
Old 05-08-2012, 12:27 PM   #12
curtisc306
City & State: SK
My Country: Canada
By 'reseating' the cables going into the tcon board this can sometimes fix this problem. My screen did this and reseating the cables fixed it sort of. What I was left with is a solid 6" vertical line but the rest of the tv pictue is fine. And afterwards I repaced the main board + tcon board which did not solve the 6" vertical line issue.
curtisc306 is offline   Reply With Quote
Old 01-09-2013, 11:22 PM   #13
Azzouzze
City & State: NYC
My Country: Usa
Hi guys
I have the same issue with a samsung ln52a580p6fxza and I changed th tcon.
Be aware that if purchased before 2012 and other conditions, you are entitle to a free repair of the main board by samsung.
I will now have the repair change the main board and we ll see.
Any idea how to fix that ?
Azzouzze is offline   Reply With Quote
Old 01-10-2013, 12:53 AM   #14
budm
budm's Avatar
City & State: S.F. Bay area
Line Voltage: 120V 60Hz
Same bad image as shown on post 5.
Here is my fix:
http://www.badcaps.net/forum/showthread.php?t=25371
Old 01-10-2013, 10:58 AM   #15
tibimakai
City & State: Los Angeles/San Dimas, CA
Line Voltage: 120VAC 60Hz
man, and I took one of these apart and dumped the screen in the garbage.
So those pads help with the temperature?
I have tried aluminum sheet metal pieces, but they didn't work, I guess the contact it wasn't perfect.
In my opinion this issue is most likely tab bonding problem and not T-con. Specially if it's not exactly at the center of the screen.
tibimakai is offline   Reply With Quote
Old 01-13-2013, 11:29 AM   #16
Azzouzze
City & State: NYC
My Country: Usa
Guys,
I am still going to ask the repair guys to change the capacitor and the board ( don't remember which one is covered in the class action).
I really don't think the tcon was the problem. I changed it and still the lines are showing up.
I think ok the cable that links the tcon to the main board.
Any thought ?
Thank you
Old 01-13-2013, 11:30 AM   #17
tom66
Savin' for TSLA
tom66's Avatar
City & State: Leeds & B'Stoke
My Country: UK
Line Voltage: 230Vac 50Hz
I'm a: Student Tech
A bad capacitor wouldn't cause this.
Old 01-13-2013, 01:36 PM   #18
Azzouzze
City & State: NYC
My Country: Usa
Tom66, would it be the cable that connects the tcon to the board ?
Old 01-13-2013, 01:40 PM   #19
tom66
Savin' for TSLA
tom66's Avatar
My Country: UK
I'm a: Student Tech
It's more than likely a bad LCD panel.
Old 01-13-2013, 02:33 PM   #20
Azzouzze
City & State: NYC
My Country: Usa
Tom66, after a couple of test with the cables, map, that link to the LCD, it is very likely that it is the issue of pressure on them.
Where can I found them ?
Thank you.
Badcaps.net Technical Forums © 2003 - 2017
