Go Back   Badcaps Forums > Electronics Theory and Troubleshooting > Troubleshooting Computer Displays
Old 04-04-2011, 03:47 PM   #81
jfr1326
Default Re: My Viewsonic VX924 monitor died!
Originally Posted by retiredcaps View Post
What country do you live in? Shipping for USA customers is around $2.75 USD.
I live in the UK. Shipping for DigiKey, Mouser, RS etc etc.. are all a fixed minimum of 12GBP. If I knew of anybody shipping at a reasonable rate, I would buy from them.
jfr1326 is offline   Reply With Quote
Old 04-04-2011, 04:05 PM   #82
jetadm123
City & State: California
Originally Posted by jfr1326 View Post
Thanks PlainBill and Jetadm123. The transistors and poly caps arrived with the usual exorbitant postal costs from DigiKey. They are now soldered in and ........a lovely bright, colourful monitor. Thanks guys.
Congrats on the repair! Yeah, I'm grateful that I have access to digikey with low cost shipping.
jetadm123 is offline   Reply With Quote
Old 08-11-2011, 11:45 PM   #83
Perineum
I have recapped the entire PSU and now the monitor turns on, but only for a second.
It turns on, then turns off about once a second, repeating. The MBR10100 tested fine when I pulled it out.
I have not touched the logic board yet but that is where I was about to head to.... I've read 3 or more threads on this monitor and I'm still not sure what the blinking green power LED means....
Perineum is offline   Reply With Quote
Old 08-12-2011, 12:12 AM   #84
pedro
City & State: Sunny Perth
My Country: AUSTRALIA
Line Voltage: 240VAC 50 Hz
What brand/series of caps did you use in the recap?
Usually a power LED blinking about once a second is symptomatic of the SMPS attempting to start, failing, and repeating this pattern. Typical causes are faulty (or inappropriate) caps, faulty rectifiers, short on an output rail, etc.
As a first step, address the cap replacement questions - what you used, and whether you replaced ALL the electros (other than the biggie). Don't bother with the video board yet, until the PSU is cleared of suspicion.
Friends don't let friends buy Samsung ....
pedro is offline   Reply With Quote
Old 08-13-2011, 11:07 AM   #85
Perineum
I replaced the 400v 100uF with a nichicon PT(M)
The (2) 25v 470uF caps by the MBR10100CT are UCC KZE
The (C21) location I put a 35v 330uF Rubycon MHE
Beside the largest cap I placed a nichicon 10uF 50v VZ(M)
Lastly, the cap near the 6 pin connector is another 35v 330uF Rubycon MHE
The values should all be fine or overkill now except I may have messed up and not used low ESR caps where I needed to....
Also, I went through the board and hopefully (maybe I missed a few?) touched up all the pins to make sure there wasn't a cold solder joint.
Thank you for your help
Old 08-15-2011, 08:41 AM   #86
Perineum
Okay, I found http://www.badcaps.net/forum/showthread.php?t=2280
The nichicons and Rubycons I used aren't on that list.
I suppose that is my issue? Which caps are part of the SMPS circuit?
Old 08-15-2011, 10:08 AM   #87
PlainBill
PlainBill's Avatar
City & State: Phoenix, AZ
Line Voltage: 120VAC 60Hz
I'm a: Hobbyist
All except the big (100 F, 450 volt) one. OK, technically it is, but it does not have to be a low ESR cap,
PlainBill
Old 08-15-2011, 10:48 PM   #88
Perineum
The cap near the 6 pin connector is another 35v 330uF Rubycon MHE
Ok, swapped out the 35v 330uF Rubycons for ZL's of the same values.
Then swapped the 50v 10uF Nichicon for a UCC KY of the same.
All caps report correct capacitance according to my Fluke 12, but I have no idea if the ESR is off (No ESR meter here)
The monitor's symptoms are slightly different now. The picture is there, but the backlight comes on.....
"grey to dull, suddenly bright, then off, then repeating about 4 seconds later" - according to the girlfriend.
Old 08-17-2011, 01:31 PM   #89
Perineum
So what should my next step be?
I'm afraid that my soldering is much much better than my troubleshooting skills.
Should I be checking ESR on the replacement caps?
Old 08-17-2011, 02:34 PM   #90
alexanna
alexanna's Avatar
City & State: st.louis mo
Post some in focus photos of your power supply front and back,using managed attachments.
The blinking PLED could be caused by voltages coming and going, Maybe from an overload on the power supply causing it to start and stop.
Are there any voltages listed at the connector from the power supply to the logic board.
If they are printed on the board what are they and are they steady?
alexanna is offline   Reply With Quote
Old 08-25-2011, 09:00 AM   #91
Perineum
All the pictures are here: http://www.badcaps.net/forum/showpos...50&postcount=3
Sorry for the long delay, I've been working 12 - 15 hour shifts right now. I will measure voltages when I can (soon hopefully). However, I did score a 4.5 amp 12 volt power supply so I can try that as well.
Old 08-31-2011, 03:49 PM   #92
Perineum
I would like to report that the 12 volts from the PSU is fluctuating.
I would guess that the logic board is OK as the image looks fine for the half second it is up on the screen.
Am I still looking at a capacitor problem?
Old 09-02-2011, 01:35 PM   #93
Perineum
Using the DC adapter to give it power via the capacitor nearest the 6 pin connector resulted in the monitor turning on once and then not again.
When I removed the connector it resumed it's normal non-working behaviour.
I did not have the AC plugged in at the same time as the adapter. Is AC needed at the same time?
Old 03-19-2012, 02:37 PM   #94
bo2000
City & State: SH
My Country: Germany
Hi!
I found this thread with google.
Awesome board!
I got an old VX924 from work to play with.
The problem was: You can turn it on, it shows a picture for about 1 second, then it wents black. The green power LED stays on.
When you remove the VGA- (or DVI-) cable and put it back on, it also shows a picture for ~1s and turns black again.
Now I changed all the caps like described, but the problem is the same.
But I just noticed, that I forgot one cap. C320. Could that be the problem?
I also checked the polarity and the connection of the new caps.
The logic board gets 12V steady.
2 pictures of my board attached.
Thanks in advance for your help and greetings from Germany
bo2000 is offline   Reply With Quote
Old 03-19-2012, 03:02 PM   #95
Jasgriff
City & State: England
My Country: UK
Hi Bo,
Welcome to the forum and great job on the clear pics.
Do you have a spare working CCFL that you can use to do a few tests?
Fixed so far : 1 Home cinema system, 16 LCD Monitors, 4 LCD TV's
How to resize your pictures guide click HERE
Retiredcaps Ideal post example click HERE
Jasgriff is offline   Reply With Quote
Old 03-19-2012, 03:06 PM   #96
Jasgriff
My Country: UK
What have you done with the main filter Cap in the middle?
Old 03-19-2012, 03:28 PM   #97
bo2000
City & State: SH
My Country: Germany
Originally Posted by Jasgriff View Post
Hi Bo,
Thank you!
I don't have a CCFL but a multimeter if that helps.
Yeah, I know it looks odd, but I only got one of these:
and I had to extend the feet to get it connected to the board.
Old 05-23-2012, 08:10 AM   #98
notrash
City & State: Vienna
My Country: Austria
Great board.
Good to see that i'm not the only one with this problem.
As described I replaced all the caps on the board. I also replaced the two parts mounted on the heatsinks.
But still... if i start my PC the screen looks normal for ~1s and then goes black (as described by bo2000).
The green power LED always stays on.
I tried to measure the voltages at the connector to the second board. One of the top pins shows 12V the other two ~0V...
Any solution for this problem yet?
Thanks,
Martin
notrash is offline   Reply With Quote
Old 05-23-2012, 08:39 AM   #99
selldoor
Slow Learner
selldoor's Avatar
City & State: Lancashire UK
@Notrash - Do you see an image of what is on the pc when the screen goes black.
try with a flashlght
When you tried to test the voltages was it all connected up
selldoor is offline   Reply With Quote
Old 05-23-2012, 08:51 AM   #100
Scenic
o.O
Scenic's Avatar
City & State: Duisburg
My Country: Germany
Line Voltage: 230VAC 50Hz
Check the 4 inverter transistors on the backside of the board (Q6, Q7, Q8, Q9) for shorts
My Belinea 101910 (which uses the same PSU board) died on me while using it a couple months back.
One of those transistors was shorted and actually had a hole in it. When you tried powering it up, the backlight would just flash for a bit less than a second (inverter shut down), but the monitor stayed on (green power LED)
Replacing all 4 of them and resoldering the inverter transformers should bring it back to life.
According to the Belinea Servicemanual (parts list on page 61, inverter on page 46), Q6-Q9 are 2A 50V NPN transistors in SOT-89 package, specifically 2SC4672 by Rohm.
Keyword for these dying POS inverters is "royer oscillator". Searching for that on here will bring up a metric f*ckton of BenQ and Dell LCD monitor threads.. all of them with more or less the same problem.
Scenic is offline   Reply With Quote
