Go Back   Badcaps Forums > Electronics Theory and Troubleshooting > Equipment Usage, Soldering, Techniques, and Reviews
Old 09-28-2010, 02:54 PM   #1
Solder Boy
City & State: Ontario Canada
Question Tenma 72-040 Cap Meter
Hi guys! I won this cap meter off Ebay earlier this month.. finally got it today..everything works on it.
Just have a question about reading the higher capacitance levels.. this thing goes as high as 20 000 uf and the meter has a selector switch on it that says 20mf.
It has a digital LCD on it.. if I test a used 3300 cap for example.. it reads 3.26 or close to it. Does this mean 3.26x1000 for a reading of 3260uf or does it mean 3.26 and the cap is shot?
I tested some 6.3 1000uf caps and that was easy... it read 850uf.
My next question is how much of a leeway eitherway is acceptable before you determine the cap to be bad? Is 850uf on a 1000uf cap ok? I kinda figure 700uf and below is bad.
Thanks guys!
www.bcrelectronics.ca
Solder Boy is offline   Reply With Quote
Old 09-28-2010, 03:05 PM   #2
370forlife
Large Marge
370forlife's Avatar
City & State: Kalamazoo, MI
My Country: United States
Line Voltage: 0-120VAC 60Hz
I'm a: Hobbyist Tech
Default Re: Tenma 72-040 Cap Meter
Almost all caps are rated for a tolerance of +/- 20% (make sure with the data sheet, if you can find one, if you are unsure)
850/1000=.85
1-.85 is .15
.15x100=15
So 850uf out of a labeled 1000 would be 15% below the labeled rating, which is in spec.
Originally Posted by JFK
The American, by nature, is optimistic. He is experimental, an inventor and a builder who builds best when called upon to build greatly
370forlife is offline   Reply With Quote
Old 09-28-2010, 06:13 PM   #3
PCBONEZ
Grumpy Old Fart
PCBONEZ's Avatar
City & State: Phoenix, AZ
Line Voltage: 120V 60Hz
If there is an (M) on a cap then it is +/-20%.
Don't confuse with the Panasonic/Matsushita [M] though.
Mann-Made Global Warming.
- Dr Seuss
PCBONEZ is offline   Reply With Quote
Old 09-28-2010, 06:19 PM   #4
PCBONEZ
Grumpy Old Fart
PCBONEZ's Avatar
Yes, 3260uf
Old 09-28-2010, 10:24 PM   #5
Quasar
Quasar's Avatar
City & State: NJ
mF = millifarad
uF = microfarad
1mF = 1,000uF
3.26mF = 3,260uF
Meter came with no book? It's usually explained or charted in the manual.
Quasar is offline   Reply With Quote
Old 02-15-2012, 09:06 PM   #6
microtech
I have the manual--it's only a couple pages--ur welcome to it if u want.
microtech is offline   Reply With Quote
