#1 |
City & State: Maidstone Kent
Bit of an odd ball question .
I Know roughly how a Geiger Muller tube works . But does does anybody know how you can actually test a GM counter works ? If I had a very old luminous watch the Radium would be detectable by the counter and it would click and show somes counts per second . But luminous dials do not use Radium anymore . So what can you use to see if it works ? thanks Barry Wilkins |
#2 |
Grumpy Old Fart
City & State: Phoenix, AZ
Line Voltage: 120V 60Hz
They use a calibrated source [known counts] to check it.
Mann-Made Global Warming. - We should be more concerned about the Intellectual Climate. - Be who you are and say what you feel, because those who mind don't matter and those who matter don't mind. - Dr Seuss - You can teach a man to fish and feed him for life, but if he can't handle sushi you must also teach him to cook. - |
#3 |
City & State: Delaware
Line Voltage: 480VAC 60Hz or Less
Most of your ionization-type smoke detectors have a very small amount of Americium in the sensor assembly. The problem is most newer smoke detectors are impossible to open without destroying them.
Here is the link to details about the Americium: http://www.webelements.com/americium/ |
#4 |
City & State: Kamloops BC
My Country: Canada
I thought that was a beta emitter? Won't most geiger counters on ebay only detect gamma?
Find Nedry! Check the Vending machines!! <----Computer says I need more beer.
#5 |
there is some gamma off of that as well, just not enough to do you any real harm. anything glow-in-the-dark puts some off as well.
(Insert signature here) |
#6 | |
in chemistry 2 years back, one of our alpha sources fell out of the plastic disc. they teacher found it using a Geiger counter. |
#7 |
Grumpy Old Fart
Different meters have different capabilities.
Depends mostly on the type of probe. . |
#8 | |
Line Voltage: 120VAC 60Hz
I'm a: Hobbyist
Or you can order a sample of pitchblende. PlainBill
For a number of reasons, both health and personal, I will no longer be active on this board. Any PMs asking for assistance will be ignored. Never be afraid to try something new. Remember, amateurs built the ark. Professionals built the Titanic. |
#9 |
Grumpy Old Fart
If all you want to do is see the needle move then any of those suggestions may work.
If you want a number that actually means something then none of them will work. The calibration frequency on 'good ones' generally varies between monthly and daily depending on what kind of meter it is. The cal frequency for the 'accident' [or 'bomb'] emergency response type meters is 1 year but that type isn't all that accurate or sensitive [compared to 'good ones'] even when newly cal'ed. The 'signal strength' these meters are designed to detect and measure is SO TINY that even small 'aging changes' in compont values in the meter will throw the reading way off. Not the kind of meter you calibrate every few years and expect the numbers to mean anything. ~ "Background" is defined as <50 cps. - That isn't because that is what background actually is, it is because below 50 cps the detector can't detect anything anyway. Any reading below 50 cps isn't a reading at all, it's just the electronics in the meter 'wandering around' because the detector isn't sending anything. - Static. [That applies to detectors a human can carry, not lab equipment.] . I was just outside an open reactor compartment doing some paper work. There was a 'a good one' [type] sitting on the table 'on' at the Control Point. [Control Point is where you check you didn't get crapped up while working in the compartment before you leave.] Suddenly the meter goes from static background, alarms, and pegs the meter at 50,000 cps. I shit! - That's what happens when a core cooling pipe ruptures! Then it dropped to static for like 3 seconds, then it did it again and stayed at 50,000 cps. I called out the casualty response team. ... Turns out some moron contractor was tig welding inside the compartment and he ran his %#@&!~ cables right next to the meter. . That contractor is lucky I never found out exactly who did it. . Last edited by PCBONEZ; 09-13-2010 at 07:21 AM.. |
| Thread Tools | |
| Display Modes | |
