Go Back   Badcaps Forums > Motherboards with Bad Capacitors > Major Manufacturers Boards
Old 09-02-2010, 11:12 AM   #1
torpex505
torpex505's Avatar
Default GX520 same board as GX620?
I have a Dell GX520 USFF that I want to re-cap. Can I just buy the GX620 USFF kit? I could not find any information on the Boards used. I can post the boards model# tonight if that might help.
Thanks,
Eric
torpex505 is offline   Reply With Quote
Old 09-02-2010, 04:01 PM   #2
stj
City & State: Europe
Default Re: GX520 same board as GX620?
make a list of the caps in it or post a foto.
Old 09-02-2010, 05:51 PM   #3
torpex505
torpex505's Avatar
I took a close look, and can't seem to find any caps that are bulging or leaking... This may not be a cap issue after all. I tested the PS, but it tests good. The thing just shuts down randomly. Sometimes it will stay on for hours, even days. But other times it won't even make it to the Windows logon screen before shutting down.
Here is the best pic i could get. Could it still be a cap issue?
BTW, It looks like they were all Rubycon caps with exception from 6 caps located near the socket and 1 next to dimm2...
Old 09-02-2010, 06:12 PM   #4
PCBONEZ
Grumpy Old Fart
PCBONEZ's Avatar
City & State: Phoenix, AZ
Line Voltage: 120V 60Hz
GX620's will blow the little 4&5 mm caps which don't always bloat.
Presumably the GX520 will too.
http://www.badcaps.net/forum/showthread.php?t=6055
Mann-Made Global Warming.
- Dr Seuss
PCBONEZ is offline   Reply With Quote
Old 09-02-2010, 08:56 PM   #5
momaka
momaka's Avatar
City & State: VA
My Country: U.S.A.
Line Voltage: 120 VAC, 60 Hz
I'm a: Student Tech
How did you test the power supply?
Does the computer really shut down or does it restart (big difference here)?
Old 09-03-2010, 04:17 AM   #6
torpex505
torpex505's Avatar
I tested using a nifty little powersupply tester that I got on eBay a while back. It does not provide actual voltage, but rather a red or green led that's based on wether it's getting the voltage that it's supposed to get per wire. I probably should go in with a multimeter to verify. It shuts down and flashes an amber light on the power button. It does not restart.
Old 09-03-2010, 05:52 AM   #7
PCBONEZ
Grumpy Old Fart
PCBONEZ's Avatar
The problem with those is that they don't put enough load on the PSU to tell you if the PSU is good in a real world application.
They will tell you if a PSU is stone dead...
But they won't tell you if a PSU will run a system.
It's not -> go/no go
It's -> no go/maybe
Old 09-03-2010, 06:07 AM   #8
torpex505
torpex505's Avatar
What would be the best way to test then? Should I just boot the computer and test the wires one by one with a multimeter?
Old 09-03-2010, 09:05 AM   #9
PCBONEZ
Grumpy Old Fart
PCBONEZ's Avatar
Check the voltages with a multimeter while the system is doing something beyond just being idle.
It's either that or scare up a slew of test loads.
Old 09-04-2010, 11:05 AM   #10
seanc
City & State: Cambridge, UK
You have a desktop or small form factor GX520, the GX620 that like to bake caps are usually ultra small form factor - very different systems.
Is your cooling fan working correctly? Is the heatsink seated correctly?
seanc is offline   Reply With Quote
Old 09-04-2010, 10:14 PM   #11
momaka
momaka's Avatar
City & State: VA
My Country: U.S.A.
I'm a: Student Tech
Or try a different power supply altogether and see if the problem disappears. The power supply needs to be rated for at least 14A on the 12v rail, though.
Also check the caps in the original power supply.
Old 09-07-2010, 09:07 AM   #12
torpex505
torpex505's Avatar
I'll try with a different PS to see. And check caps in original PS as well.
Old 09-07-2010, 09:17 PM   #13
brethin
City & State: Owensboro, KY.
Line Voltage: 120VAC 60Hz
Thanks,
Eric
Short answer is no, they are not the same.
brethin is offline   Reply With Quote
Old 10-05-2010, 07:53 AM   #14
torpex505
torpex505's Avatar
Sorry I've been inactive for a bit. Ok, so it's a GX520 SFF, not USFF... But yeah, deffinatly not teh same board.
What program should I run to runup the load to test the PS? Would a Dell diagnostics or memtest scan be suffecient? or is there another program that will give me the load that I would need to get a good test?
Thanks for the help,
Eric
Old 10-05-2010, 07:56 AM   #15
shovenose
Spoiled Asshole
shovenose's Avatar
City & State: Fairfax, California
I'm a: Forum Junkie
Prime95 for cpu and furmark on the graphics while playing a dvd and doing a drive error check using hdtune. Thatll stress it out as much aa possiblr
New computer! Intel Core i7-4770K 3.5GHz, 16GB DDR3-1600 RAM, Geforce GTX 670 2GB, 2x 120GB Intel 520 Series SSD in RAID0 for OS and programs, 1TB WD Caviar Black for downloads and data, 800W Power Supply, Silverstone PS07B case, Windows 8 Pro
shovenose is offline   Reply With Quote
