I've got a Vizio VW42lHDTV10A that when powered on the Vizio logo changes from amber to white and the backlights come up - it has a gray screen. There is no picture, no sound, no menus, etc. - it won't shut off with either the remote or the buttons on the side. Inverters seem to work.
I've checked caps on the power board and main board - nothing puffed. I have checked the caps with an esr meter (both boards) - pulled and tested some with a capacitance meter - all seem to be fine. I replaced some since they were a bad brand with low esr caps (panasonic fm) that I had in stock. Nothing changed the symptoms. All the voltages on the power board check ok (5,12,24) fuses on the t-con, main board check ok. The 5 volt regulator on the main board checks ok.
I've cleaned the connector to the t-con board and reseated it (and the others). If I push the reset button on the main board it will shut the tv off.
I noticed that there are five ic's on the main board that appear to be fixed low dropout regulators - four are marked AMC 1117 and one marked K1117. Does anyone know what the correct voltages should be at these items (U2,U8,U33,U7) and U9? The main board is Vizio 3642-0242-0150
Judging from some internet postings this problem seems to be fairly common - does anyone know the solution?
Thanks,
Mike
Thanks,
Mike
