#1 |
City & State: Mount Savage, MD
is it possible to replace 220 uf 16v with a 220uf 25v? I know you can go up in uf by about 10-20% but what about volts?
Thanks Chase |
#2 |
Depends on the application. One step up in volts is fine, in most cases, and usually within a brand/series there is no trouble.
It depends on the characteristics of the cap you are replacing vs. the cap doing the replacing. Reviewing the datasheets/specs is the best/safest way to be ~fairly~ sure. Example: Using a Nichicon HZ (super low ESR) cap where a Nichicon PW (medium low ESR) cap was, may cause problems upstream with the circuit. Same as if you used them the other way around. Circuits are designed using a specific type of cap with x/y/z characteristics which are figured in the engineering formulas at the design level. Voltage Scale: 4-6.3 6.3-10 10-16 16-25 25-35 or 25-50 50-63 63-80 80-100 100-etc. |
#3 |
City & State: Canada
#4 |
Thanks for the replys. Ill give it a try and also read the data sheets on both caps!
#5 |
The Boss Stooge
I have 220uF in both 25v and 16v, in both Rubycon and Samxon. If possible, stay with what came out originally.
<--- Badcaps.net Owner & Forum Administrator!! Badcaps.net Services: Premade Capacitor Kits Badcaps.net Capacitor Master List Motherboard Repair Services If you've come here in search of replacement capacitors or repair services, please use the links above. ![]() ---------------------------------------------- Badcaps.net Forum Members Folding Team http://folding.stanford.edu/ Team : 49813 Join in!! Team Stats |
| Thread Tools | |
| Display Modes | |
