KDS Business K Series K22mdwb not turn on
  • hoadle
    • Jul 2010
    • 174
    I had KDS Business K Series K22mdwb its not turn on (not powerlight & Lcd monitor)
    On KDS Business K Series K22mdwb had POWER SUPPLY 200-000-DTLBMH PI-190DTLB & find one site sale but in hongkong but main thing I want to know how to fix the problem
    http://www.dgdw.cn/dewang%20power/PI...er%20Board.htm
    any one can help me?
    thanks
  • PlainBill
    • Feb 2009
    • 7034
    Re: KDS Business K Series K22mdwb not turn on
    thanks
    Do you have a DMM? If you don't all I can suggest is replacing every electrolytic cap, especially the tiny one near the big transformer, and the fuse (the red 'box' to the left of the power connector).
    If you DO have a DMM, CAREFULLY check the voltage across the large capacitor in the lower right corner when the power supply is plugged in.
    PlainBill
    • retiredcaps
      • Apr 2010
      • 9271
      Post clear focused pictures of your board after reading
      https://www.badcaps.net/forum/showthread.php?t=1868
      Do you have a multimeter? If yes, what is the brand/make and model number?
      edit: PlainBill beat me to the punch writing this. I'm soldering in a new chip in between questions.
      --- begin sig file ---
      --- end sig file ---
      • PlainBill
        • Feb 2009
        • 7034
        And I'm following a baseball game. Who do you think will have more to show for it at the end of the evening?
        PlainBill
        • hoadle
          • Jul 2010
          • 174
          I will pot the picture soon, but I already replace all cap & back side the board had burn Transistors, I replace new one is turn on about 2 min & smell burned & open and Transistors i replace is burned again
          Yes I had 2 DMM (multimeter)
          Fluke 115 & Fluke 87
          • hoadle
            • Jul 2010
            • 174
            I already replace all new electrolytic cap & replace one trasistor too & late is burn out again
            thanks
            try pot back side the board soon
            • hoadle
              • Jul 2010
              • 174
              Now I replace 2 Tip3055 transitor now powerlight on but backlight turn on about second & off. Find out top backlight is on & bottom not on that why is shut off run out option need held
              Here the top & bottom board picture
              • retiredcaps
                • Apr 2010
                • 9271
                Try testing both transformers as per step #4
                Compare all measurements. The 2 transformers should be very close or identical.
                • ecking767
                  • Oct 2009
                  • 492
                  I'm 100% percent sure you have replace your output transistors with the wrong part. TIP3055 is a transistor, On that particularly board the output transistors are MOSFET. Here is the part number PHD3055E
                  http://www.alldatasheet.com/datashee.../PHD3055E.html
                  I have seen this board using a AOD444 for the output transistor too..
                  please confirm..
                  • hoadle
                    • Jul 2010
                    • 174
                    please confirm..
                    I think you right here diagram
                    http://www.4shared.com/get/vkH_vj3t/...2BB5FAFB.dc210
                    • ecking767
                      • Oct 2009
                      • 492
                      hoadle thanks for the schematic, I have work on this board with out a schematic for a while now. I was off by one digital for the other part number. Its AOD442 not AOD444. You must get the right MOSFET in place before doing anything!!!
                      • hoadle
                        • Jul 2010
                        • 174
                        Where you order the AOD442?
                        • retiredcaps
                          • Apr 2010
                          • 9271
                          $1.01 at digikey.
                          http://search.digikey.com/scripts/Dk...=785-1107-1-ND
                          • hoadle
                            • Jul 2010
                            • 174
                            I get AOD442 at local electronic store and install powerboard, now monitor can't turn on + no powerlight & screen.
                            Will T/S late
                            • ecking767
                              • Oct 2009
                              • 492
                              Will T/S late
                              something is shorted across the power supply, check the MOSFET for shorts. check the filtering caps for shorts
                              • hoadle
                                • Jul 2010
                                • 174
                                I find another power/inverter board with some bad cap (replace all new cap) now I had another problem the screen not right color
                                I take some picture, some one help me
                                thanks
                                • seanc
                                  • Nov 2008
                                  • 1319
                                  If you're referring to the gradients showing as banding, check your display properties are set to use 32bit colour.
                                  • hoadle
                                    • Jul 2010
                                    • 174
                                    I check all setting & follow to display color calibration but still the same (if thay had goog picture & can't see text + display dark)
                                    Need help
                                    • hoadle
                                      • Jul 2010
                                      • 174
                                      Any one had Ideal to fix my KDS monitor?
                                      • gasan
                                        • Sep 2010
                                        • 26
                                        so when you replaced the power supply you got the color problem????????
                                          Samsung Galaxy Book2 Business Galaxy Book2 Business Notebook Specification for Upgrade or Repair
                                          This specification for the Samsung Galaxy Book2 Business Galaxy Book2 Business Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Galaxy Book2 Business boardview and Galaxy Book2 Business schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                          09-07-2024, 05:50 AM
                                          09-07-2024, 05:20 AM
