Go Back   Badcaps Forums > Battling the Bad Capacitors > Recapping Your Motherboard
Old 07-30-2010, 02:42 PM   #1
Sylvester
City & State: Up North
My Country: UK
Line Voltage: 230v
Default Identify smd cap value
smd cap approx 5mm x 6mm high, markings 95TA, 47, 16v, is this 47uF 16v? Its been broken off a mobo when the owner tried to fit a graphics card. Ordering a single unit in the uk may be difficult but I've managed to find a cap on a graphics card with the markings 24, 47, 6A possibly 1mm higher but the same diameter could this be used?
Sylvester is offline   Reply With Quote
Old 07-30-2010, 03:48 PM   #2
Toasty
Toasty's Avatar
City & State: East Coast, USA
Line Voltage: 220-221
Send a message via Yahoo to Toasty
Default Re: Identify smd cap value
47uF 16v - yes
24, 47, 6A - sounds like 47uF but 6 volt, so no.
Toasty is offline   Reply With Quote
Old 07-30-2010, 04:46 PM   #3
Sylvester
My Country: UK
Line Voltage: 230v
Thanks, thought that possibly was 6v, what does the 95TA mean. What would be a widely available replacement, is esr an issue?
Old 07-30-2010, 05:02 PM   #4
Toasty
Toasty's Avatar
Production date code perhaps?
Please:
Board make/model
Photos of damage area and of cap top
Yes, low ESR on mobos
Old 07-30-2010, 05:32 PM   #5
Sylvester
My Country: UK
Line Voltage: 230v
pc is a compaq presario sr1000, mobo is ms 7184 v1.0, cap is directly inline with pciex16 slot, fortunately the cap was still in the case and made the fault finding easier. I'll post a few pics shortly
Old 07-30-2010, 06:11 PM   #6
Sylvester
My Country: UK
Line Voltage: 230v
You can see the solder pads where the cap was fitted next to the mounting hole, the cap between the 2 slots and next to the via and realtek chips is the same value.
Old 07-30-2010, 07:06 PM   #7
Toasty
Toasty's Avatar
http://search.digikey.com/scripts/Dk...=565-2537-1-ND
Plastic base is: 5.3mm x 5.3mm
Cap is: 5mm x 5.8mm
Minimum 5 pcs = $3.32
ESR: 0.7Ω Ripple: 160mA
These are more for noise filtering & trace length compensation than power filtering.
Old 07-31-2010, 08:33 AM   #8
Sylvester
My Country: UK
Line Voltage: 230v
Thanks for the info.
Old 07-31-2010, 08:57 AM   #9
Sylvester
My Country: UK
Line Voltage: 230v
Although a slightly bigger case width, is this cap suitable?
http://cpc.farnell.com/jsp/search/pr...sp?sku=CA05545
Digikey shipping is pretty expensive to uk.
Old 07-31-2010, 09:53 AM   #10
Toasty
Toasty's Avatar
>>Digikey shipping is pretty expensive to uk.<<
And exactly how would I know where you are located?
Location box in profile......?
RS Online has a better selection.
Either is fine, in order of my preference:
http://uk.rs-online.com/web/search/s...duct&R=0568474
http://uk.rs-online.com/web/search/s...duct&R=5370461
Old 07-31-2010, 11:00 AM   #11
Sylvester
My Country: UK
Line Voltage: 230v
Thought I had mentioned uk. For some reason I thought rs had a minimum order value, but it seems they don't anymore, so problem solved.
Old 08-08-2010, 04:30 PM   #12
Sylvester
My Country: UK
Line Voltage: 230v
RS delivered next day, cap now soldered in place, thanks for help.
Old 08-08-2010, 06:44 PM   #13
kiddznet
kiddznet's Avatar
City & State: The TOP END of OZ (snakes crocs cold beer)
Another one fr the masters if you have the time
What are the values of the caps missing off this board?
8 Around the CPU and one little on near AGP slot
While youre looking can you tell me whats wrong with the board?
kiddznet is offline   Reply With Quote
