Go Back   Badcaps Forums > Electronics Theory and Troubleshooting > Power Supply Design and Troubleshooting
Old 08-02-2010, 12:49 PM   #21
Per Hansson
Per Hansson's Avatar
City & State: ----
My Country: Sweden
Line Voltage: 230v 50Hz
Send a message via ICQ to Per Hansson Send a message via MSN to Per Hansson
Default Re: Antec TruePower 2.0 TPII-550
Originally Posted by Wrog View Post
Just for my understanding, what's the reasoning behind bumping up the voltage from 35v to 50v on this cap?
It is a critical cap, if it fails 5VSB will go high and kill your mainboard
Increasing it's voltage rating is a small safeguard that will make the capacitor withstand voltage spikes etc better (If memory serves, which it well might not, I think Wizard did a test where it was found that there could be quite high voltage spikes on this capacitor...)
Old 08-02-2010, 02:38 PM   #22
PCBONEZ
Grumpy Old Fart
PCBONEZ's Avatar
City & State: Phoenix, AZ
Line Voltage: 120V 60Hz
The 47uF shows up in most PSUs with voltages of 25v, 35v or 50v.
Of those I think I see 35v most often.
Basically it's an important cap so there is no reason not to use a 50v as it costs no more to upgrade.
You don't -have- to use 50v.
The original voltage should be okay as you are getting better quality caps.
Us guys [or at least I do] that buy caps in bulk just get the 47uF 50v and use them for the 25v and 35v 47uF caps too, rather that stocking 3 sizes of 47uF caps.
So: The upgrade is routine based on practical logistics and ecomonics strategies.
- Did that sound cool, or what?
In other words it's more of a habit than a requirement.
Mann-Made Global Warming.
- Dr Seuss
PCBONEZ is offline   Reply With Quote
Old 08-02-2010, 03:19 PM   #23
Toasty
Toasty's Avatar
City & State: East Coast, USA
Line Voltage: 220-221
Send a message via Yahoo to Toasty
Talking Re: Antec TruePower 2.0 TPII-550
You got a purty mouth.
Toasty is offline   Reply With Quote
Old 08-02-2010, 05:01 PM   #24
PCBONEZ
Grumpy Old Fart
PCBONEZ's Avatar
You're purdy cute in that helmet too!
Old 08-02-2010, 07:18 PM   #25
Wrog
City & State: Florida
Originally Posted by 370forlife View Post
Scorch marks might just be dried glue. There's usually not much under the main transformer, some small parts near it that may have committed suicide. Look for any burnt resistors/capacitors/diodes, etc... around or under the transformer.
Sorry, I should have been more clear -- the scorch marks that I noticed were on the bottom of the PCB. See attached pics, the non-flash picture makes it look worse than it actually is, so I included one with a flash too.
Wrog is offline   Reply With Quote
Old 08-02-2010, 07:26 PM   #26
Wrog
Thanks for the information on selecting a 50v over a 35v, the reasons make perfect sense. While I don't buy caps in bulk, it's good to understand these things just in case I do in the future!
Old 08-02-2010, 07:31 PM   #27
370forlife
Large Marge
370forlife's Avatar
City & State: Kalamazoo, MI
My Country: United States
Line Voltage: 0-120VAC 60Hz
I'm a: Hobbyist Tech
Send a message via AIM to 370forlife
Just looks like heat discoloration.
Originally Posted by JFK
The American, by nature, is optimistic. He is experimental, an inventor and a builder who builds best when called upon to build greatly
370forlife is offline   Reply With Quote
Old 08-02-2010, 09:32 PM   #28
Toasty
Toasty's Avatar
Arrow Re: Antec TruePower 2.0 TPII-550
There is either a diode or resistor mounted on end between the 2 trafos. Verify that the part is not physically damaged and that if it's a resistor, that it is in tolerance to its markings. Reflow the solder to those pins.
Old 08-02-2010, 09:39 PM   #29
370forlife
Large Marge
370forlife's Avatar
Looking at that noflash image, that scorch is pretty dark. Definitely check out what toasty is pointing out.
Old 08-02-2010, 10:20 PM   #30
Wrog
Reference designator is D20. Ran out of time to do any checking on it tonight, but will definitely follow up tomorrow. Thanks!
Old 08-04-2010, 09:15 PM   #31
Wrog
Seems fine physically, and on diode check it measures .549 in one direction and open in the other (seems OK). Will post again once I've recapped.
Old 08-05-2010, 12:06 AM   #32
Toasty
Toasty's Avatar
Sounds good!
Please confirm that that diode is actually on the discolored area. There is another component nearby but I can't make it out. Just below that diode and right up against the transformer. Use a flashlight shown through the board to locate what sits right on the mark. Discoloration probably all caused by time/heat and not helped by the bad caps.
Old 08-25-2010, 01:17 PM   #33
Wrog
Sorry for the long delay between followups; I had some RL stuff pop up (or pop out would be more descriptive)! The discoloration is definitely centered around D20. D21 is nearby but also tests fine. I am just now getting around to ordering the replacements, and wouldn't you know it? The UCC LXZ (565-1927-ND) is on backorder until sometime in October! I've scanned for a replacement but the specs don't seem to be as good as the LXZ in this size. Of this list, which would be the best to get (these are the 220uF 16V 6.3mm in stock at Digi-key):
Panasonic M
UCC SMG
Nichicon VR
There are a few others but are rated for only 1000 hours with a lower ripple rating. Thanks for the continued help!
Old 08-25-2010, 02:20 PM   #34
Toasty
Toasty's Avatar
Lightbulb Re: Antec TruePower 2.0 TPII-550
These are only 85°C caps. Need 105°C.
Use KMG - http://search.digikey.com/scripts/Dk...me=565-1293-ND
-or-
NHG - http://search.digikey.com/scripts/Dk...&name=P5530-ND
Old 08-25-2010, 03:38 PM   #35
Toasty
Toasty's Avatar
See PCBONEZ remarks (6 & 7) on this thread regarding endurance hour ratings:
http://www.badcaps.net/forum/showthread.php?t=10764
Also, can an 8mm fit in for that 6.3mm? If so, you have a much larger number of choices.
Cheers!
Toast
Old 08-25-2010, 06:59 PM   #36
Wrog
Thanks! I will inspect where they sit to check if 8mm diameter can be used. If they fit, would the Nichicon PW be a good choice? Actually, I think I may have some 220uF 25V with an 8mm diameter that I could use (Panasonic FM).
Old 08-25-2010, 07:03 PM   #37
PCBONEZ
Grumpy Old Fart
PCBONEZ's Avatar
PW and FM would both work for that one.
Old 08-25-2010, 07:47 PM   #38
Wrog
Awesome, thank you guys. All parts ordered, I'll post updates when I have some time to work on them.
Old 08-26-2010, 10:19 PM   #39
Wrog
Had a chance to desolder all caps tonight, and found a slight surprise. I was going by PCBONEZ's list for the TPII-550 he did awhile back when I originally posted, and lo and behold, my actual list has one difference. C38 (under one of the coils) isn't a 22uF 50V as I had assumed, but rather a 1uF 50V. So his list has quantity 2 of the 22uF 50V and mine has quantity 2 of the 1uF 50V, everything else is the same. Very strange... good thing I ordered extras!
Old 09-08-2010, 11:54 PM   #40
Wrog
Got all caps swapped out tonight, but too late to do any testing. I probed purple to ground (standby) and got 5.1v so that's a good start! Hopefully tomorrow I can fire it up in one of my PCs and report back.
