Go Back   Badcaps Forums > Electronics Theory and Troubleshooting > Troubleshooting Computer Displays
Old 07-20-2010, 11:17 AM   #1
goodpsusearch
City & State: Thessaloniki, Greece
My Country: Greece
Line Voltage: 230VAC 50Hz
I'm a: Hobbyist Tech
Default Nec Multisync FE700+
I got today that crt monitor and was planning to give it to a friend, but when tested it I noticed some discoloration in the upper right corner of the screen.
It can be seen in the photos that the chassis is broken there..
How do you explain the discoloration?
Is it fixable?
goodpsusearch is offline   Reply With Quote
Old 07-21-2010, 01:18 AM   #2
Scenic
o.O
Scenic's Avatar
City & State: Duisburg
My Country: Germany
Default Re: Nec Multisync FE700+
tried degaussing it?
some monitors have an option in the menu for that..
The USA have Barack Obama, Bob Hope, Stevie Wonder and Jonny Cash.
We have Angela Merkel, no hope, no wonder, no cash.
Scenic is offline   Reply With Quote
Old 07-21-2010, 01:42 AM   #3
Krankshaft
Krankshaft's Avatar
City & State: New Jersey, USA
Looks like somebody was playing with a magnet.
If the internal degaussing doesn't work as it sometimes won't if the screen is really magnetized you'll have to use an external degaussing coil.
Power it up and slowly rotate it in a circular motion while stepping away from the screen. Once you're far enough away and don't see it effecting the deflection anymore turn the coil off.
Krankshaft is offline   Reply With Quote
Old 07-21-2010, 05:39 AM   #4
goodpsusearch
My Country: Greece
Degaussing and on offs didn't help.
Where can I find an external degaussing coil?
Old 07-21-2010, 07:09 AM   #5
PlainBill
PlainBill's Avatar
City & State: Phoenix, AZ
Line Voltage: 120VAC 60Hz
I'm a: Hobbyist
Sounds like it could be a warped shadow mask.
PlainBill
Old 07-21-2010, 07:18 AM   #6
Scenic
o.O
Scenic's Avatar
My Country: Germany
thought about that too.. as it looks like the monitor fell onto that edge.. :/
Old 07-21-2010, 06:53 PM   #7
goodpsusearch
My Country: Greece
PlainBill
it uses aperture grill.
Old 07-21-2010, 08:25 PM   #8
PlainBill
PlainBill's Avatar
I'm a: Hobbyist
Semantics. The monitor was probably dropped on that corner, distorting the aperture grill, shadow mask, or whatever you wish to call it.
If you can easily borrow a degaussing coil, it's worth a try, but it's unlikely to actually help.
PlainBill
Old 07-22-2010, 04:15 AM   #9
goodpsusearch
My Country: Greece
I used a screwdriver with a magnet to test how the monitor responds when you get it near it.
I read over the internet that some people attach small magnets at their monitors in a way that the discoloration is less visible.
So, I put the screwdriver at the top right of the screen and the discoloration went away but it was temp: When the magnet was removed it got back.
Then I had the idea to degauss it while I had the screwdriver on it in a way there was no discoloration but that had the opposite results: The discoloration got bigger when the screwdriver was removed.
So, what I did was to put the screwdriver in a way that the top right corner of the screen was completely reddish and then degaussed. It instantly became less discolored and after I removed the screwdriver, the screen's colors are nearly perfect!!
I don't know if this is a temp fix and it will get discolored again over time... Time will tell.
What do you think?
Old 07-22-2010, 07:15 AM   #10
PlainBill
PlainBill's Avatar
I'm a: Hobbyist
What do you think?
I think you have magnetized it in a matter that compensates for the warping of the mask. The normal degaussing action the monitor uses when turned on will remove it. The distortion will return fairly quickly.
PlainBill
Old 07-24-2010, 05:57 PM   #11
goodpsusearch
My Country: Greece
You were right...
Old 07-24-2010, 06:01 PM   #12
PlainBill
PlainBill's Avatar
I'm a: Hobbyist
You were right...
Well, nobody can say you didn't give it a good try. Too bad it didn't work out.
PlainBill
Old 07-24-2010, 06:22 PM   #13
goodpsusearch
My Country: Greece
Thanx for your help anyway
