Go Back   Badcaps Forums > Electronics Theory and Troubleshooting > Troubleshooting Computer Displays
Old 07-12-2010, 11:32 AM   #1
Magnets
City & State: England
Question Viewsonic VP2030b Flickering
When playing games, or viewing fullscreen images my display pulses/flickers. It also doesn't like coulered/patterned backgrounds but is fine with a white screen.
It's been doing it for a few months but been gradually getting more frequent and now my monitor is hardly usable, even using this forum it is causing it.
[update]It's intermittent though, screen has been on for a few hours now and it's no longer doing when viewing this forum.
I took a video a couple of months ago of CSS http://www.youtube.com/watch?v=ZfRghUIMbbs (around 0:09/0:10 is a flash-bang in-game) but you can clearly see the screen is flickering and the display constantly freezes for a fraction of a second.
If I use the in-built USB hub it causes the flickering to happen almost non-stop.
What do you guys think? Bad caps? Is it easily repairable? (it's out of warranty now)
ps. never buy viewsonic, this is my third replacement under warranty [4th screen] and has lasted just under 2 years.
Magnets is offline   Reply With Quote
Old 07-12-2010, 12:44 PM   #2
retiredcaps
City & State: Canada
Default Re: Viewsonic VP2030b Flickering
It could be bad caps. Take it apart and look at the caps. If you are unsure, post clear focused pictures after reading the FAQ on how to insert pictures.
It is easy to repair if you have a soldering iron, solder, and a desolder pump or wick.
Old 07-28-2010, 01:01 PM   #3
lucky13
Magnets, if you ever come back to read the response to your thread. Do a search for other VP2030b or VP2130b threads. Other people have similiar issue like yours.
The problem is the USB takes its 5V from the Main board. So, if the Main board has issues with the caps and the 5V rail already fluctuating, then there is your problem.
lucky13 is offline   Reply With Quote
Old 07-28-2010, 01:56 PM   #4
Solder Boy
City & State: Ontario Canada
You might also have a problem with your CCFL lamps, put your ear to the top and or bottom of the LCD and listen for sizzling crackling noise and a distinctive smell of plastic burning. The lamps might be shorting out.. that will also cause the flickering as I found out during the repair of my KDS monitor.
The wire(s) leading to the CCFL on top were kinda crispy.
www.bcrelectronics.ca
Solder Boy is offline   Reply With Quote
Old 08-14-2010, 08:33 AM   #5
Magnets
I cracked it open and I can only see one bad capacitor (c206 - 1000uf 6.3V).
What is the correct method of removing the panel from the front and rear plastic casing? I had to leave the 4 screws in the back of the case and pry the front bezel off from the rear plastic case and simultaneously pry the latches that attach to the actual metal TFT panel.
I was expecting the rear case to just pop off after removing the screws.
I found this piece of plastic under the circuit boards, in this exact position. Anyone have any idea where it should go? Looks like it may go under the metal plate that is under the yellow board.
The USB board looks OK
Here is the only bad one I can see:
There was no smell of burning, and it's been like it for a while. One thing I noticed is that the flashing happens more on patterened screens (more so when the pattern is light). The flickering does not happen on a pure white screen, and decreasing the display resolution seems to ease the problem but not fix it.
I had a good read through the other thread but didn't see anyone mention the same problem, only issues with long startup time and the green LED flashing (I had that exact problem on an older viewsonic monitor).
Here's some more pics, let me know what you think.
The same photos in large resolution are here http://www.zen23322.zen.co.uk/images/forum/badcaps/
Old 08-14-2010, 10:55 AM   #6
lucky13
That piece of clear plastic goes on the solder side of the P/S. It acts as a insulator from the metal LCD back.
I recall the front bezel just pops out when you give it a twist/bend at the hooks. Be careful with the flat cable to the front switches.
Definitely replace that 1000uF cap on the Main board. I see the small cap on your P/S is alos a bit domed up (C4 on 101_5120.jpg).
The other caps on the 5V USB board need not change.
If you are considering replacing ALL the Crapxon caps on this unit, I suggest don't (it just too many and you could screw up something else. besides most of those small ones don't crap out).
Old 08-14-2010, 10:56 AM   #7
lucky13
BTW, it looks like your inverter has the newer version. Was this monitor reapired previously?
Old 08-14-2010, 11:17 AM   #8
Magnets
I noticed the same (c4) in the image, but it's just the angle of the flash/photo, the top is still flat.
I am looking at capacitors in Farnell, but they only seem to sell Panasonic NHG or FK http://uk.farnell.com/panasonic/eca0...-3v/dp/9692738
http://uk.farnell.com/panasonic/eeuf...0uf/dp/1744870
Can anyone suggest the best replacement? I see that RS also only stock those same Panasonic series. (looking for UK stockists)
The monitor is a warranty replacement that I've had for about a year and was almost certainly a repaired unit because the VESA mount cover was not fully attached when I received it and I had to pop it on myself. I had to wait for it to be sent from Denmark because viewsonic didn't have any stock in the UK.
Old 08-14-2010, 11:24 AM   #9
lucky13
Magnets, please add your country/region in your profile so others won't suggest you to get caps from US source. You can also order from ebay?
You need low ESR for that cap on the main board.
C4 on the P/S can be left alone based on your observation.
Whoever refurb this the last time for Viewsonic should have repalced that cap on the Main board!
Old 08-14-2010, 11:26 AM   #10
lucky13
Oh I missed 3 other caps on the Main board.
Replace these 330uF too: C204, C205 & C174.
Old 08-14-2010, 11:53 AM   #11
Magnets
I've always try to avoid ebay so would prefer not to, but if that is the only option then I will.
The monitor has been working fine for almost a year so I presume that capacitor was fine when they fixed the unit before shipping it out to me.
One other thing though, I noticed this red wire had been trapped between the heat shield and the back panel and it has flattened the wire, you can see where it has left an impression on the yellow tape. The tape was also under the CCFL connectors, whereas the service manual shows it's supposed to be above them.
Old 08-14-2010, 02:29 PM   #12
lucky13
Unless you have the 2sec to black issue, I would not worry about the flattened wire. it is a stranded wire anyway.
Old 08-16-2010, 08:09 AM   #13
Magnets
I've found most of the capacitors on farnell.
C206 1000uf 6.3V 8x15mm
Replace with Rubycon ZLH 1000uf 10V 8x16mm (10ZLH1000M8X16)
C204/C205/C174 330uf 16v 8x9mm
Replace with Rubycon ZLG 330uf 16V 8x11.5mm (16ZLG330M8X11.5)
C180/C181/C187/C188 100uf 16V 6.3x5mm
Replace with Panasonic FM 100uf 25V 6x11.2mm (EEUFM1E101)
C124 100uf 25V 6x7mm
I'll get some of the USB board capacitors too, just in case.
100uf 25V 6.3x11mm
Old 08-18-2010, 08:08 AM   #14
Magnets
I have just finished replacing C206 with Rubycon ZLH 1000uf 10V 8x16mm (10ZLH1000M8X16) and it has been running for 30 mins with no problems and the USB hub works fine now too. I didn't replace the others because I was too tight to buy a solder pump and just used the soldamop (braid) that I have, but it really doesn't work which makes things more difficult.
I noticed something rattling when moving the motherboard, but then realised it was probably just the tilt sensor
Thanks for the help
Old 08-18-2010, 08:28 AM   #15
Magnets
Spoke too soon, it's flickering again Will replace C204/205/174 now
Old 08-18-2010, 11:30 AM   #16
lucky13
Do change those 3x 330uF caps.
You might want to forgo using the built-in USB hub to see if it helps.
Do you have a meter to check voltages?
Old 08-18-2010, 03:54 PM   #17
Magnets
I swapped the 330uf caps and it's been running fine for almost 3 hours, I haven't tried the USB hub yet but I'd rather just not use it than have to spend more time fixing it, or break something.
I have a small multimeter but I am not confident enough to poke around with it while live.
Old 08-18-2010, 04:03 PM   #18
Magnets
I have it running with the rear cover removed and the metal cover/backplate for the power board is fairly hot (cool enough to hold your hand against but not for too long) is that normal?
What purpose does the sticky-back silver foil serve? It seems to have lost it's stickyness.
Old 08-24-2010, 12:04 PM   #19
Magnets
Been almost a week of usage and it's fixed.
I still have a problem with image persistence in a strip across the bottom few inches of the screen. Is that fixable?
If the same image is on the screen for a few hours I get an inverted ghost image that disappears after a while.
Old 08-24-2010, 02:05 PM   #20
lucky13
That issue is your LCD. Not repairable.
This model runs very warm. Good in the winter.
The silver tape is for EM/RFI shielding. Unfortunately, once you pull it off, it does not stick anymore. No big deal unless you have AM radio nearby.
