Canicon 1000uf10V looks bulging. I will replace. The PSU is still performing fine though.
Tmp-ans Lc B350atx
Re: Tmp-ans Lc B350atx
congrats on getting quoted in the cNet article that pauloncall posted about
anyway the more press on the badcap issue the better until someone starts doing something about it.Last edited by willawake; 11-10-2005, 03:43 PM.
The bulging capacitor is used in the +5V standby rail (If this rail fails, you can't start your computer!)
Are there any Gincon capacitors in it? (You should find two of them)
The chip is marked "2003", as shown in the pictures - most likely to be a poor quality one. Some quality power supplies from big manufacturers have their own chips in them.
My LC-B400ATX supply was almost identical to these pictures. I'm glad I scrapped it before it damaged my system!My first choice in quality Japanese electrolytics is Nippon Chemi-Con, which has been in business since 1931... the quality of electronics is dependent on the quality of the electrolytics.
That is a 350W P/S?!
I'd be afraid to use it for more than 250W. Those heatsinks and that power transformer are going to get really hot at 350W. I'd love to know what the ratings are of the +5V and +3.3V O/P rectifers. If the part numbers look something like MBR4060DT, the "40" means its rated for 40A, and the "60" means the peak inverse voltage is 60V.
PeteS in CA
Very similar circuits of this unit can be found on http://narod.yandex.ru/100.xhtml?ele...Y-B200-ATX.zip and http://www.eserviceinfo.com/download.../L&C_400W.html
I can also see electrolytics with an unknown manufacturer's logo in the attached picture.
As with my unit, the electrolytics (as well as the output rectifiers and the heatsink) were a bit under-rated.My first choice in quality Japanese electrolytics is Nippon Chemi-Con, which has been in business since 1931... the quality of electronics is dependent on the quality of the electrolytics.
Commonly every PSU model number starting in "LC" means that it's an crappy L&C power supply. Those caps with a logo of a planet in L&C power supplies are generic caps.Last edited by Newbie2; 11-11-2005, 07:41 AM.My gaming PC:
AMD Phenom II X6 1100T Black Edition 3.3GHz Six-Core CPU (Socket AM3)
ASUS M4A77TD AMD 770 AM3 Motherboard
PowerColor AMD Radeon RX 480 8GB GDDR5 PCI-Express x16 3.0 Graphics Card
G.SKILL Value Series 16GB DDR3-1333 RAM (4x4GB dual channel)
TOSHIBA DT01ACA200 2TB 3.5" SATA HDD (x2)
WD Caviar Green WD20EARX 2TB 3.5" SATA HDD
ASUS Xonar DG 5.1 Channel PCI sound card
Antec HCG-750M 750W ATX12V v2.32 80 PLUS BRONZE Power Supply
Antec Three Hundred Mid-Tower Case
Microsoft Windows 10 Pro 64-bit
Microsoft Windows 7 Ultimate SP1 64-bit
na064,
That looks to be an very obsolete Samsung part - TO-220, 600V, 2A, 5 Ohm, N-channel. SAmsung MOSFETs were acquired some time ago by Fairchild. This looks like a decent replacement. It's same package and voltage, 3A, 3.4 Ohm; it's probably faster, with a lower gate charge (easier to drive) than the original.PeteS in CA
