Go Back   Badcaps Forums > Electronics Theory and Troubleshooting > Test Equipment Usage, Techniques, and Reviews
Old 06-15-2010, 09:25 PM   #1
smason
City & State: Alberta
My Country: Canada
Line Voltage: 120VAC 61Hz
I'm a: Hobbyist Tech
Default Magnification
So what do you all use for working on tiny SMD stuff?
I purchased a cheap 10x loupe with my last Digikey order, it's great except you have to be right on top of the device, and you can't always get close enough when there are other components in the way.
Also it's hard to solder under a loupe
smason is offline   Reply With Quote
Old 06-15-2010, 11:40 PM   #2
stj
City & State: Europe
Default Re: Magnification
i just look!
Old 06-16-2010, 04:35 AM   #3
Radio Fox
Radio Fox's Avatar
City & State: East London
My Country: UK
Line Voltage: 230VAC 50Hz
I found that a 3X eyeglass for inspecting a board is a good compromise. Anything higher, means you have to get too close to the board.
When soldering, I use a magnifying headset that I bought on ebay. This leaves both hands free.
________________________________________________
Invisible airwaves crackle with life
Bright antennae bristle with the energy
Radio Fox is offline   Reply With Quote
Old 06-16-2010, 09:40 AM   #4
PowerAmpFreak
My Country: Sweden
Originally Posted by stj
i just look!
Yeah right, but most of us are interested in what we're looking at, He He
PowerAmpFreak is offline   Reply With Quote
Old 06-16-2010, 04:13 PM   #5
stj
i see just fine.
maybe it's because i spend most of my time in underground computer centers & workshops without many windows and havnt had my eyesight fucked up by decades of exposure to the UV from the sun.
Old 06-16-2010, 11:01 PM   #6
PlainBill
PlainBill's Avatar
City & State: Phoenix, AZ
Line Voltage: 120VAC 60Hz
I'm a: Hobbyist
I have a Luxo magnifier on an articulating arm (likethis one.) This works well when I am trying to identify components. As for soldering, thus far my eyeballs have worked well, but I suspect after next week I will be shopping for a magnifying visor of some sort.
PlainBill
Old 06-17-2010, 09:28 AM   #7
smason
My Country: Canada
Thanks for the feedback. I have a similar Luxo laying beside my bench, I need to :
a) clean off the bench so I can use it, instead of the pool table
b) find a method of mounting it to the bench.
I may still look into a visor of some sort. Sucks to get old....
Old 06-17-2010, 11:27 AM   #8
PlainBill
PlainBill's Avatar
I'm a: Hobbyist
I had the same problem. Mine has a 5/16" diameter post designed to slip into a bracket. I didn't have the bracket so I drilled a 3/8" hole in a hunk of wood and clamped it to my desk. (My workbench also should be cleaned off).
True, but it beats the alternatives!!
PlainBill
Old 06-17-2010, 12:04 PM   #9
PowerAmpFreak
My Country: Sweden
i see just fine.
You're lucky stj! I don't know your age, but I'm 35 myself and need more and more help from magnifiers these days.
Anyways - keep on stay away from the sun then!
